Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters
Other Makes and Models Helicopters Other makes and model Helicopters
Old 03-08-2013, 11:27 AM   #41 (permalink)
Default Pictures repaired... again
dont know whats up here.
Logo 480 XXtreme, Logo 550SX, Logo 690SX, Logo 800 XXtreme, TDR, Minicopter Diabolo 550, Minicopter Triabolo, Goblin 500, Goblin 700, Goblin 770, KDS Agile 5.5, Voodoo 600, Voodoo 400, HD Cell 500, Thunder Tiger E700
taosgraveyard is offline        Reply With Quote Quick reply to this message
Old 03-08-2013, 11:38 AM   #42 (permalink)
Default Installing intermediate shaft and main gear
the intermediate shaft parts
like this:
needs a grub screw
intermediate shaft drops in here
motor belt goes over shaft
main shaft, assembled main gear, jesus bolt and some shims
DO NOT DO IT THIS WAY... you'll never get it to go in
DO NOT pressemble main gear and shaft
because the main gear will never slip into this slot in the side frame as the end of the main shaft slides on to the lower main bearing plate
instead leave the jesus bolt out
and it will all be able to drop in. then line up the jesus bolt hole
and install and tighten the jesus bolt
Old 03-08-2013, 11:41 AM   #43 (permalink)
Default Upper bearing plate.
this side up
[IMG]http://i592.photobucket.com/albums/tt3/ravenpath/voodoo/installing%20main%20gear%20and%20top%20main%20bear ing%20plate/2013-03-03144827.jpg[/IMG
Old 03-08-2013, 11:45 AM   #44 (permalink)
Default motor mount
has an integrated counter bearing
[IMG]http://i592.photobucket.com/albums/tt3/ravenpath/voodoo/installing%20main%20gear%20and%20top%20main%20bear ing%20plate/2013-03-03150050.jpg[/IMG
ummmm. oh-oh
Checked with Stephan, and as i suspected, a scorpion with a 6mm shaft does not need a counter bearing. The bearings and shaft are larger inside the motor than on a Pyro. I'll need to remove it then make sure the clip on the shaft of the scorpion at the motor's base clears the hole where the counterbearing was.
Old 03-12-2013, 11:12 PM   #45 (permalink)
Default Acrobat Voodoo 600 build thread
Your build sequence is magnificent and I am sure it will be of great help to Ahmad and me in a few weeks. I'll be using the 4225 on 10S as well so these tips on mounting it are welcome. I got the motor and lipos during my vacation, as well as the BLS255, miniV and some Edge 603SE blades. I bet the lower ESC plate position is to get proper CG on 6S.
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 12:11 AM   #46 (permalink)
Thanks for the kind words...
Will be posting more tomorrow
Built the head, I do things a little out of sequence, preferring to put the landing gear on last. For me it makes it lower on the bench, and easier to work on and set up
I also like to build the tail after building the rotor head and installing the electronics and setting up the head so that's the order I am going to use in this thread instead of the order in the manual, which by the way is excellent, as one would expect from a German boutique helicopter company
Think you are right about the optional ESC position
Old 03-13-2013, 11:22 AM   #47 (permalink)
Default Motor Mount
As you can see in the next photo, for a Scorpion 4225.610 motor, the mount has to be modified
I removed the counter bearing and as you can see there is a lip inside the hole for the bearing against which the counter bearing seats.
This lip causes another problem. There isn' t enough clearance for the retaining clip to clear the lip shown in the previous photo The motor can turn, but the clip is caught against tip; the clip stays in one position as the motors can turns.
3 minutes with a dremel tool spinning a steel bit - about 1/8" in diameter and spec'd for grinding aluminum - did the trick
Now, the motor and mount are fastened to the frame side
And the belt is slipped over the motor pulley. I intentionally omitted documenting the installing of the motor pulley, I haven't ground a flat on the motor shaft for the grub screw to seat against, so its all coming out after I have the other frame side on and have decided the motor pulley is in the right position , so that the motor belt is centered on the pulley on the intermediate shaft. So i am saving that part for later.
Old 03-13-2013, 11:26 AM   #48 (permalink)
Default FInally the other frame side is attached
starting to look like a helicopter!
