Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree20Likes
Old 07-07-2013, 04:33 AM   #1041 (permalink)
Default Show off your T-Rex 550 - post your pics here!
Originally Posted by tyhatts View Post
Really enjoyed that !! Thanks for sharing
Thanks dude!
Sent from my iPhone 5 using Tapatalk
Helis: Trex 700 DFC HV - Blade MSRx
Tx: Spektrum DX9
Charger: Hyperion 0720i Super Duo3 1000w
B3NNZ is offline        Reply With Quote Quick reply to this message
Old 07-23-2013, 06:35 PM   #1042 (permalink)
JWILL is offline        Reply With Quote Quick reply to this message
Old 07-24-2013, 10:33 AM   #1043 (permalink)
ady
Name:	iphone 1 252.jpg
ady is offline        Reply With Quote Quick reply to this message
Old 07-25-2013, 10:15 AM   #1044 (permalink)
Originally Posted by JWILL View Post
Hi, Can you send the link of the canopy or name to order one for me?,Love it!
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is online now        Reply With Quote Quick reply to this message
Old 07-25-2013, 06:24 PM   #1045 (permalink)
Default New DFC on the 550 V1
New DFC head and tail upgrade on the 550 V1
We Men Need a Second Hobby, Besides Women
Futaba, Vbar, Kontronik, Align, IKON, 3GX, Vario, WR Hercules
Mikado, Scorpion, BeastX, Gens Ace, Goblin, Hyperion, JetCat Turbine, APS, BD3SX
www.modelhelicopter-review.nl
trexpro is offline        Reply With Quote Quick reply to this message
Old 07-27-2013, 08:42 PM   #1046 (permalink)
All Align airframe except for OMG Revolution FBL hub, KDS 550 CF rudder pushrod, Lynxheli canopy mounts, Protek metric 12.9 cap head screws, Axial self tapping screws (boom mount and battery tray) I used Axial flat head hex drive self tapping screws with countersunk washers because finishing washers would not center properly on the stock self tapping screws. I'm using a Robird G31 with Hyperion DS20X-SMD's on cyclic, DS20X-GCD on rudder, YEP 80A and an Align BL600M motor. I get about 7 minutes at 2100rpm with the pack ending at slightly over 3.8v per cell.
ID:	438989   Click image for larger version
ID:	438990   Click image for larger version
ID:	438991   Click image for larger version
ID:	438996   Click image for larger version
Old 07-27-2013, 10:46 PM   #1047 (permalink)
Very nice, AS. I use the BL600M also. It's a very efficient motor. I fly 5 minutes of soft 3D and the batteries are close to storage charge. One thing I do with my 600M is to lube the bearings. I got the 550 when it was first released and a lot of others had motor bearings fail after a small number of flights. I started off using scorpion motor oil and now I use HeliOption bearing oil, about every 20 flights. The motor is still going strong, and the BL600MX I bought to replace it, is still in the box.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
Old 07-28-2013, 01:23 AM   #1048 (permalink)
I've been periodically using Norvay INC. turbine oil. Stuff is a pain in the butt to store because it will climb out of it's container then down the sides and across whatever it's sitting on if you leave it for long enough. Those same properties make it great for bearings and shafts though.
If I ever need to replace the motor I was thinking of maybe using a Gaui X5 motor as it's also 1800 watts and I don;t really need anything more powerful. Viper RC also makes a 2200 watt 550/600 class motor that has good reviews for about the same price as the X5 motor.
One thing I found is that the protek screws have higher tolerance threads than the Align screws. You can tell this is the case by screwing one into a tapped hole on one of the parts halfway and wiggling the screw. The protek screws have about half the slop of the Align screws. I checked with calipers and the Align frame screws have a diameter of 2.81mm to 2.82mm on the threaded portion and a diameter of 2.85mm on the unthreaded collar while the protek screws have a diameter of 2.91mm to 2.92mm. The holes in the CF have a diameter of about 2.95mm. Because of this more care has to be taken getting the thread started on the protek screws but they have a better fit. The tighter tolerance means you basically don't have to worry about getting the frame lined up and the screws are less likely to back out and more resistant to stripping (though more care has to be taken to avoid cross threading)
Old 07-28-2013, 01:48 AM   #1049 (permalink)
(double post)
Old 08-04-2013, 04:38 PM   #1050 (permalink)
This must be the best heli there is. Today I have put on Align 550-blades and really liked them.
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 08-06-2013, 04:27 PM   #1051 (permalink)
some upgrades, the best machine got even better!
ID:	441544   Click image for larger version
ID:	441545   Click image for larger version
ID:	441546   Click image for larger version
Old 08-07-2013, 01:16 PM   #1052 (permalink)
That is sweet Danny. Do you have any issues with the top of the main gear rubbing on the lower rubber servo grommets?
My clearance is already so tight in there with the stock 170T main gear - the slant gear you're using (KDE?) is much thicker and would certainly contact one mine I would suspect.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
DCflyer is offline        Reply With Quote Quick reply to this message
Old 08-08-2013, 12:11 AM   #1053 (permalink)
Default My 550e
carrier2027 is offline        Reply With Quote Quick reply to this message
Old 08-08-2013, 12:44 PM   #1054 (permalink)
not much clearance, but it works without problems. The gear is Align 700 gear, the M1/112T, really fat!
Old 08-08-2013, 02:25 PM   #1055 (permalink)
Dang monster motor and servos you have on that thing - must feel like a gnat in the air!
That is the exact gear i'll be running on my 700. Decided on the KDE 164T straight cut gear along with Revco 16T pinion and Lynx hub/bearing for the 550. Want to get a little extra life out of my motor bearings. I'm sure the KDE motor can handle it though.
Looks like you have the same clearance as I. I might just file down those rubber grommets. Their fitment is not ideal.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 08-08-2013, 02:47 PM   #1056 (permalink)
yeah, I don't buy new machines but I like to improve the ones I have. Have like 1000 flights with this one now and really love it. The servos have been there from day one, a few craches but they works flawless anyway. The machine itself have been quite maintenance free also.
Good with same gear, then you need only one gear in stock for both helis!
Old 08-08-2013, 07:49 PM   #1057 (permalink)
Align 550 DFC with old gear ratio ( Custom Canomod Canopy)
3x 610
1x 650
BeastX 3.0.8
CC Bec Pro 20A
600mx
112t / 12t
Edge, Main and Tail.
Black Gears
CC 120HV
The tail boom is the only diference with the new 550DFC , I have 550 tail boom.
Name:	P1010818 (Large).JPG
ID:	442158   Click image for larger version
Name:	P1010828 (Large).JPG
ID:	442159   Click image for larger version
Name:	P1010823 (Large).JPG
ID:	442160   Click image for larger version
Name:	P1010827 (Large).JPG
Old 08-09-2013, 12:13 AM   #1058 (permalink)
really nice canopy!
Old 08-09-2013, 03:48 AM   #1059 (permalink)
That canopy reminds me of the yellow/red goblin
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6
-kenny- is offline        Reply With Quote Quick reply to this message
Old 08-09-2013, 06:48 AM   #1060 (permalink)
+1
Tx: Spektrum DX9
