450 Class Electric Helicopters 450 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
01-21-2016, 12:12 AM | #1 (permalink) |
Best upgrades to my 450 dfc for extreme 3d?
Hi guys I want to upgrade my stock 450 pro dfc to perform to his limits. I want to start practicing kind of extreme or smack 3d staying in 3s battery. What kind of motor . esc. Main and tail blades. Pinions etc do I need to have a strong and powerful setup? Will appreciate any help. Thanks
] Trex 450 SE V2 - Trex 550e V2 - Trex 450 Pro DFC BeastX Dx7 Ar610 - Ar7300 w/BeastX |
01-21-2016, 02:30 AM | #2 (permalink) |
If you are considering doing all of that, you might as well stretch it and run 360mm blades. Also make sure you have the black align gears.
01-21-2016, 02:31 AM | #3 (permalink) |
When I went down this path I started with a KDE 450XF-3500 and a CC Edge Lite 50A ESC 12/121 gearing. Standard Align blades & tail.
In the end I went for a 4S setup with 75A ESC (insane power - can run the blades at 3400RPM - clocked it at 140KM/Hr on the GPS (calm day and wasn't even at highest headspeed) - but (a) they don't make that motor anymore (although some still have stock) (b) 4S/2450 is heavier (so more suited to "big air" than "smack"). Personally, I was very under-whelmed by 3S & 6S setups for a 450 (I'm more of a bitchy/twitchy "extreme power" kinda guy). |
01-24-2016, 10:21 AM | #4 (permalink) |
Thanks guys .
01-24-2016, 05:23 PM | #5 (permalink) |
For 3s, the scorpion 2221-6 4400kv has loads of power. I ran it on my 450 pro, and now on my X3. It has more power than I will ever need, and is very hard to bog. I am running 325 blades, so I can imagine on on 360 blades it would have a little less power. But for right now on 3s, I do not need anything more.
Team Synergy |
01-25-2016, 02:48 PM | #6 (permalink) | |
Closed Account
I have the 6S KDE motor and the power is similar to the 3S setup. You just come down less hot. |
01-25-2016, 02:57 PM | #7 (permalink) | |
4S on the other hand is a full 33% more energy being lifted for only a small increase in overall weight - it's like bolting a turbocharger on. Only problem is that KDE have stopped making the 450XF-3500 (I bought a couple of extras as "insurance") (apart from shafts and bearings they don't wear out - so hopefully I'm good to go) |
01-27-2016, 10:40 AM | #8 (permalink) | |
Closed Account
The KDE 3500 on 4S is an absolute beast. KDE has stopped producing a number of heli motor it sucks I'm still looking for a 500xf 1450kv for my 500. |
01-27-2016, 02:33 PM | #9 (permalink) | |
In terms of temps, I honestly can't recall any great differences - both are so within the operating window that it becomes a moot point. Off memory I think my ESC was slightly hotter on 6S as I remember thinking at the time that that wasn't what I was expecting, but the logs were well within limits anyway so again I just stopped worrying about it. With 4S I run all my 450 Birds with a 75A ESC making the whole powerplant idiot proof (can't bog it - can't overheat it - can fly it with impunity). Worst I've done is stripped a main gear when I accidentally spooled up in a low headspeed mode (Castle ESCs have a bug that results in it spooling up slowly to a certain point and then letting rip at max acceleration for a short time is RPM are set low). |
01-28-2016, 02:29 AM | #10 (permalink) | |
While I agree with this it is assuming that all other parameters are constant. In reality the 6S 450L is geared for a higher headspeed with larger blades and based on what I've read here it's a 4-5 minute max flight time heli. The 3S by contrast is geared for slightly lower RPM and swings smaller blades. I run mine at 6:30 minutes very comfortably. The 6S motor also is able to produce a few hundred watt more power than the 3S. As such the 6S has more power because it can cope with the higher load it is demanded from it. If setup to be equal to the 3S it will be the same in performance as long as your 3S packs can cope with the current.
Goblin Black Thunder TGY 725MG, BK 7006HV, XNOVA 4525-560KV, Spirit Pro Goblin 500 Sport - KST, HW 100V3, Quantum 1200KV, Spirit Pro, Trex 450L, Spektrum DX9 |
01-28-2016, 03:00 AM | #11 (permalink) | |
The 3S version uses the HML46M02 motor rated at 500W continuous and 730W for 5 seconds, whereas the 6S version uses the HML46M01 motor rated at 650W continuous and 970W for 5 seconds My 450 comparisons have been done with the KDE450XF-3500 and -1750 motors - both 725 watts continuous. I suspect a 450XF-3500 with a 4S/2450 battery would eat a HML46M01 equipped 450L for breakfast though; more available continuous power and lifting 1/3 more energy to disperse as the pilot desires Just makes me smile when people (in general) talk about 6S as being the heli equivalent of a V8 compared to a flat 4 when in reality (apples with apples) there's essentially no difference - and in talking performance setups they never seem to mention a 4S setup with a full 1/3 more energy available. Don't forget too that in terms of battery wattage, the 3S has to cope with twice the current compared to a 6S setup (again apples with apples) BUT the battery is also twice as capable as the 6S battery of delivering that current. I found 6S batteries a PITA in reality - too easy to kill one cell if you push them hard by under-volting it (which is why when I setup my 550 I went for 2x 4S/5000 so I can swap out in essence "1/2" a pack). |
01-28-2016, 04:30 PM | #12 (permalink) | ||
Closed Account
01-28-2016, 04:48 PM | #13 (permalink) | ||
Yesterday I did a test flight to illustrate something for someone. I tried to record it by putting my iPhone in my top pocket - failed MISERABLY - but here's a link to a low-quality version. There are a few glimpses of the heli where people can see the speed and G's it's pulling, but for the most part I think the residual value is in the sound where people can hear both the headspeed and tight governing (even when I mad it sag briefly near the start) (doing continuous rolls). https://drive.google.com/file/d/0B2g...ew?usp=sharing I've clocked this heli at 140 km/hr - and that was with the headspeed a couple of hundred RPM lower than it is here (on a calm day too). Just trying to show people that this is what we 4S folks fly with everyday - it's a far cry from my 3S / 6S setups. |
