Old 08-25-2009, 03:30 AM   #1 (permalink)
Default TREX E / ESP FAQ's
Ok Freaks,
A request was made to have a FAQ's sticky made concerning 600 E & ESP build issues, drive train combination's, repair and replacement info and such.
Should make life easier for all here, this way the same questions won't need to be answered over and over again, and the newbies can search through for easier answers.
A request to all HeliFreak Members...
Please, if you have a question, comment or concern about any of the FAQ information ..please bring it up in the main forum as to not to clutter the information postings here.
Thank you
what do you all think???
nightflyr
JR9303 / JR9503 / Futaba10CHP
nightflyr is online now        Reply With Quote Quick reply to this message
Old 08-25-2009, 04:33 AM   #2 (permalink)
Default ESC replacement
Common inquiry:
What is a suitable aftermarket ESC replacement to the Align ESC?
If your planning on staying with a 6S battery setup, the CC110HV would be a reliable and cost effective replacement.
But if you planning on upgrading to 10S or 12S ( with a suitable motor of course) the CC85HV will work just fine.
There are other aftermarket replacement, but I can not comment on them due to the fact I only own CC equipment.
So anyone who is using other than CC ESC's please feel free to air your thoughts.
nightflyr
Old 08-25-2009, 06:01 AM   #3 (permalink)
Default Scorpion Motor upgrade for ESP
More fliers are upgrading the stock motor's out of the heli's in favor of an upgraded version.
In order to install a Scorpion motor into an 600 ESP, the Frames will need to be modified to accept the wider motor (side note: there are direct fit replacement motors that can be purchased and installed without frame cutting)
The modification is fairly easy by using a dremel tool with a cut off wheel:
Old 08-25-2009, 08:33 AM   #4 (permalink)
+1 - Great idea!
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 550 DFC 3GX, 600ESP V-Bar, 700E 3G
Shef is offline        Reply With Quote Quick reply to this message
Old 08-25-2009, 09:00 AM   #5 (permalink)
hey guys I am building a 10s t-rex 600esp with a cc hv 85 I was wondering why do people put a cc hv 110 on a 6s set up that's a lil over kill right correct me if I am wrong but that's good for t-rex 700e right the cells it holds and the motor plus it cost about 40 dollars more than a cc hv 85 thanks guys just wanted to know
blindpilot is offline        Reply With Quote Quick reply to this message
Old 08-25-2009, 09:02 AM   #6 (permalink)
I blow through 100A pretty frequently with my 6S setup.
Old 08-25-2009, 09:11 AM   #7 (permalink)
Default ESC requirement
100 amp is required for 6S due to current draw of the electrical system, If you increase your cell count say 10S your current requirements are reduced so a CC85HV is rated high enough to work on such a setup
nightflyr
Old 08-25-2009, 09:28 AM   #8 (permalink)
yea couldent you just a cc 125 instead of a cc hv 110
Old 08-25-2009, 09:31 AM   #9 (permalink)
I guess you could...but it's only good up to 6S so if you ever go to 8, 10, or 12 cell, you'd need another ESC.
Old 08-25-2009, 12:48 PM   #10 (permalink)
Maybe this is the right place to ask a newbie-ish question about a T-Rex 600. I'm in the process of putting together my 600 right now and I'm deciding on components.
I'll just be running the power system to start so that means I'll need to pick up some 6S packs and I'm trying to avoid re-buying packs when I upgrade. If I wanted to upgrade to a 12S setup in the future what size 6S packs should I pick up? From what I've read most people running 6S packs are using larger 5000+mah packs while people running 12S are using more in the neighborhood of 3500mah packs. What is my best bet? Run 2x 3500mah packs in parallel at first then in series when I upgrade? Or should I resign myself to re-buying packs and grab some 6s 5000's for now?
