Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 04-19-2012, 09:08 AM   #1 (permalink)
Default New upgrade oneway for x7
Looks like they chaged the oneway bearing to the sprag bearing type that xcell and 700n/e use.
http://www.rctw.net/thread-216784-1-1.html
benben is online now        Reply With Quote Quick reply to this message
Old 04-19-2012, 09:17 AM   #2 (permalink)
cant see any pictures can you upload them here?
xfactor6 is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 09:22 AM   #3 (permalink)
pictures
ID:	309397   Click image for larger version
ID:	309398   Click image for larger version
Old 04-19-2012, 09:27 AM   #4 (permalink)
cool no more c clip
Old 04-19-2012, 11:41 AM   #5 (permalink)
Cool, mines locked up twice now.
Stuff
Rob Cherry is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 12:15 PM   #6 (permalink)
Awesome, but how much is it gonna cost for people with the old design? My OWB has tons of drag right from the box.
vr360 is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 12:50 PM   #7 (permalink)
I'm guessing close to $70. Same as replacing both parts to the current one-way assembly. Maybe we can reuse the current hub/sleeve...
Stuff
Old 04-19-2012, 02:10 PM   #8 (permalink)
Whole new hub and sleeve from what I can tell.. I hope it's a little better with side to side play though. I suspect it will be.
Old 04-19-2012, 03:11 PM   #9 (permalink)
How soon will this be available. my buddies and mine lock up all the time
BEASTX
FUTABA
GAUI
IKON
SAB
Levitbe is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 03:12 PM   #10 (permalink)
The side to side play is determined by the top and bottom needle bearings that sandwich the OWB, they handle the side load. If they don't upgrade these, or change the inner sleeve diameter, we'll still have the same result.
It's currently not much, but I have noticed the main gear will chafe against the motor support brackets under heavy power loading, that's what the white dust is from.
I think that the current OWB lockup is due to the inner sleeve diameter being too small, this allows the OWB "tabs" to fold over too far and bind, thus locking up. If they'd increase the inner diameter, the "tabs" would have less tendency to fold over and bind, AND have less play.
Arm chair engineers.
Stuff
Old 04-19-2012, 03:22 PM   #11 (permalink)
Default one way
My one-way bearing his work perfectly from the start, no play, excellent freewheel. I'm lucky in that respect.
frito169 is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 07:29 PM   #12 (permalink)
+1 My one way bearing has been good as well.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 07:41 PM   #13 (permalink)
Is this why my main gear moves a little? I noticed it during spool up the other day, main gear had a wobble until blades came up to speed then the gear ran true. I came inside and tore it apart to see if there was anything loose, everything seemed fine. I repacked the ow but it still has a little movement.
Trex- 250, 450~Oxy4~Gaui X7
Magooch is offline        Reply With Quote Quick reply to this message
Old 04-22-2012, 06:38 PM   #14 (permalink)
How do you when it locks up, do you see/hear the motor being driven by the main gear when it spools down?
What's the implication for an auto-rotation landing? Deadly? If a lockup is on the cards, then it might be more risky practicing auto-rotations than just trying do it when I need to?
Harrow is offline        Reply With Quote Quick reply to this message
Old 04-22-2012, 07:46 PM   #15 (permalink)
Default autos
It would just make it a tiny bit tougher, If at all.
Old 04-22-2012, 08:20 PM   #16 (permalink)
So having to turn the motor is not slowing the head down much? Hang on, yours is working fine, how can you be sure?
Old 04-22-2012, 08:32 PM   #17 (permalink)
Default sure
On my whiplash the motor turns until the head speed is down to about 60 rpm's and It gives me no issues at all. Strange part is head spins very freely, with no drag if from a stand still then spinning the blades.
Old 04-22-2012, 11:05 PM   #18 (permalink)
Interesting, it's behaving like a centrifugal clutch.
Old 04-23-2012, 08:23 AM   #19 (permalink)
I flew mine 15-20 flights after it locked up. It spools down a little quicker, that's all. If you're comfortable doing autos in general then you'd be fine. I found I just had to give a little more reverse collective to keep the HS up while flaring.
Stuff
Old 04-23-2012, 02:15 PM   #20 (permalink)
When will this be available?
irishmatt18 is offline        Reply With Quote Quick reply to this message
