Old 09-20-2014, 02:29 PM   #1081 (permalink)
Originally Posted by altascape View Post
After using the Parkfly 2362 for around 100 fun if somewhat underpowered flights I decided to go for the Hyperion 2213 3585 motor.
Still available from this site but pricey
http://robotbirds.co.uk/catalog/prod...oducts_id=4908
My 300x is running the standard plastic head. Would the plastic head be ok with the extra power if just doing sport flying?
Originally Posted by DoubleCH View Post
I run plastic head all my 2000+ flights no problem many with Hyperion 2213-3585, some with Lynx EOX motor.
Good find on apparently the last Hyp 2213-3585s in the world. But yeah that's about 65 USD which is very pricey for this motor. For that price I'd just go for a Scorpion 2213-14 which can be had for 60 USD.
I'm still running the plastic grips as well. I actually have some aluminum ones, but I like the plastics better. No problems there.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 09-20-2014, 10:48 PM   #1082 (permalink)
Most definitely. The stock plastic head, grips, and swash are very strong and durable. I have three 300Xs (I just sold a forth one I had)... I have metal head/grips on one (running 4s) and plastic head/grips on the other two. I've had the plastic head and grips up past 4000RPM without issue.
Uriah is offline        Reply With Quote Quick reply to this message
Old 09-21-2014, 03:24 AM   #1083 (permalink)
+1
...with a splash of Lynx dampers, the stock makes the head feel loose...
Oxy 285 (6s) (AR7200BX, HKII 2216-16, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV)
Lynx Team Pilot / Oxy Field Rep
Livan75 is offline        Reply With Quote Quick reply to this message
Old 01-01-2017, 08:44 AM   #1084 (permalink)
What's a good esc to run with the scorpion 2213-14?
Efmikey17 is offline        Reply With Quote Quick reply to this message
Old 01-06-2017, 11:39 AM   #1085 (permalink)
That motor is rated 32 amps, you would probably want a 35 amp ESC. I like the Castle Talon.
Murph_d is offline        Reply With Quote Quick reply to this message
Old 04-21-2018, 01:57 PM   #1086 (permalink)
Default 320H/250 CFX Main Motor Replacement?
My 250 CFX came with the same 320H motor as y'alls 300X
Do you know which motor may work in the 250's small frame without over-taxing its ESC? I am not sure...
-do you think a 39 gram 250-size motor Lynx 1911 on 3S would work? It is only 3600kv, yet similar weight, so i suppose i could try a different pinion to make up for rpm loss (the 320H is supposedly 41.5 grams stock)
The Lynx 2214 V2 looks way too large. Will likely tax the dual esc...
Yall have the most experience with similar motor replacement versus the 250 forum... not trying to get off-topic.
Thanks for any ideas
Hangar223: Logo 480 Xxtreme (prjct), DX6i, Heli-X demo, several airplanes, Club Saito RCGroups
Bunnyshooter223 is offline        Reply With Quote Quick reply to this message
Old 11-08-2019, 03:35 AM   #1087 (permalink)
So what's the easiest hop-up motor to install/use that's available now? And does anyone have a link to get one?
Helis: Blade 150s, Blade 300x (own 2), Spektrum ix12, -RC Cars: Tamiya TRF 417x, Traxxas E Revo, HPI WR8, -Boats: Proboat Recoil 17
LethalSassonic is offline        Reply With Quote Quick reply to this message
Old 11-08-2019, 11:16 PM   #1088 (permalink)
How’s many cells do you want to run?
bgymr is offline        Reply With Quote Quick reply to this message
Old 11-08-2019, 11:54 PM   #1089 (permalink)
Drop in a Lynx 4S 4100kV motor with 1350mAh 4S packs...
Do the math for pinion size (most likely will be a 10T)
http://www.jmrware.com/misc/hscalc.html
136T main gear will give 3200 @ 80 TC...3400 @ 85 TC
https://www.ebay.com/itm/LYX8005-Lyn...0AAOSwgmJX1RdN Last One !!
Old 11-09-2019, 02:48 AM   #1090 (permalink)
I want to stick to stock esc and 3s
Simple Heli Headspeed Calculator
Jon, I don't have any large fields near me, I want to stick w/3s because the park I fly is not large enough for a larger heli than the 300x, or a super-charged 300x motor. I'm more thinking a better performing motor w/less slop/vibes that will drop in for the stock one, but massive power is not needed.
Old 11-09-2019, 08:56 AM   #1091 (permalink)
Scorpion 2213-14 is a solid motor for a 3s setup ungoverned with a 12t pinion. I ran one on my 300x (lynx frame) for hundreds of flights on 4s governed with a talon 35a at 3600 3800 & 4000 and it was great although it did just throw a magnet. I’ve since replaced it with the eox 2214, to match my Oxy3, which is def a bit stronger. Keep in mind if you go the scorpion route you’ll have to file/grind a flat on the shaft and they recommend lubing the bearings every couple of flights.
KJas is offline        Reply With Quote Quick reply to this message
Old 11-09-2019, 09:44 AM   #1092 (permalink)
You can use the Lynx w/3S...adjust the pinion for the head speed You need
When I saw the words hop-up in You OP I thought 4S
Old 05-02-2020, 04:59 PM   #1093 (permalink)
I'm doing another 300x rebuild with all my spares... I can't find any upgraded motors anymore, either they are on back order or discontinued, anyone have some links to buy?
Old 03-08-2023, 02:11 PM   #1094 (permalink)
Old threads.
Wow!
Shadows and Dust!
I recently cleaned out my closet and found my old 300x stuff packed away in a random box.
I then logged in to see what was going on in the forum.
Vaporware!
Shadows and dust, Maximus!
DJI F550 (Hexa) + JR9503 (storage).
Blade MQX (old and crusty).
300x (sold).
450x (sold).
NoRedLights is offline        Reply With Quote Quick reply to this message
