Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
11-27-2016, 02:07 PM | #1 (permalink) |
Telemetry--most info/fewest sensors
What is the current state of telemetry info from ESC to radio, without separate (wired) sensors everywhere?
IE-- 1. besides Kontronik Telme Mikado (with Neo/VControl), does Telme system work the same with Futaba/Jeti/Spektrum/Taranis radios, and does it matter what FBL is used? 2. Do Jeti or Taranis (Horus) work similarly with any particular ESC, or do they require several separate sensors to provide the same info as Telme? Thanks--just checking |
11-27-2016, 02:14 PM | #2 (permalink) |
delete
11-27-2016, 02:18 PM | #3 (permalink) |
VControl Evo (Neo/Evo) Goblin Buddy, Gaui X3, Kraken 580, Raw 580, Raw 580n, Synergy N7, Kraken 700, Goblin 700 Sport |
11-27-2016, 02:24 PM | #4 (permalink) |
Graupner has telemetry ESCs, but telemetry only works with Graupner receivers without something like a JLog.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
11-27-2016, 02:48 PM | #5 (permalink) |
Latest scorpion ESC speaks VControl telemetry without sensors.
However, and this goes for a lot of ESCs, the current value from a jlog etc may not be as accurate as a separate sensor. Not all ESC, in some cases not even very expensive ones include a current sensor and instead calculate the value for the amp draw. Kosmik do include the hardware, are calibrated and are very accurate.
Logo 700 | Trex 700X | Logo 600 | Logo 690SX | Gaui R5 | V-Bar Control V-Bar Control flight analyzer (Win/OSX/Linux) - Latest release v5.0.0 July 5 - 2017 Sleipnir timing system - How fast can you fly? Only the ground is the limit! |
11-27-2016, 03:29 PM | #6 (permalink) |
One of the most versatile telemetry sensor units I've seen is the Unisens-E from Germany. It provides measurements of current/capacity, main voltage, receiver voltage, barometric altitude, and RPM (wire directly from one of the motor phases). It speaks the following telemetry languages:
11-27-2016, 04:20 PM | #7 (permalink) | |
http://www.kontronik.com/en/products...ler/telme.html
Robert Montee | Team Futaba USA | Team Kontronik USA | TellARotor RC Podcast | Citizen 13 |
11-28-2016, 02:25 AM | #8 (permalink) | |
On the down-side you have to connect it in-line with your main battery pack and add a small wire touching one of the motor wires (if you want RPM). On the up side, you have many good sensors in a tiny unit that probably costs less than a single TelMe and is compatible with many different radios.
Compass 6HVU, XLPower 520, Chase 380 |
11-28-2016, 06:02 AM | #9 (permalink) |
I use Unisens-e on my 700s with my JR XG14. It works awesome once you figure out how to convert figure it which takes translating from German to English in Google.
I now fly with mah consumption which I love because I can go from a low rpm 8min flight to a high rpm 3.5 min flight and never over discharge my packs like with a timer and get max flight time.
Synergy 766, Goblin 700C, Synergy E7 SE, Logo 700, Align 700x, Logo 550sx, Goblin 500, Oxy3 TE, BK Servos, Spartan VX1e, TX - JR XG14 Xbus |
11-28-2016, 08:10 AM | #10 (permalink) |
Take a look at Jlog, it talks to most ESC brands and supports all the major radios for telemetry. It's the most universal option out there at the moment I think.
Helis: Oxy 4 Max (day + night), Gaui X3 380, Oxy2 FE 215, Oxy2 Sport 190 Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2 Sims: RealFlight & AccuRC |
11-28-2016, 10:11 AM | #11 (permalink) | |
A JLog unit talks all the telemetry languages except Mikado VBC. It is the best setup all around. TelMe sensors are very limited. They don't talk to my Jive 100LV, or Power Jive 120HV, and they are purchased with a separate unit per protocol. So if you are using Futaba or JR etc.. and switch to Jeti later you don't need to buy new hardware. You just modify the configuration of the JLog.
Mark Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc.... |
11-28-2016, 10:33 AM | #12 (permalink) |
If you want ESC telemetry and just about anything else, the combination of the Unisens-E and the JLog would cut way down on the number of sensors needed.
11-28-2016, 01:40 PM | #13 (permalink) |
I think you mean either-or. The UniSens can talk to just about anything without jlog anyway, and I think there is some add-on if you want onboard logging.
11-28-2016, 01:44 PM | #14 (permalink) | |
If you're running a separate BEC from main power, the ESC current measurements won't take BEC current draw into account. The Unisens-E can give you overall current draw from the flight pack(s). That's not to say that there wouldn't be some overlap, but neither is a perfect solution by itself.
02-23-2017, 01:38 PM | #15 (permalink) | |
02-23-2017, 02:31 PM | #16 (permalink) |
Is there a place in the US where you can get a Unisense-E?
Specter v2, Tron Dnamic, Nimbus 550, P380, Edge-TX |
02-23-2017, 03:39 PM | #17 (permalink) |
Nope. You have to order from Germany, which isn't such a bad thing now that the Euro is almost even with the US Dollar.
https://www.sm-modellbau.de/UniSens-E If you don't understand German, just run it through Google Translate; that's what I did.
02-23-2017, 03:53 PM | #18 (permalink) | |
02-23-2017, 06:32 PM | #19 (permalink) |
Castle ESC -> Brain 2 ->SPM4649T Rx
02-23-2017, 07:45 PM | #20 (permalink) | ||
Brain 2 enables Castle, Scorpion, Kontronic, and Hobywing v4 without additional hardware. (Some you may have to move pins around in the cable) |
