Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 08-12-2010, 06:12 AM   #1 (permalink)
Default Edge FBL blade rattle?
I have a set of Edge 603mm FBL blades with approximately ten flights on them. I noticed a rattling sound coming from the blades the other day when I raised and lowered the swash. If I tap on the blades I can hear a noise that sounds like something is loose inside one blade. Anyone else experienced this with Edge blades?
Bobs is offline        Reply With Quote Quick reply to this message
Old 08-12-2010, 07:06 AM   #2 (permalink)
Its your ball links,
Just had this the other day with my radix, Take the end of the blade and twist it up and down so you put a load on your ball links, then start grabbing the links until you know witch one is loose.
Your blades are fine : )
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 09-06-2010, 08:28 AM   #3 (permalink)
I have the same with my 553 torsions.. Not sure what it is. links are all good..
Nko15 is offline        Reply With Quote Quick reply to this message
Old 09-06-2010, 09:40 PM   #4 (permalink)
Did you take the blades off the heli to see if the noise is still there?
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 09-22-2010, 06:11 PM   #5 (permalink)
i here that on all blades v blades to.and they are solid core
taildrive is offline        Reply With Quote Quick reply to this message
Old 09-22-2010, 06:14 PM   #6 (permalink)
Default i have herd that
i have herd that on my heli with solid wood core V Blades.you should be fine
Old 09-23-2010, 06:40 AM   #7 (permalink)
Did you try to grease/oil your mainshaft? Mine was free of grease and I had this rattle too.
After oiling the main shaft a little bit the swash was moveing smooth again and the rattle stopped.
WoDiGe is offline        Reply With Quote Quick reply to this message
Old 10-05-2010, 06:11 PM   #8 (permalink)
TRy differnet set of blades to see if it still does it. What FBL are you using? I running SK720 with Satilite and if you move the collective up and down you will see a roughness in movement and cause a rattly sound from the blades. THe blades are fine and so is the FBL unit as there no roughness/jitterly in the head when flying.
Cheers, Glenn
Outrage Fusion 50 FBL SK720 12s Xera 4025-560,Kon.HV 80 ,JR8717,OR 9088 on 6v TP 6s 65c 3300's
Trex 700CHP FBL SK720 MX510,Kon HV 80, JR 8717,OR 9188, 6v, TP 6s 45c 4400's
Gernejr is offline        Reply With Quote Quick reply to this message
Old 10-05-2010, 06:20 PM   #9 (permalink)
It may be the bearing in the blade grip. On my blade grips they are not a perfectly tight fit and if I raise and lower my Edge FBL blades at the tips, I can hear it rattle in the grip.
G.
g-bru is offline        Reply With Quote Quick reply to this message
Old 10-06-2010, 10:04 AM   #10 (permalink)
I have the same rattle in one of the 2 SAB new type blades I am running on my T500 FBL. I think it could be the weight inside the blade which may be loose causing the noise/rattle, otherwise they fly great. I contacted SAB who informed if their is no blade induced vibration just fly them.
foncam is offline        Reply With Quote Quick reply to this message
Old 10-18-2010, 08:26 PM   #11 (permalink)
Had the same thing happen to me!... the blades are on the noisy side but they are AWESOME!!! They fart so well!!!
Team EMPIRE/ GAUI USA / Cyclone blades/ Scorpion Power Systems / YS Engines / JR Radios / Opti Power
kovar is offline        Reply With Quote Quick reply to this message
Old 01-13-2011, 01:44 PM   #12 (permalink)
I get the same sound,I think it might be resonating from the servo metal gear train and or the servo steps or system resolution?When the system is spinning I can't see or hear it.Though it's normal it would be interesting to know what it is.
Dave Snider is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 08:12 PM   #13 (permalink)
It could be notchey bearings on the elevator arm ive seen that before.This is on the bench not noticeable in flight.
Magneto is offline        Reply With Quote Quick reply to this message
Old 12-10-2012, 12:43 PM   #14 (permalink)
well boys i can tell you what it is!! after smashing a couple of pairs of Edge 523 se fbl and getting a look inside! theres a thin,1.5 -2 mm maybe rod that run s along the leading edge and both sets i duffed they werent secured very well in there. other than that theres only foam.-no lead like they advertise
bowmaaker is offline        Reply With Quote Quick reply to this message
