Belt CP E-Sky Belt CP |
05-02-2015, 07:28 AM | #1 (permalink) |
4 axis giro
Bit of a quick question but is there any harm putting a 4 axis giro on a flybared 450.It wont be anytime soon as i am currently unemployed so money will be tight till i find a new job
Hubsan 501s |
05-02-2015, 08:30 AM | #2 (permalink) |
Hi Antony
I'm thinking you mean a 3 axis gyro, or FBL controller. From what I've read, they can't practically be used with a flybarred head as you get control interactions between the flybar and the controller. As with all things, people have tried, and no doubt some will have succeeded to an extent, but probably only by turning the main rotor gain way down, so that the stabalisation is really still coming from the flybar. That being the case, what's the point, you might as well just use a tail gyro anyway. That having been said, you don't necessarily have to buy a flybarless head to do away with the flybar. My 600 is still flying with my own modified set-up. Recently I converted it to DTS, and improved it a little, but it was pretty good to begin with. I also switched it from the MicroBeast controller to the Spartan VX1e, so maybe the improvement was primarily as a result of the new controller. Resolution of the head, or granularity of control for the FBL unit, which is the tricky thing to achieve when you mod your own head, was reasonably good. I expect you could also get it good enough with the 450. Cheers Sutty
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1 Pro, FBL Trex600ESP VX1e, Parkzone P51D, QRX350Pro |
05-02-2015, 09:13 AM | #3 (permalink) |
Doh, and I thought it was going to include the 4th dimension!!
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades TRex600N, Kasama Head, OS50SX |
