10-28-2010, 03:37 PM | #1 (permalink) |
bad vibration during spool up and down
I just built my 500 3g and am experiencing a bad vibration about halfway through spool up and spool down. it only lasts for a second or two and then goes away. it does not vibrate during flight at all. Any suggestions?
T-Rex 5003g T-Rex 700e 3g |
10-28-2010, 06:29 PM | #2 (permalink) |
Check blade tension, if there a bit too tight in the grips then you'll be getting some vibrations until they swing into place . Also re-check blade balance both main blades and tail.
TBS Discovery / Nemesis 240 / Park Zone Sport Cub / Taranis X9D / Black Pearl 7' FPV Monitor / iCharger 206-B / Sony 2.8 FPV camera / GoPro Hero 3 Silver + |
10-28-2010, 07:35 PM | #3 (permalink) |
Is it a vibration or a shake?
If it is a shake it is pretty normal, and is often caused by to tight blades. If you tilt your heli to the side the main blades should stay straight but you should be able to "shake" them out of position. Pete |
10-28-2010, 08:41 PM | #4 (permalink) |
Check your feather shaft and main shaft. Even thought it looks straight it might not be.
10-29-2010, 01:03 AM | #5 (permalink) |
I guess it is more of a shake than a vibration.
10-29-2010, 03:21 AM | #6 (permalink) |
Yea could be main shaft if it's on spool down and spool up... BUT, I recently installed a 3G into my 500 and saw the same thing happening, however a couple of guys at my field said this is fairly normal for a 3G FBL setup? I've just now put a new main shaft on since I bought it used but haven't had the chance to fly it yet
-Goblin 700: Crashed but re-building, still needing electronics -Goblin 630: CC Ice 120HV, vBar |
10-29-2010, 06:01 AM | #7 (permalink) | |
If it is the main shaft I believe it might not stop that quick. Last edited by im4711; 10-29-2010 at 06:01 AM.. Reason: spelling |
10-29-2010, 07:42 AM | #8 (permalink) |
mine shakes a bit when the blades are spinning at low RPM if its not shaking when the blades are at full speed you are probably ok depending on how bad the shake is..
----------------------------------------------------------------- Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more. |
10-29-2010, 08:55 AM | #9 (permalink) |
Mine will shake the odd time halfway during spool down if the collective is in just the right spot. Giving a little collective one way or the other usually smooths it out immediately. It's only happened 5 or 6 times all summer and just once since I went FBL last month.
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo #nodroneshere - 104 |
10-29-2010, 10:09 AM | #10 (permalink) |
i should mention that my friends 450 does the same thing. he does like tight blades tho..
10-29-2010, 07:24 PM | #11 (permalink) |
IMO, barring any crashes and any bent shafts or other equipment on the heli, the main and/or tail grips are too tight on the blades.
At the precipice, we change! Team GrandRC |
