Old 01-20-2017, 02:55 PM   #1
Jamie Marks
Default Survey from Revolectrix
Help us by completing a brief survey and become eligible for prizes from Revolectrix!
http://www.revolectrix.com/new_appli...t01.20.17.html
Thanks,
Jamie Marks
REVO USA
Jamie Marks is offline        Reply With Quote
Old 01-20-2017, 10:41 PM   #2
Dansy
Thanks,
Jamie Marks
REVO USA
Done, I found it a little confusing at the end.........for me to replace my DPL8 and my PL8 it would required to have some advancements, like higher voltage input for the PL8, higher discharge rate for either of them...thing of that nature, having the bump instead of the screen has no improvement over what I already have.....chargers, PS and Bump under the deck, probably not what your looking for.....
Daniel...many flying planks.....Goblin Urukay Red/White, Gaui R5
Goblin 380 KSE Yellow/Blue, Goblin 420 XNova
JETI DC-24, MKS Servos, Ikon2/Brain2, Axon, Kontronik, XNova
Revolectrix/MeanWell PS, DPL8, PL8, 2x XP10 and Bump Contr.
Dansy is online now        Reply With Quote
Old 01-21-2017, 08:01 AM   #3
RevoKelly
FYI - the proposed PowerLab 8 Touch (single and dual) would support 48v just like existing DPL8.
RevoKelly is offline        Reply With Quote
Old 01-21-2017, 08:03 AM   #4
Shogun71
Done. I agree with the above.
This would be an adjunct to my current setup rather than a replacement.
I also have a PL8 and DPL8. I do like the idea of a 4 channel setup for my smaller batteries.
Rob
Team pilot Lynx Heli Innovations.
Jeti DS-16, Oxy 3, Goblin 380, 500, 570, 630, and 700 competition, Airwolf 600 scale heli, Sk 540 and 720, Spartan VX1e, YGE 18 LV to 160 HV.
Shogun71 is online now        Reply With Quote
Old 01-21-2017, 08:08 AM   #5
Dansy
Sorry I was sure I saw 32v....
Old 01-21-2017, 08:11 AM   #6
jcflyer
I currently use 2 PL8's together and have no plans for changing, unless it would be a substantial improvement...
Helicopters Don't Fly - They Beat The Air Into Submission
Logo 500SE
Minicopter Diabolo
Banshee # 45 700 LE and 850
jcflyer is online now        Reply With Quote
Old 01-21-2017, 11:17 AM   #7
pctomlin
That was for the 6S series of chargers.
Would have liked to have a general comments area in the survey. Having access to a design engineer or technician to talk with is not the most beneficial use of their time. Having someone very knowledgeable of the product typically can answer 90% of our questions. Very good Manual can answer most questions, as long as we read it. . Revokelly present on the forum, priceless.
If you do make chargers with integrated Bump Controllers, please make it a modular installation so it could be remote mounted also. One of the huge advantages to Revo charging products now is the Bump and the flexibility it gives in case design/charger placement and a major drawback still with icharger equipment.
There is two PL8s and a set of DPS1200FB power supplies mounted under the top deck.
Paul
Agile 5.5 - Quantum 4125-1100, Ice 100, Ikon FBL / Outrage 550 - HK4020-1390, Edge 120, iKon FBL
Rave Ballistic FSO - HKIII 4035-560, Ice2 HV160, iKon FBL / Protos Max V2 - MSH 4530-500, Edge HV160, Brain FBL
pctomlin is offline        Reply With Quote
Old 01-21-2017, 05:43 PM   #8
Dansy
I was already told about that but thank you....
Old 01-24-2017, 12:04 PM   #9
RevoKelly
The Bump Controller and current PowerLab chargers will continue on as products, so these new products are mainly targetting guys who don't need the "modular" design that gets installed in charger cases. It is meant for more convenient standalone usage.
There are some differences (like all XH connectors and a dual version of the 6S charger), but the Bump Controller will continue to get the same features/fixes/upgrades as the PowerLab Touch series of chargers, so there won't be any significant differences between the two - aside from the obvious "modular" vs "all-in-one" hardware.
Old 01-24-2017, 12:20 PM   #10
tporter416
One thing I would like to see is a case, one that works with your controllers and has room for power supplies underneath, something that makes it easy to turn your chargers into an easy grab system for when I goto the field. Currently making up my own case, would have preferred something that makes the job easier and overall result neater...
MSH Protos V2 Max
SAB Goblin 380 & 500
Blade 180CFX, mCPX BL, nano CP S
tporter416 is offline        Reply With Quote
Old 01-24-2017, 01:09 PM   #11
luckyflyer
I was going to do the survey but noticed that it was hosted by Survey Monkey. I fear that once they have my info I'll be on their mailing lists forever. If revo had done this survey in house I would have participated.
luckyflyer is offline        Reply With Quote
Old 01-24-2017, 06:38 PM   #12
RevoKelly
Thats what bumpcharger.com is for ;^)
