Old 07-07-2015, 08:44 AM   #61 (permalink)
Originally Posted by krazycarl View Post
Do i use the subtrim in radio to center the servo horn on my rudder servo or do I use the center setting in the gpro software to center my servo horn. ?
Use the Gpro software. Good luck!
dja2424
dja2424 is offline        Reply With Quote Quick reply to this message
Old 07-07-2015, 08:49 AM   #62 (permalink)
Once you have set the endpoints of the various servos travel on the first screen of the Gpro setup all future adjustments are via the Gpro and not the radio, some see this as a negative cos its easier to do tweaks directly on your radio but if you have the BT permanently installed its easy enough!
Tiaanj is offline        Reply With Quote Quick reply to this message
Old 09-18-2015, 05:43 AM   #63 (permalink)
Default Tail twitch GPRO align problems
Hi guys
It has been a while since I started this thread and been here. There is some confusion regarding bounce vs twitch. The problem I had was the twitch, as per my original post and video.
Well I sold the GPROs (3) last year and life went back to normal with the AR7200s - nice and smooth normal
And then a new align 700 Heli came last month via the post and I said - maybe they fixed it? Give it a try! Waste of time. Same problem. Also a friend just got one and he set it up on his JR radio - we tested it yesterday - same thing.
Come on Align - fix the problem!
And while your at it how about doing something about the tail Hum on the 700s - that's serious! Time to come out of hiding and address your customers complaints!
You can tell I am frustrated . I suspect anyway it is apparent.
Tower is offline        Reply With Quote Quick reply to this message
Old 09-18-2015, 05:49 AM   #64 (permalink)
Default GPRO tail twitch bug
Originally Posted by dksia View Post
I have 8 GPros installed and flying. I have also run a bunch of experiments on my bench. I have seen this behavior on the bench. It is exaggerared if you have low gains, somewhere below about 30% at the TX. Based on my experiments and seeing the helis fly perfectly fine, I believe what people are referring to as a "bug" is nothing more than seeing odd behavior in a heading hold gyro when it is sitting stationary and having no reason to do anything, as there is no motion to prevent or to make happen.
Having been able to see this behavior on the bench, and then seeing that same controller perform flawlessly flight after flight tells me the behavior on the bench is not an indication of anything being wrong, it is how the heading hold gyro behaves when sensing no motion.
Hover in normal mode, adjust the tail linkage for a hover with no nose left or right yaw. Land. Reset the two travel limits. Then, back in HH mode, work with the left and right stop parameters, and the P and I gains as needed. Little additional adjustnent is needed.
Sorry disagree - I agree some are able to adjust the gain and get rid of it. I have seen this with 5 different GPROs on the bench with 3 brands of radios. Some see it in the air and some do not. Some can get rid of it, and some cannot. I can tell you that this was reported directly to Align and was supposed to be on their fix list. They decided to become a UAV company instead.
Old 05-30-2016, 11:41 AM   #65 (permalink)
Default Its just a setting, not a bug.
Reducing the P gain in the tail setting in the software takes away the twitch completely. I am running 4 perfect twitch free GPRO now.
Allan
TREX 250 PRO,Talon15, GPRO, Zeal ----TREX 500 EFL PRO, GPRO, RAILS ----2x TREX 450PRO V2, 1xGPRO&1xBRAIN, Talon35, RAIL , Zeal ---- SAVOX powered TREX500 EFL in Roban scale UH1-N ---- TREX 600 EFL PRO, GPRO, RAILS ---- DX9 ----
TR450ZS is offline        Reply With Quote Quick reply to this message
Old 12-28-2016, 07:51 PM   #66 (permalink)
I know this is an old thread but if it helps anyone..
I bought a used bird that was barely flyable, changed every bearing, feathering and main shafts, tail shaft and the tail control link. Went through in detail and set it up to perfection. Would hover hands free but right rudder was twitchy and sometimes it would return to where it started.
I tightened the tail servo rod 3 full turns and reset the limits as described earlier in this thread. It's perfect now. No twitch, no return to prev HH.
Thanks!
StampedTees is offline        Reply With Quote Quick reply to this message
Old 12-29-2016, 12:07 AM   #67 (permalink)
Yup. Nothing wrong with GPRO.
Allan
Tags
align gpro rudder twitch, gpro tail wag, tail twitch gpro
