Old 06-24-2013, 05:44 PM   #1 (permalink)
Default B400 fbl question
Ok so I think I know the answer to my own question from reading back into the forums, but I just want to make sure I know what I'm getting in to. I have a stock blade 400 aside from a 35 amp esc out of a 4503d, and a ds76t tail servo. I would like to do the good ol' tarot/zyx conversion and wanted to make sure that it was a drop in replacement like the 4503d is(aside from bigger ball ends) and if my stock servos will work. Thanks in advance!
blade MCX, 120SR, MCPX V2, 4503D, 5003D, Dx6i
adanick2 is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 07:38 PM   #2 (permalink)
I too am in the process of making this switch. If I'm correct you will also need to cut about 2 mm off the top of the main shaft.
skiiermike is offline        Reply With Quote Quick reply to this message
Old 06-24-2013, 08:14 PM   #3 (permalink)
Oh yeah, I was going to ask about that too thanks.
Old 06-25-2013, 07:22 AM   #4 (permalink)
If you use one of these 450FL rotor heads from CNC no modification to the main shaft is required or needed. I use one and its a direct drop on just had to change the balls on the swash to 450 size. As far as the servos I couldn't tell you. I changed mine to Hitec 5055MG's.
http://www.cnchelicopter.com/servlet...ead/Categories
Rustyfan21 is offline        Reply With Quote Quick reply to this message
Old 06-30-2013, 04:29 PM   #5 (permalink)
Drop in replacement that works great:
Blade BLH4399 Aluminum Fly-Bar-Less/Flybarless Conversion Set: for Blade 450 3D
Pull the old shaft and head out and replace with this and set it up with your Beast or what ever you like.
doctorbarn is offline        Reply With Quote Quick reply to this message
Old 07-07-2013, 06:31 PM   #6 (permalink)
This, got mine from ampdraw for $62. Direct drop in, nothing special needed.
Doc_Hurley is offline        Reply With Quote Quick reply to this message
Old 07-07-2013, 08:28 PM   #7 (permalink)
Ok thanks, are the blade grips the same as original meaning i would still have to use shims if i use carbon fiber or fiberglass(non "blade" blades)?
Old 07-07-2013, 10:46 PM   #8 (permalink)
you could use stock servos but.i.wouldnt, i do not trust them. get you some hs65s.
follow my thread in the b450 section all info need is there.
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 07-08-2013, 12:27 PM   #9 (permalink)
Oh I've been there already..... Many times. Thanks for the advise, I'll look into those servos you mentioned.
Old 07-08-2013, 12:32 PM   #10 (permalink)
Oh thanks, we converted my fathers old b400 he enjoys it so much more now..made it.fly so much better
Old 07-08-2013, 01:24 PM   #11 (permalink)
I am in the process of doing the exact same thing you are asking about Nick. I have all my parts together just waiting for a few free hours to get everything done. I have the Tarot 450 FBL head that Rusty linked you too and it is a drop in replacement, super easy. I leveled my swashplate with the new head attached and am waiting to get the wiring done. I bought the Tarot ZYX gyro and a castle creations BEC (using the stock ESC) to get everything working right. Bee posted a wiring diagram in my thread "Weird Rotation" if you need a diagram on how to get the ZYX wired (though it will be slightly different because of my BEC). I actually had some spare 400 ball links. So I switched those out with the 450 ones included with the tarot head so half my swash balls are 400 and half 450. I hope this doesn't cause any problems I just happened to have two spare 450 swashplate balls around and didn't want to order more. I have a new set of blades on the way, a new canopy, Trex 500 canopy mounts, and a hand full of other things coming this week to get everything done. I'll post some pictures this week. Best of luck to you.
spfdheli is offline        Reply With Quote Quick reply to this message
Old 07-08-2013, 09:00 PM   #12 (permalink)
Thanks, good luck to you too! I know i'll need it. I'm just waiting to get paid from my little side(hobby money) job and i'll be ordering me some parts, can't wait!
Old 07-08-2013, 09:18 PM   #13 (permalink)
Oh its simple. I think I need to start having people ship me there helis and all the goodies and i do the install and tweaking then send it back, for a fee of course
Old 03-14-2015, 12:11 PM   #14 (permalink)
So the mainshaft that comes with the BLH4399 kit works on the B400?
I compared the 2 mainshafts and thought I would have to modify the B400 shaft.
1340 is offline        Reply With Quote Quick reply to this message
Old 03-14-2015, 12:13 PM   #15 (permalink)
Feel like such a Homer. Just realized I joined a 2 year old thread!
Old 03-16-2015, 03:32 AM   #16 (permalink)
It happens, especially when you see exactly the question you're dealing with.
I'm running 450x parts in my b400 conversion. I didn't see this kit available when I was doing it. I would have saved a little had I gone that way. But it is nice now to share head parts between my 450x and b400.
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis
gstoneberg is offline        Reply With Quote Quick reply to this message
Old 04-09-2015, 04:45 PM   #17 (permalink)
So was this kit a direct drop in?
Did you modify the main shaft or anything?
Thanks HeliFreak's for helping me build and learn to fly
Align T-Rex 250, 450 V2, 500(DFC), 600NP(DFC), 700 Dominator
DX7
extremeshannon is offline        Reply With Quote Quick reply to this message
Old 04-09-2015, 07:12 PM   #18 (permalink)
The b450 and b400 shafts are a little longer than the 450x shaft so I switched to the 450x shaft when I did the conversion.
Old 04-10-2015, 12:29 PM   #19 (permalink)
Thanks for the info
Shannon
DX7
