Old 11-17-2012, 11:42 PM   #1 (permalink)
Default tail twitch
The tail twitches a couple of degrees every so often in hover. Is this normal for a 450 size heli? Its not bad, just slightly annoying.
I have torque tube tail drive. Tail is silky smooth.
Vibes less than 0.9 . No visible vibes either.
Tried two different tail servos.
Logging is off.
Tail gain set to 24.
Tried with/ without gov. Manage collective.
Gov gain at 30
Any thoughts please....
Cheers
Nick
Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat.
Mini Titan E325 FBL, Blade Nano Cpx
nickyd is offline        Reply With Quote Quick reply to this message
Old 11-18-2012, 04:41 AM   #2 (permalink)
Logging on,off ?
Use the search to find 5 similar threads
ArguZ is offline        Reply With Quote Quick reply to this message
Old 11-18-2012, 05:30 AM   #3 (permalink)
my 450 does exactly the same so I guess its normal
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is offline        Reply With Quote Quick reply to this message
Old 11-18-2012, 06:32 AM   #4 (permalink)
Thanks guys
Arguz: ive been following the other threads. my logging is off as i mentioned, thus the new topic. thanks for answering though.
Anthony : Cheers. i can live with the twitch then. just wanted to make sure i wasnt setting something wrong. im getting a bit ocd with my sk..... especially since im no pro pilot ( cant even do inverted for more than 5 seconds without pissin my pants
Nick
Old 11-18-2012, 09:06 AM   #5 (permalink)
had a bit of a breakthrough this morning, tail twitch nearly all gone, I can still see it but just slightly now, it appears my tail gain was too high, stopping gain a bit low, heading hold low too, after playing with these it got a lot better, maybe it is settings! all my testing was done upright but does involve flying backwards( for the heading hold gain) I was going to just accept it too but I must be ocd too as my beast x trex doesn't have the twitch and this is a much better gyro
Anthony
Old 11-18-2012, 10:00 AM   #6 (permalink)
Hi Anthony. whats all your tail gain settings at now please. cant help but dabble a bit more.....
Nick
Old 11-18-2012, 11:38 AM   #7 (permalink)
here's a screen capture of my tail tab
Name:	sk 540 tail.PNG
Anthony
Old 11-18-2012, 02:17 PM   #8 (permalink)
=] Nick hi, clear the SD card and please report back?
Old 11-18-2012, 02:33 PM   #9 (permalink)
Hi GM,
my card is cleared before every flight.
i almost suspect i am seeing things ...
just the odd twitch. i will try to film it sometime. .i should concentrae more on flying than watching my tail twitching
Nick
Old 11-18-2012, 02:58 PM   #10 (permalink)
=] is the primary drive on that belt?
Old 11-18-2012, 06:29 PM   #11 (permalink)
Originally Posted by nickyd View Post
Hi GM,
I have never been able to get the tail on a 450 or smaller to be 100% perfect, they either feel a bit vague or you get the odd very slight twitch (usually linked to wind IMO). I never notice when I am not just hovering and looking for the problem so I just ignore it.
My 500 was perfect pretty much right off the bat, though.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 11-18-2012, 08:52 PM   #12 (permalink)
Primary tail drive is torque tube...
Nick
Old 05-23-2013, 09:46 AM   #13 (permalink)
Thanks Anthony. I had my stop accel at 27 and have now increased it to 35 . This has removed the twitch. Cheers for the great tip!!
I see your tail gain is over 40%. If I go above 30% tail gain on my MT I can see a very small , say 2mm , tail wag.
I am using the "lock tail gain" value as my dx6i doesnt have a spare channel to regulate this.
Nick
Old 05-23-2013, 04:25 PM   #14 (permalink)
the dx6i should have one spare channel? You should have a gear channel, unless you're using it for cyclic gain
DX8 / MCPX BL / 450 Pro DFC / Skookum Powered!
Jon Sands is offline        Reply With Quote Quick reply to this message
Old 05-23-2013, 04:25 PM   #15 (permalink)
Default Re: tail twitch
I hear you on being ocd. I am very picky about how well my models fly aswell. Fighting a slow wag on my gasser still so now I am thinking of playing more with the settings.
Sent from my HTC One V using Tapatalk 2
B400(retired),Mini Titan V1(Retired),Radikal G20 (scrapped),Align T-Rex 500pro DFC,Synergy E5s
Digger1973 is offline        Reply With Quote Quick reply to this message
Old 05-23-2013, 07:46 PM   #16 (permalink)
I now have my tail gain locked at 30, my whole flight is wag free until the end when I can hear the batteries struggling then the twitch is back for landing and is really no big deal however with my new batteries there is no twitch at all, my old batteries must have around 500 - 700 flights so all in all I think I got a good deal out of them.
Anthony
Old 05-23-2013, 07:58 PM   #17 (permalink)
actually I just checked my settings and its my overall gain that's set to 30 , so I've included my tail tab again, hope this helps
Anthony
Old 05-23-2013, 10:42 PM   #18 (permalink)
Thats 20% higher than my gain. Do you have the sk governer on? I have my sk gov at 30% so maybe this is making a difference.
I use my spare dx6i channel for sl bailout.
Thanks for all the help. Im happy with my setup now . Cheers....
Nick
Old 05-24-2013, 05:50 AM   #19 (permalink)
could be to do with the fact that my tail blades are small compared to other 450's and yes i'm using the sk gov set at 25%
Anthony
Old 05-24-2013, 05:55 AM   #20 (permalink)
Thanks Anthony.
I may try turning down my sk gov to 25%. My tail blades are KBDD 61mm.
Nick
