Old 04-23-2010, 05:45 AM   #21 (permalink)
Originally Posted by tribe3 View Post
Hey Jroth; be sure to secure the connector of the main sensor. There are quite some vibes on the boom. I use double shrink tube overlapped but you can hot glue it or whatever suits you better. Just make sure it won't disconnect during flight.
Bests
I will be testing that heli on sunday, need area free from trees etc.
Jroth is offline        Reply With Quote Quick reply to this message
Old 04-25-2010, 06:36 AM   #22 (permalink)
Default Programming CP2
On menu Preflight and by the question "All./Elev. are CENTERED" is the right stick (mode 2) already centered => ENTER
=> On Screen:
Pitch= -22 UP
Roll=- 24 DN
What is the meaning of the value above? Is the value correct when the swash/heli is level?
Old 04-25-2010, 09:56 AM   #23 (permalink)
You are good to go, message is normal
My only suggestion to you would be if you can...move the main sensor out of the "Kill Zone" of a blade strike
JR9303 / JR9503 / Futaba10CHP
Old 04-25-2010, 04:24 PM   #24 (permalink)
Guys, little on the side of this topic.
The CPII paid itself about two times today.
Best $ 200 Ive spent on this hobby.
Im using the AUX2 as ON/OFF/PANIC.
The CPII is great, I didnt expect so much.
I "made mistakes" on purpose and then used the 'Panic' to save the heli.
I have my main sensor also on the kill zone, dont know if I should move it. Forward will be too close to the vertical sensor and canopy, backwards will be too close to the tail rotor and might be affected by it (Im on a 450-size heli).
I can not put it under, my tail rotor push rod is too close.
Technically, works like a dream, but the Kill Zone thing bothers me a bit.
Manny
MA Furion 450, Mikado Mini V-Bar, Scorpion 2221-8, 13T, CC Ice Lite 75A, --- Walkera 60#B, Stock Motor, Stock Servos, Stock Blades and Futaba GY520 (yes!) Spektrum DX7se.
And, CRAVING for a HENSELEIT TDR!!!!
gobase is offline        Reply With Quote Quick reply to this message
Old 04-25-2010, 07:25 PM   #25 (permalink)
My CP2 default setting:
PREFERENCES
Pitch Gain >70%
Roll Gain >50%
Stick Priority >100%
Max Servo travel limit >100%
Gyro Output CH4 >None
Disarm flight mode to >LEVEL
Enable Emergency Recovery >Y
Flight Mode Setup
Off Remote = 0%
AutoTrim ? 6deg
F.mode 1 Rm= 100%
>Level Flight
For Beginner is the setting above usable?
Is this correct, when I set "Gyro Output CH4 = 64%" as before using cp2 the Gyro (HH) was set to 64%.
HK450TT + CP2, GP750+DS520, 3x TowerPro MG90, TowerPro Motor+ESC, Stock Blade.
Old 04-25-2010, 08:02 PM   #26 (permalink)
You are good to go
Blade400
pril250 is offline        Reply With Quote Quick reply to this message
Old 04-25-2010, 08:16 PM   #27 (permalink)
Your Gyro Gain might be too high, try 38% to start.
vanguy is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 09:14 AM   #28 (permalink)
I'm glad you like it! I felt the same way when I saw it working; I hadn't expected it would be so effective!
I already broke a main sensor in the kill zone... I was thinking under the landing gear somehow but I'm too lazy to do it at the moment.
Bests
tribe3 is offline        Reply With Quote Quick reply to this message
Old 04-26-2010, 04:44 PM   #29 (permalink)
What is about "None" by "Gyro Output CH4 >None" ?
Old 04-26-2010, 04:55 PM   #30 (permalink)
If you attached the yellow gyro gain wire into CP2, this means CP2 has taken over the duty of setting the gyro gain, you need to input a value here "gyro Output Ch4> 38% or around there. You gyro gain is now set using your hand held unit.
