Old 03-18-2017, 08:00 AM   #21
larryfl
Originally Posted by Dansy View Post
I have a 48v to 12v converter....for my fans and USB plugs....
can you send a link to that? or where to get it?
larryfl is online now        Reply With Quote
Old 03-18-2017, 08:03 AM   #22
Dansy
48v to 12v converter copy and paste in google, I got mine on eBay from a US vendor....don't remember who has been a while, its available from many many vendor...
Daniel...many flying planks.....Goblin Urukay Red/White, Gaui R5
Goblin 380 KSE Yellow/Blue, Goblin 420 XNova
JETI DC-24, MKS Servos, Ikon2/Brain2, Axon, Kontronik, XNova
Revolectrix/MeanWell PS, DPL8, PL8, 2x XP10 and Bump Contr.
Dansy is online now        Reply With Quote
Old 03-18-2017, 08:22 AM   #23
Ace Dude
Originally Posted by larryfl View Post
i currently have a mean well 1000 24v and about to purchase a new mean well 2000 that will give me about 1500 usable...
so the question is 24 v or 48v ?
i have a dual pl8 so 48v is fine..the issue is my case fans and usb charger are 24..i can probably get a 48v fan..not sure about the usb charger...
thoughts and recommendations?
does 48v make much of a difference and worth it to overcome the buck/boost?
I've been using a 48v power supply on my DPL8x2 for several years now. The higher the input voltage the less current draw so less heat generated in some areas.
The extra 500W may be helpful in your case depending on your charging needs.
I'm using 48v fans in my case. The DC-DC converters are an options as well as using a small power supply of voltage you need. Something like the Meanwell SGA series:
http://www.trcelectronics.com/Meanwe...ptor-sga.shtml
Ace Dude is offline        Reply With Quote
Old 03-18-2017, 10:17 AM   #24
KevinB
I'm running a 48-2000 Meanwell in my charging case as well, but powering two dualPL8s. I don't like parallel charging. I'm pushing the limits of the Meanwell, when I charge 4 6s5000 packs at 3c, but the case handles it fine. Doing that at max load (according to the BUMP), it's using approx 1750W.
I usually charge at 2c though.
For my case fans and USB ports, I just used an old wifi router power supply. It was 12V 3A which was all I really needed.
KevinB
KevinB is offline        Reply With Quote
Old 03-18-2017, 10:32 AM   #25
Ace Dude
KevinB
You using 120v AC or 240v AC?
Old 03-18-2017, 10:46 AM   #26
larryfl
120
Old 03-18-2017, 11:05 AM   #27
Dansy
120
I should mention that if I by charge at home in the garage I have a 20amps just for that
Old 03-18-2017, 01:42 PM   #28
KevinB
120v.
KevinB