Fatalcrash is offline        Reply With Quote Quick reply to this message
Old 08-25-2009, 12:55 PM   #11 (permalink)
You my friend need to log on to HobbyKing and check out the prices you'll be happily surprised
you can also run 3700's or 4000's
Old 08-25-2009, 01:33 PM   #12 (permalink)
It seems to me that the CC Phoenix ICE 100 will be a good lower cost option for people like me that want to start with 6S and then *maybe* run 8S in the future. It's still just coming out in stores, so I haven't read many reviews, but it seems to be a good stand-in for the Align Fireball 100A ESC. Also, the data logging is a neat feature.
Anyone using or planning on using an ICE 100 (not ICE Lite 100)?
ferret30 is offline        Reply With Quote Quick reply to this message
Old 08-25-2009, 01:35 PM   #13 (permalink)
I just went ahead and bought a new HV110 on ebay for $179 and used the bing cashback trick for 10% off. Was a layup.
Old 08-25-2009, 01:37 PM   #14 (permalink)
+1 agree the ICE will be a good aftermarket replacement but it's limit is 8S so it does no good for me
Old 08-25-2009, 01:38 PM   #15 (permalink)
O really? I saw a 110HV for sale on HF but I skipped it since I saw you sent a PM first. Did you not end up getting it, or do you have 2 now?
Old 08-25-2009, 01:40 PM   #16 (permalink)
I decided to go new. I also already have a CC Link so didn't need another.
Old 08-27-2009, 04:07 PM   #17 (permalink)
Default Bell Crank shims
Something you new ESP owners should be aware of....
When installing your bell cranks AFTER you finish you'll notice 4 shim washers that are not mentioned in the assembly manual.
If you push/pull on the bell crank shaft, some if not most of you will notice side slop.....and guess what those mystery shims are for.......
depending on how much lateral movement you have will depend how many shims you'll need.
nightflyr
Old 08-27-2009, 10:43 PM   #18 (permalink)
Default 3rd Bearing block Modifacation 600 ESP
There has been a lot of talk, complaining concerning the main shaft being undersized and causing lateral movement in the head.
This is not the solution but an enhancement to the main shaft.
The undersized shaft slop can only be corrected in one of 2 methods.
1) A correct size main shaft either produced by Align or privately
2) The use of Loctite 680 ... LOCTITEŽ Product 680 is a high strength, single component anaerobic retaining adhesive for cylindrical joints. The product cures when confined in the absence of air between close fitting metal surfaces.
Here is how I incorporated the 3rd bearing block to the ESP frames.
1) Locate and drill the metal block mounting holes......(side note..Helifreaker My2cents has fabbed up a drill template for this, you might try to pm him and inquire about it)
2) Install and align all 3 blocks with the main shaft.....
The 3rd bearing was modified to fit into the metal block holder.
At the time of assembly of the head and main shaft into the bearing blocks, completely clean the shaft and internal race faces of any oil and residue, apply the locktite 680 and allow 24 hours to completely cure before proceeding any further.
If there is any question as to how well this works.....I have well over 100 flights against it and it is still rock solid with absolutely no lateral play what so ever.
ID:	112430   Click image for larger version
ID:	112431   Click image for larger version
Old 08-28-2009, 06:25 AM   #19 (permalink)
Sweet fix.
Two questions;
1. What are your measurements for the vertical positioning of the shaft within the blocks?
2. If (more likely when) I crash, and the shaft is damaged requiring replacement, will the loctite 680 release or will the bearing have to be replaced as well?
Scotty
Goblin Kraken Pyro 850-40 14s, NEO, Xpert R2 Kosmik Cool 160
Goblin 700 KSE 4525-520, NEO, Xpert R2, Kosmik 160
Goblin 570 XNova 4025-860, NEO, Savox 1257, BL9288, Jive Pro 120
Goblin 380 KSE Xnova 3215-930, NEO, DS-3001HV, DS5005HV, Koby 90
Scottyb410 is offline        Reply With Quote Quick reply to this message
Old 08-28-2009, 06:38 AM   #20 (permalink)
Yep, you are right, I found it AFTER I finished.......
