Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters
Compass Helicopters Rage RC Hellicopter Discussion
Old 02-04-2012, 02:23 PM   #1 (permalink)
Default Retaining connectors in Microbeast/Receivers/Etc.
Hi guys....
I'm gonna fly my 6HV again if it kills me someday but not until I reach a suitable solution to the subject. Some say shoe-goo others this goop stuff. A few days ago I thought haha I have tons of rtv silicone rubber that is black will work perfect.... non conductive etc.
After 3 days of curing to a worn out cellphone charger plug housing not so much, would take xacto to cut any connectors out of it. Looking for something that adheres well yet peels right off... what does that?
I saw a comment from Richard the other day about stacking 3M tape into the connector from below on a MB thread I think. I thought this to be a very innovative idea as I hate the thought of lathing a bunch of something about the wiring....
Best regards,
Tom
"It's not the crash so much as the sudden stop"
Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe....
sarpilot is offline        Reply With Quote Quick reply to this message
Old 02-04-2012, 02:37 PM   #2 (permalink)
I use hot glue on my miniature servo connectors on my mcpx. Holds them on but peels off pretty easy when I take them apart.
Blade120sr-Blade450x2-BladeMcpx-Beam E4.... Hirobo eagle Freya..
JohnnyV52 is offline        Reply With Quote Quick reply to this message
Old 02-04-2012, 02:49 PM   #3 (permalink)
I just put a strip of 3M 4010 clear tape on top of connectors. Sticks good and easy to remove and replace.
belcom is offline        Reply With Quote Quick reply to this message
Old 02-04-2012, 03:08 PM   #4 (permalink)
Thx for the replies guys... Yes I believe someone mentioned the glue gun thing previously as well. I mean you want good adhesion but tradeoff to that is having to work on it....
B I guess Richard's approach is similar to yours. Point being there is something better than just gobbing stuff on there. Everyone I think wants it all to look good ... DO NOT use RTV Silicone....
Old 02-04-2012, 03:49 PM   #5 (permalink)
Tom, I swear by hot glue, i just put a blob over the servo connectors, then with a wet finger smooth over and leave. Then when dry break any of the wire like strands off.
Peels of a treat too
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 02-04-2012, 04:08 PM   #6 (permalink)
Formerly BarnStormer
goop is the stuff I use
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
Old 02-04-2012, 09:14 PM   #7 (permalink)
Another vote for hot glue.
Andrew
kevinator9 is offline        Reply With Quote Quick reply to this message
Old 02-04-2012, 10:49 PM   #8 (permalink)
Some people use dental floss. You just wrap it around the device between the wires on the connectors. If you want to be able to pull connectors, you only have to snip the floss.
HeliFreak Support
Graupner MZ-32
Old 02-05-2012, 06:23 AM   #9 (permalink)
Here are a few shots of my areas of concern. Is this the right tape? I looked for 4010 or 4011 but this was all I could find around here locally.
Leaning towards the hot glue as a permanent solution especially if it is easily removed for maintenance. For now I am thinking use this 3M tape get it back in the air. I don't mind crashing that is part of the game but crashing because of stupid building practices I am really trying to get away from that....
Old 02-05-2012, 06:24 AM   #10 (permalink)
not sure what is up server will not accept uploads.... will try again later....
Old 02-05-2012, 06:33 AM   #11 (permalink)
+1 for the hotglue!!! Peals easy of, or use some of the misses nailpolish remover to make it easier!
Compass 6HV Ultimate / Warp 360/ eXo 500 on the wish list
Dutch Compass Maniac's
gevaho is offline        Reply With Quote Quick reply to this message
Old 02-05-2012, 06:56 AM   #12 (permalink)
try again....
ID:	286511   Click image for larger version
ID:	286512   Click image for larger version
ID:	286513   Click image for larger version
Old 02-05-2012, 11:28 AM   #13 (permalink)
goop stays much more flexable then hot glue.I just use a razor to cut between the connectors I want to remove then peel off the goop in between.
Old 02-05-2012, 03:34 PM   #14 (permalink)
That looks very tidy and effective.... black glue eh?
Old 02-05-2012, 03:58 PM   #15 (permalink)
Tom,
Here is a photograph of the AR7200BX in my test machine:
You cannot see it very clearly, but you can just see the edge of the gray tape stacked up under the plugs
I have done this on the last two or three helicopters with very good success. No plugs coming loose or backing out.
Old 02-05-2012, 04:19 PM   #16 (permalink)
Thx Richard for the pic yes I was curious as to how you were doing it I believe you posted something on the MB board where I saw it.... on 6HV using MB tape I have not had any vib issues and it is on the rear of platform I cannot stack it that way unless I redo whole platform. Scroll back look at tape pics is this pretty much what you are using?
For 7HV build gonna get MB/Spektrum combo as you try your idea tape stacking. Big platform there.... On 6HV I am thinking cut some of this 3M tape run across the top as someone else posted suggestion I think....
Best regards,
Tom
Old 02-08-2012, 11:33 AM   #17 (permalink)
Yep, we got it at work.
Old 02-08-2012, 02:30 PM   #18 (permalink)
I was unable to get an appointment this week for an TWDHT (Tony Whiteside Destructoboy Heli Test) so gonna just have to rough it. Opted for the hot glue about to do it final bench tests almost complete..... Since I couldn't schedule that I opted for shaking the daylights out of it somewhat smashing into countertops trying to induce electrical malfunction. So far so good.... Saw a thing of shoe-goo finally somewhere may snag a tube of that to try I know Dominic recommends that. I like the adhesion of the hot glue and the precision of application but after 2 days curing on my test piece it is somewhat plyable but still is gonna have to be hacked off somewhat if you ever need to get wires out.....
Oh ya.... got to graduate from the Skunkworx Academy of Receiver Battery Charging yesterday, pretty exciting to get my crash bill! Luckily on bench doing final testing get her almost 100% rpm and whooooooom nothing every possible light blinking.... hot glue pics soon.....
Old 02-08-2012, 02:39 PM   #19 (permalink)
I know I'm probably tempting fate, but I don't do any special retention of cables where they go into my full sized VBars except for the sensor cables. I bundle the servo cables up to the VBars and the bundling does a good job of distributing pulling stress over all the plugs. If I were using a BeastX or Mini VBar, I most certainly would retain the plugs better just because of the way they emanate from the unit.
HeliFreak Support
Graupner MZ-32
Old 02-08-2012, 02:58 PM   #20 (permalink)
yes the current MB plug configuration leaves much to be desired. I wonder if new Spektrum/combo the same Spektrum receivers are usually pretty snug....
