| 450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I love flying my mcpx. I love the flybarless setup so much that I was thinking about switching one of my 450s over to flybarless. What setup can I get on a budget? The heli I would be converting is all Align and Tarot. Align motor/esc, GP780, skids, and tail boom. Tarot head, tail, frame, and cano. I was looking at either the Tarot flybarless controller, HK controller (which I think is about the same as the Tarot), or the CopterX. For the head I was thinking about going with the Tarot upgrade. Which wide chord blades could I get that wouldn't cost me $50. I fly Pro3D blades right now (can't beat the price). Thanks guys.
O ya, the head, tail and frame are all 450 sport.
#3 |
tarot head, with tarot zyx, no doubt.
honey bee king II |
#4 |
What about hobbymate FBL unit? I heard it is a clone of the beastx, any good? With the DFC head total is about $100 or a few bucks more.
#5 |
i never looked up the hobbymate. what is dfc?.
#6 |
DFC is Aligns "Low Profile" Flybar less head system.
I am converting my 450 Pro to this. http://www.helifreak.com/showthread.php?t=434567&page=2 See post 13 and on. The part number is HT45162T for a complete head conversion Then you'll need some kind of brain. BeastX, V-bar, 3GX. ZYX... Rene'
Align T-Rex 450 Pro DFC BeastX, trainer.- Align T-Rex 600E Pro. SAB Goblin 700 - Maxed out Blade mCP X V.2. 4x Nine Eagles Solo Pro's. Spectrum DX8. x3mheli.dk Any landing where you only need to bend once, to pick up your bird, was a good one... |
#7 |
so all i need is either the align or tarot conversion kit and a tarot zyx? what about blades? i want to use the dfc
#8 |
A couple more questions. Again, do I need wide blades, or can I use regular blades? If I get either the Align or Tarot DFC conversion kits, do I need anything else? Can I use the swash from my Tarot sport head? Thanks guys.
#9 |
use your regular FB blades, works fine
the dfc head is $$$ and luxuary, and I dont think you will be able to tell the difference, when you fly. I dont run DFC on my 450s, or 500, I do run it on the 700 though. Ideally you need a dedicated $$$ swash for the DFC, so... just get the regular cheap clone tarot head, non DFC. the hobbymate is both more expensive, and unproven than the tarot XYZ
honey bee king II |
#10 |
tarot head and a zyx-s gyro or the hobbymate fbl (60.00) beast-x clone
ZYX-S can use a sat and no receiver for a 450(ONLY) the hobbymate is a v1 beast-x clone and you will need a receiver for that unit
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
#11 |
dont you need digital servos for fbl also?
#12 |
I believe many FBL systems can use analog servos. ZYX can, as an example. But I've heard that the analogs don't perform as well for FBL as digital. They don't center as well, apparently, and there are other factors as well, I think. I believe analogs also don't update as frequently (70 Hz vs, say, 250 Hz for digital).
Tarot 450 Pro FBL. ZYX, Blade 450 X tail grips, 6S, Ice Lite 50, DS92A+ cyclics, DS215MG tail. BL Blade mCP X (HP05S, XP7A, dual coreless tail), mSR (sold), DX6i |
#13 |
i got the zyx s and tarot non dfc head. So can i use the satt from my spektrum rx and just run the servos directly to the gyro? Why only on a 450?
#14 |
Can someone please explain how to use my Tarot ZYX-S with my Spektrum sattelite? Do I need the receiver still, or the sattelite? I know I need the cable for the spektrum sattelite.