Old 03-13-2013, 11:44 AM   #49 (permalink)
Default Belaying the aileron servo wires
The two aileron servo wire need to be belayed so they don't get caught in the drive train
the servo wires are first routed through the lower bearing block
then a wire tie is fastened around both
and the tie is cinched tight,
take care that the wires wont rub on the intermediate shaft
Old 03-13-2013, 11:51 AM   #50 (permalink)
Default Upper Canopy Mounting Bolts
Old 03-13-2013, 11:52 AM   #51 (permalink)
Default Re: Acrobat Voodoo 600 build thread
You are so going to love how she flies
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 11:57 AM   #52 (permalink)
Default Front Canopy Mount and Skid Frame Bridges
http://i592.photobucket.com/albums/t...3-11184030.jpg
Old 03-13-2013, 12:05 PM   #53 (permalink)
Default A Departure
IN the manual, the next step is installing the landing gear, and after that is the section on building the tail.
I have gotten in the habit of doing things a little differently. I am going to do things in t his order
1. install and level the swashplate
2. build and install the head
3. install the Speed Controller
4. Install the FBL unit
5. Install a Spektrum TM1000 telemetry unit
6. wire the helicopter
7. partially setup the FBL unit, except for the tail settings
then built the tail, and THEN finally add the landing gear. I find that doing it my way means that I can move the heli around easier (without the tail) while wiring it , and without the landing gear it sits lower on the bench so its easier to work on from a sitting (ok, slouching) position.
So, soon Ill add the sections about installing the swashplate and head.
soon: I will post the section
Old 03-13-2013, 03:38 PM   #54 (permalink)
My water is mouthing... I mean my mouth is watering! Gorgeous!
Marcos
Old 03-13-2013, 04:20 PM   #55 (permalink)
I have another tip for you. When placing your next order order this parts. They are from the acrobat and the sleeving you have left from the lipo mounters. It will make sure your servoarms are not touching your canopy.
Old 03-13-2013, 04:22 PM   #56 (permalink)
Picture 2
Maybe I have the part numbers in my email.
Old 03-13-2013, 05:10 PM   #57 (permalink)
Had some left over and tossed it...,
Thanks for the tip, a good one too.
I may have something around here that will work, but I am definitely interested I those part numbers,
Old 03-17-2013, 10:31 AM   #58 (permalink)
Default Swashplate
That is not an optical illusion. The aileron servo links from servo to swash are canted to the rear. so when the servo is centered it must be at 90" to the link rod. IF you are using Vbar, and if you have the Pro version of the firmware installed, you'll be able to level the swash at 0, min and max pitch. Unfortunately, I am using a Helicommand HC3-SX, and will only be able to level the swash at 0 pitch. I suppose this means that at max pitch, the swash will tilt forward ever so slightly, and will tilt a little bit back at min pitch. I doubt i will notice this very much, and with self level on, the FBL unit should correct for the variation.
Also, I am using JR Servos, and JR servo wheels have a larger OD than Futaba. I can see that the wheel will have to be trimmed a bit so not to interver with the ball link at max and min pitch.
Like the Minocopter Diabolo, a swash height and leveling tool is supplied
I hooked up the HC and will now set the swash height
I like using that tool for setting the height, but I dfind that when I use a swash leveler I don't get a reall accurate level using just the tool under the swash. I didn't have a swashplate leveling tool for the Voodoo, but was able to make one from a Synergy E7 swashplate leveling tool from FBLRotors.com. I had to cut notches in the tool to clear the Voodoo swashplate
I used a metal ruler and recentered the servos. The servo arm must be at a right angle to the link rod. Its easy to eyball it when restong the end of the ruler on the screws in the servo wheel.
Then i leveled the swashplate using the FLBRotors Synergy E7 tool.
Next I'll built the head.
Old 03-17-2013, 10:32 AM   #59 (permalink)
Default The Head
next, the FBL Head.
A mandrel is supplied for installing and removing the blade holder bearings. THere were already installed in my kit.
Old 03-18-2013, 10:30 AM   #60 (permalink)
beautiful work and illustarions , Marcos and my kits have been shipped 3 days ago, the wait is almost over and your outstanding build will be soooooo handy. Thanks buddy.
_____________
abanihani is offline        Reply With Quote Quick reply to this message
