Old 07-08-2015, 10:23 PM   #1 (permalink)
Default mCPx Power loss
Hey guys,
Can't seem to find anything about my issue. When flying when I give it full throttle and the motor turns off and everything works still and is lit up still. Any help would be great!
Blake
Blakez is offline        Reply With Quote Quick reply to this message
Old 07-09-2015, 05:15 AM   #2 (permalink)
Sounds like LVC. Low voltage cutoff. 1st how old are your batteries? 2nd how old is the main motor?
weav01 is offline        Reply With Quote Quick reply to this message
Old 07-09-2015, 05:26 AM   #3 (permalink)
Sounds to Me like an issue I've had before...
Run the heli at 40-60% throttle with no main blades (hold it with one hand) for 2 batteries at 4 minutes each...
Then see if your problem persists
Old 07-09-2015, 02:43 PM   #4 (permalink)
They are brand new batteries motor is still strong.
I tried the two batteries at 50% and ran at least for 4 mins.
Any other input would be great!
Blake
Old 07-09-2015, 03:56 PM   #5 (permalink)
Blakez, jonjet would know!
Old 07-09-2015, 03:58 PM   #6 (permalink)
What version 3n1 board do you have? Original board and motor?
Old 07-09-2015, 04:02 PM   #7 (permalink)
I guess a better way to approach that would be to explain "why" you might want to do that or "what" exactly it achieves. I'll admit that it sounds a little crazy. But hey, I've seen crazy things work sometimes.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 07-09-2015, 04:07 PM   #8 (permalink)
The why is really not easy to explain...but I've had a very similar issue with new V2 boards coupled with new stock motors...and the method I outlined solved the problem...several times
My opinion? Break-in period...especially if it's not been flown in months or there are new components
Old 07-09-2015, 09:16 PM   #9 (permalink)
JonJet thanks for the help! It looks like it fixed the problem.
What is your best advice to get rid of tail blow out? Is it the tail motor? Battery?
Old 07-09-2015, 09:31 PM   #10 (permalink)
Three cheers for crazy. Good call Jon.
Old 07-09-2015, 10:32 PM   #11 (permalink)
The best way to end tail blowout is to upgrade to at last a 7mm tail...I've done several dozen and not one of them has the problem anymore
Old 07-09-2015, 11:12 PM   #12 (permalink)
Do I need to do any modification on the board at all?
Old 12-16-2015, 04:01 PM   #13 (permalink)
My issue sounds like it may be related though it is somewhat different. I have two MCPx V2's. On each, with a fresh battery, the heli is almost unable to lift off the ground even at full throttle. On one, I had a similar problem, replaced the board, and it was great until after a few flights, I smacked it into the ground. Afterwards, it was doing the same thing. It will go for a few minutes on a battery and the blue light stays on solid. On the other, it will spool up, will barely lift off and within a few seconds, it settles back to the ground and the blue light is blinking.
Any ideas?
Thanks,
Jack Cutrone
May all your landings be soft.
Align 600E Pro DFC, Blade 230 S, Blade 200 SRX, Blade MCPx BL, Aeromaster 35% Extra 260 (under construction), Hanger 9 40 size P51, SIG Somethin' Extra, Eflite Carbon Z Yak 54, Motion RC Avanti (under construction)
jackcutrone is offline        Reply With Quote Quick reply to this message
Old 12-16-2015, 04:37 PM   #14 (permalink)
Any ideas?
Thanks,
Jack Cutrone
First guess is the battery, but if you've tried a new one, that would lead Me to expect the power cable...the stock one is very cheesy...try a decent power lead with about 4" of wire so you can route it away from the left servo, and that may solve your problem
Name:	mCPX Power Lead 001.jpg
Old 12-16-2015, 05:40 PM   #15 (permalink)
Agree on the power cables.
They will slowly break the strands until there are only 5 or 6 strands trying to carry all that current. Carefully remove that rubbery coating around the wires where they connect to the board. I'll bet you find about half the strands broken.
I have to turn the music down while driving so I can see better.
MariaFan is offline        Reply With Quote Quick reply to this message
