Old 03-09-2017, 07:43 PM   #1
Shabill
Default Recovering Firmware in Bump Controller
So just got my iOS app and loved that it automatically updated firmware straight from the app. Updated the firmware on the bump controller. Great. Then tried updating the firmware on my PL8. It failed. I had to disconnect, connect to my laptop and update firmware through my laptop. All set. Except ... the bump controller can't figure out that the firmware is all set. Even if I disconnect the charger altogether. Message is attached. Thoughts?
Compass 7HV (BE SK720 w/GPS)
Gaui X3 (SK720 Blue) / FBL TRex 450SEV2 (SK720 Blue)
Blade MSR / MCX
JR 11X
Shabill is offline        Reply With Quote
Old 03-09-2017, 07:59 PM   #2
Shabill
Never mind; I figured it out. I turned off channel 1 in the bump controller settings and then turned it back on and that seemed to do the trick.
Blade MSR / MCX
JR 11X
Old 03-09-2017, 08:52 PM   #3
RevoKelly
After the PL8 firmware upgrade failed, did you attempt to retry (after power cycling) ?
Our testing has shown that it will indeed fail occassionally on the first attempt, but has always succeeded on the 2nd attempt ... so curious to see if if everyone else experiences the same.
RevoKelly is offline        Reply With Quote
Old 03-10-2017, 11:28 AM   #4
Shabill
No, I wasn't able to get it to restart through iOS after it failed. I tried, and when that didn't work, went in through my laptop.
And as an update, as it turns out, now whenever I power on the charger, the same message shows up on the bump controller and I have to go into the bump controller and disable and then re-enable that charger.
Blade MSR / MCX
JR 11X
Old 03-10-2017, 02:42 PM   #5
RevoKelly
Strange. Ill see if i can recreate it.
Old 03-17-2017, 11:23 AM   #6
Shabill
No luck recreating? I can't make it stop.
Well, there is one solution (for me) ... since I only have 3 chargers, think instead of using 1,2,3, will use 2,3,4.
Blade MSR / MCX
JR 11X
Old 03-17-2017, 02:01 PM   #7
RevoKelly
I cant recreate yet, but will add a feature to next release that workaround it by resetting that upgrade state anytime the port is enabled/disabled.
If you dont want to wait for that release, just go i to settings -> Factory Reset. That should clear the problem, but youll need to do setup again on the Bump - power supply settings, wiring mode, etc., will revert back to default values.
Old 03-17-2017, 04:20 PM   #8
Shabill
I can wait for the update. Thanks!
Blade MSR / MCX
JR 11X
