Old 08-04-2012, 05:22 AM   #21 (permalink)
OP here:
Lots of good stuff guys, appreciate it. Here's a bit more info for some of you that were wondering:
-Swash is leveled. Fusion has rigging pins to lock the bell cranks & swash when setting 90 deg. on the servos. On the bench, swash moves all the way up / down leveled.
-Heli hovers hands off with no drifting backwards.
-tracking dead on.
I'll read the MB manual again as some of you have suggested, re-check my servos and make sure I'm not short on travel on 1 of them...
AMA #976001
HELIS: TREX 500 (6s), Trex 600 ESP (12S) & Trex 550 (12S): ALL FBL
PLANKS: Hangar 9 Pulse 60, Alpha 40 & Great Planes Revolver
nieves50 is offline        Reply With Quote Quick reply to this message
Old 08-04-2012, 06:53 AM   #22 (permalink)
Originally Posted by DominicD View Post
When it doesn't climb out straight ... because the swash isn't level. Parameter A is for guys who didn't level the swash properly. What the OP is describing is the swash is tilting NOT that the heli isn't climbing straight.
That is a typical misunderstanding that probably comes from the time we all had flybarred helis. Having the swash level at step G does not guarantee you will have straight climb outs (even assuming the CoG and everything else is correct). The BeastX is in full control of the swashplate behavior and we can't know how it moves the swashplate on climbouts. Having the swashplate level on step G does not necessarily mean that BeastX will keep it level on climbouts with no cyclic input. It all depends on its internal algorithms which are in full control of the swash.
I for example had a perfectly level swshplate in step G (checked with the leveling tool) but still had to trim the parameter A six clicks left to make the climbouts straight. Yes, it resulted in a tilted swashplate in step G but hey, this is what the manual says and if the heli is happy with this setup we should not assume this is wrong. Otherwise the BeastX developers wouldn't have written the instructions for parameter A the way they did.
VolodymyrK is offline        Reply With Quote Quick reply to this message
Old 08-04-2012, 07:28 AM   #23 (permalink)
I think we are agreed then that Option A is the 1st step for nieves50 to try 1st...https://www.helifreak.com/images/smi...on_redface.gif
midnightx1 is offline        Reply With Quote Quick reply to this message
Old 08-04-2012, 08:09 AM   #24 (permalink)
The Capi
Well of the over 20 BX setups Ive been a part of this year I have NEVER found a need to adjust parameter A.
Old 08-04-2012, 12:49 PM   #25 (permalink)
I've never had to adjust Parameter A, either. There was a discussion about Parameter A last month where Sutty did a great test with it.
Scott
KBDD Team Pilot ):>
Old 08-05-2012, 08:04 AM   #26 (permalink)
Parameter A is the one to play with here, it's there to be used, normally you will not need to play with it very much, and remember that an helicopter will never hover hand free with a level swashplate because of tail thrust & other factor.
With more advanced Flybarless controller we have ''tail drag compensation'' adjustment for that problem, this tilt the swash forward to compensate for the drag of the tail on straight climb out.
Tail inertia is another one in aggressive pitch move, specially on large 700 + size, but we live with it.
T-rex 600E pro
T-rex 450L
Coaxial Collective Pitch 550
martin_ is offline        Reply With Quote Quick reply to this message
Old 08-12-2012, 02:30 PM   #27 (permalink)
OP here.....
Man!...last week was a very long one...Anyway, today was able to finally test it. Parameter A did not fix the issue. Seems POT 1 need more adjustment (towards + side)...Was unable to test more since the "plankers" like to hog the field and today they came in full force..
Should be able to check it out Wednesday after work..
Thanks for all the help and will keep you posted.
AMA #976001
Old 08-20-2012, 08:59 AM   #28 (permalink)
Confirmed yesterday:
Adjusting POT 1 towards the positive side took care of the tilting while punching collective! (2 tick marks)..
Thanks for all the input guys
AMA #976001
Old 08-20-2012, 09:31 AM   #29 (permalink)
The Capi
np.
