Go Back   HeliFreak > R/C Electronics Support > JLog - The JIVE logging stamp
JLog - The JIVE logging stamp JLog - The JIVE logging stamp - Official English Support Forum
Old 04-20-2011, 03:17 AM   #41 (permalink)
Aha...
dl7uae is offline        Reply With Quote Quick reply to this message
Old 04-20-2011, 11:51 AM   #42 (permalink)
@beans07
Unfortunately they are out of stock but I will wait until they come in.
Hmm..., sure? Just did an order there (except of the last click ), no "out of stock".
Well, the light is yellow but - who knows... Never saw a green light there.
Tom
Old 04-20-2011, 04:52 PM   #43 (permalink)
Hi Tom.
Okay, i might have use for voltage sensor in 2-3 months. (i will have 8.4V BEC for electronics).
Petr, would be the following okay?
max. 12.8V, 12.5mV measurement resolution, 100mV log/display resolution, logged/displayed as "extTemp0" (°C)
voltage devider: -----|--4R--|--x-----------------> to JLog 4-1
..............................................i
.............................................R
...........................................----- GND
Resistors of the devider: For example 40k/10k, metal film resistors.
Tom
Old 04-21-2011, 02:01 AM   #44 (permalink)
I think it would.
When i will have external BEC (Western Robotics Super BEC), will i need to connect ground with Jive?
I think the Jive is not opto isolated?
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 04-21-2011, 03:54 AM   #45 (permalink)
Yes.
No OC.
Attention, OT: Why WR? Because of a higher output voltage?
(If I look at the tiny cooling of the WR's and then read the specs... Even with an outstanding good Eta... - there're limits with buck regulators at higher input voltages - ... The physics does not twist. Well, it will work, but not if understood as continuous current.)
Old 04-21-2011, 04:26 AM   #46 (permalink)
Yes, voltage for HV servos, 8.4V regulated.
As side effect, it should transfer some of the heat out of the Jive to WR. Maybe.
The Jive have different type of regulator?
I know one issue, when the WR shut down because of overheating in very hot weather.
So it will be mounted on a spot where should be some airflow.
There is no airflow under the TDR canopy.
My logged max servo current spike was 8.5A and the HV servos will be these Hitecs:
http://hitecrcd.com/blog/
I plan connecting them first to Jive to log the current demands.
- TDSF in a box...
Old 04-21-2011, 06:20 AM   #47 (permalink)
No, switching type.
Two years ago I played with buck reg's for R/C application, 10A continuous (7x24) 12..14S. So I know about dissipation loss... Burned them regularly after a time in short circuit tests if the input voltage was above 12S. Gave up then, do not need that personally, was the time a bit too cost expensive for me to experiment with that only just for fun.
Old 04-21-2011, 01:46 PM   #48 (permalink)
But if you do not trust them at 12S-14S, then only solution is separate battery.
Not much space for that in TDR.
- TDSF in a box...
Old 04-21-2011, 08:33 PM   #49 (permalink)
Originally Posted by dl7uae View Post
@beans07
Tom
Thanks Tom I went by the light. I will put an order.
Synergy E7 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L
beans07 is offline        Reply With Quote Quick reply to this message
Old 04-22-2011, 06:32 AM   #50 (permalink)
Who is "them", WR?
I do not have any experience with WR, so I have no opinion.
@beans07
Meanwhile I asked Lindinger if the yellow light means "out of stock". Yes, it does.
But "Der-Schweighofer" seems to have in stock and speaks also English: http://www.der-schweighofer.at/artik...ve_datenlogger
Tom
Old 04-22-2011, 08:05 AM   #51 (permalink)
Them...
If i understood right, the BEC in Jive and WR is the same type, switching regulator.
WR is most favorite and reliable brand, definitely better then Castle BEC.
WR Super BEC is about 1/3 size of Jive, so i think (and hope) it is built to the specs.
- TDSF in a box...
Old 04-23-2011, 07:07 PM   #52 (permalink)
We have a new configurator JLC4 (version 4.0.0.4), One-for-All, JLog 1 2.4 ... 2.6[.n], JLog1 2.7[1], JLog2 3.1, the new 3.2 and 3.3 A/B ("JTX", homebrew JLog telemetry with XBees), as well as the Powercroco CMT JLog1 setup.
Although there is no version marker contained in CONFIG.txt and it wouldn't be possible to integrate that subsequently in the different firmware flashes, JLC4 is almost unerring in recognizing the version during the read-in of the config file. Only JLog2 3.2 can be misjudged as 3.1 if the type of alarm line #1 is "switched" (and not "interval" or "flash" or "Morse") and "telemetry" is not Unidisplay.
The challenge was a JLC for version 3.3 (D.I.Y. telemetry with XBee), but it was a wish of a user to have also one JLC for both, JLog1 and 2.
Voila.
Tom
Old 04-24-2011, 05:42 AM   #53 (permalink)
Voila.
Tom
Thanks Tom, it’s great to see the progress you’re making. Now if only Futaba can release that new telemetry TX!!
Heli G is offline        Reply With Quote Quick reply to this message
Old 04-24-2011, 06:41 AM   #54 (permalink)
Let's hope that the display, the appearance of sensor data and its setup, will be as flexible as the S-Bus itself is or will be...
Old 04-24-2011, 07:29 AM   #55 (permalink)
+1
Old 04-24-2011, 02:02 PM   #56 (permalink)
We have a issue, Tom.
Jeti telemetry.
Sometimes, when the system is powered up, the JetiBox mini will start in JLog2 configuration mode, showing incorrect settings. We can exit the config and after entering it again, everything is right.
Latest 3.2 firmware.
We will test tomorrow again, because we done only 2 flights due to high wind, but it happened in roughly 40% of power-ups.
Edit: capacity check against EagleTree also tomorrow, i hope.
- TDSF in a box...
Old 04-24-2011, 04:57 PM   #57 (permalink)
The "issue" is well-known, Petr, we already tried damping it by some provision in the firmware - but the chances for the logger are marginal. JLog cannot differentiate who it was sending acknowledge/keycode over the terminal bus.
It seems to be a bug in the firmware of the JETI Tx module. Keys, never depressed for the JLog, go through if connecting to Mx.
In most cases of that "issue" the logger landed in jbJLC - but sometimes in a strange manner that all values displayed are wrong.
The easiest way to avoid this is to have throttle a little above zero, at 1% for example.
Tom
Old 04-25-2011, 06:53 AM   #58 (permalink)
mAh...
Petr, a bit too late for your today tests, sorry.
Look here under mAhrs....
Tom
Old 04-25-2011, 10:57 AM   #59 (permalink)
Hi Tom, I am a little confused about the firmware versions. Currently running v3.2_3.29 and this works fine. I do not have any telemetry connected to it and purely use it as a logger. Should I follow the two step procedure to upgrade to 3.30?
VControl
Old hand at Planks
Peter
Vinger is online now        Reply With Quote Quick reply to this message
Old 04-25-2011, 11:25 AM   #60 (permalink)
Thanks for help Tom, we will try that throttle thing next weekend.
From this weekend we have this mAh tests with the previous firmware:
2055mAh from JLog2 discharged
2260mAh EagleTree discharged
2380mAh Tema SCD 300 charged back (no balancing).
Type of flying was easy flying with some soft 3D.
I can confirm the JLog captures higher current spikes, Eagle logged around 93A and JLog spike was 107A.
BTW what is difference between I-motor and I-motor/Int?
- TDSF in a box...
