Like Tree5Likes
Old 01-25-2015, 12:15 PM   #501 (permalink)
Originally Posted by K-rash View Post
I'm not sure if a Blade heli is allowed, but here is my effort.....
Looks great, very clean! I love the anodized red and carbon combo too!
murderisthegame is offline        Reply With Quote Quick reply to this message
Old 01-25-2015, 04:26 PM   #502 (permalink)
here is my 450L dominator:
ID:	565124   Click image for larger version
Greetings from Israel
Trex 700e dfc pro HV\Ikon FBL\CC Edge 160
Trex 450L\Ikon FBL\CC talon 35
Gaui X3\Ikon\Talon 35\460MX
bendisar is offline        Reply With Quote Quick reply to this message
Old 01-25-2015, 07:28 PM   #503 (permalink)
That looks really good!
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 01-26-2015, 07:43 AM   #504 (permalink)
agreed
BladeScraper is offline        Reply With Quote Quick reply to this message
Old 02-08-2015, 04:52 AM   #505 (permalink)
Hello everyone, totally new to rc helis and a couple of weeks bought a blade nano cxp. Couple of days later had the opportunity to buy a blade 500x and a trex 450L Dominator.
The 500x is BNF but the 450L I've had to build and after a lot of research here and else where here it is.
whatson is offline        Reply With Quote Quick reply to this message
Old 02-08-2015, 08:31 PM   #506 (permalink)
Guess I'll have to sort out how to post pics properly....
Old 02-12-2015, 06:59 PM   #507 (permalink)
my x3
Old 06-20-2015, 12:13 AM   #508 (permalink)
Default Tarrot 450 FBL
Here is my attempt when recently assembled for a good friend his first heli.
I think it is a good training base.
Have Nice Flights
ID:	591815   Click image for larger version
ID:	591816   Click image for larger version
ID:	591817   Click image for larger version
socratesb is offline        Reply With Quote Quick reply to this message
Old 12-09-2015, 02:14 AM   #509 (permalink)
Here's my GAUI X3
Align Trex 470LM / iKON2BT
SPEKTRUM DX8G2
RCHN 702 PAST: Mikado Logo 550SXv2, Mikado Logo 480 XXtreme, GAUI X3, GOBLIN 500 SPORT, TREX 550L
mattday is offline        Reply With Quote Quick reply to this message
Old 12-09-2015, 05:24 AM   #510 (permalink)
Have Nice Flights
Originally Posted by mattday View Post
Here's my GAUI X3
Guys, you really should cover all wires going through the edge of the carbon frame. Leaving it uncovered is asking for troubles!
Carlos
CZorzella is offline        Reply With Quote Quick reply to this message
Old 12-09-2015, 06:29 AM   #511 (permalink)
Carlos
Cheers Carlos, I was too keen to get it flying. Just did a temporary fix for now.
SPEKTRUM DX8G2
Old 12-09-2015, 07:05 AM   #512 (permalink)
Matt, I'm especially concerned about possible damages to the satellite wires that are rubbing against the carbon fiber.
Carlos
Old 01-26-2016, 11:47 AM   #513 (permalink)
Default CX450SE-V3
It's not anything new or special, but at least it fairly clean.
bvrrocks5150@gmail.com is offline        Reply With Quote Quick reply to this message
Old 02-02-2016, 11:03 PM   #514 (permalink)
My first attempt. Be gentle. 450L
Open to suggestions obviously. I think it's routed well. Still looking for a transmitter/receiver for it, hence why there are wires still hanging.
DaJokr is offline        Reply With Quote Quick reply to this message
Old 02-22-2016, 09:27 PM   #515 (permalink)
Looks good! A few things, I see you are just putting zip ties on the wires, it is best to wrap a small strip of electrical tape around and then ziptie, I have had the ties cut into wires. And not related to wiring, make sure you get your DFC links screwed on a little more, wouldn't hurt to have a few more threads to grab onto. Other than that, looks great!
Team Synergy
Dylan Hudock is offline        Reply With Quote Quick reply to this message
Old 02-23-2016, 07:57 AM   #516 (permalink)
Apart from what Dylan said, the only thing I want to add is that you should consider using a mesh for the wires. Not only makes the wiring a lot cleaner, but it also protects the wires from the frame edges and zipties.
Carlos
Old 03-21-2016, 08:09 PM   #517 (permalink)
I filed all the edges so they were all smooth, I'll see if I can find that mesh, it would look a lot cleaner with it as well as be protective. I'm not sure about the esc though as the wires are sitting on the motor, and they were so stiff to bend that I actually broke a bullet connector off the motor, which I still need to fix...and there's virtually no wire to work with.
The DFC links felt like they might start to strip if I went any further, that's why there is so much there. I still have yet to setup the heli as I have yet to put a receiver in it.
Old 03-23-2016, 10:45 PM   #518 (permalink)
The icon doesn't mind being strapped down like that? normally FBL units you only use the double tape on bottom and so they can more a tiny tiny bit.
I always say im going to get some the wire mesh to put on mine but never have. i still don't fully understand how you install it guess you have to remove the connector then re install it.
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 03-30-2016, 09:11 AM   #519 (permalink)
That's called the "Milton" Mod. It serves as a Vibration Isolation System. More details at https://www.helifreak.com/showthread.php?t=282042
Carlos
Old 03-30-2016, 09:46 AM   #520 (permalink)
Here's a few of one of my X3's
jbobb1 is offline        Reply With Quote Quick reply to this message
