Old 09-17-2011, 03:07 PM   #221 (permalink)
Thanks for the reply Heim,
I have a spare set for the Align metal tail grips..I'll give them a try on the HC500SE.
Mike
Trex700N2E
Trex500ESP (Belted)
HC500SE ....GO TEAM FLYBAR!
Blayd is offline        Reply With Quote Quick reply to this message
Old 09-22-2011, 07:06 AM   #222 (permalink)
I would like to purchase some for the new Align V2 tail for the 700 which is all silver and has two radial bearings and one thrust bearing per side. Do you have some weights that I could try on them?
http://www.heliwholesaler.com/HN6103...tinfo/HN6103A/
StatiC is offline        Reply With Quote Quick reply to this message
Old 09-22-2011, 08:09 AM   #223 (permalink)
The Trex 700 Align metal weights will work. I wil send you a PM with purchase info.
Wrong!
Thanks, HJ
HEIM JOINT is offline        Reply With Quote Quick reply to this message
Old 09-22-2011, 08:14 PM   #224 (permalink)
The new V2 metal tail takes longer bolts than the 700e older metal tail. The older tail had 16mm bolts. The newer tail needs 18mm bolts but actually comes with the 16mm which are too short to go into the nyloc part of the nut. Does the longer 18mm mean the older version might not work on it?
Old 09-22-2011, 09:07 PM   #225 (permalink)
Good catch! I did not realize it was using a longer bolt. My current 700 Align metal weights would be too short. And with that much change in the grip I should actualy do testing to design the new weights. But I am real busy with my real job right now so it isnt going to happen soon.
Thanks, HJ
Old 10-14-2011, 08:42 AM   #226 (permalink)
Default chinese wights for my T-Rex 500 ESP
Hi Heim Joint,
you got a PM, for purchase one of these chinese wights.
best wishes
G. Elmas
koeschi is offline        Reply With Quote Quick reply to this message
Old 10-14-2011, 03:01 PM   #227 (permalink)
I have the new V2 tail for the 700E and the metal weight for it works just fine..
KDS Chase 360 | Align Trex 600NSP | Align Trex 700E | Align Trex 700X
Sirolf is offline        Reply With Quote Quick reply to this message
Old 10-14-2011, 06:04 PM   #228 (permalink)
How much of the bolt sticks out of the grip for the nut to engage with? If it is less than 3.5mm it is not enough to be safe.
Old 10-19-2011, 12:39 PM   #229 (permalink)
Hello HJ,
the chinese wights arrived today.
Thank you.
Best whishes
G. Elmas
Old 10-19-2011, 01:04 PM   #230 (permalink)
Originally Posted by koeschi View Post
Hello HJ,
Thank you.
Best whishes
G. Elmas
Crazy! 4 days door to door to Gemany and it can take over a week to get delivered in the US
Old 10-23-2011, 07:34 AM   #231 (permalink)
hi will this work on a 450 pro 3gx?
3GX newboy is offline        Reply With Quote Quick reply to this message
Old 10-24-2011, 09:49 AM   #232 (permalink)
Yes, you would use the 450 pro weights.
Thanks, HJ
Old 10-24-2011, 09:51 AM   #233 (permalink)
Sirolf, Can you show a picture or see how far the bolt sticks out of the grip? The new Align V2 700e tail (grips are completely silver) does need a longer bolt than the previous Align tail (black and silver).
Old 11-02-2011, 08:02 AM   #234 (permalink)
Ordered a set of the weight mods for my 450sev2 can't wait to try them out!
*edit*
HJ informed me they shipped today such a great guy! shipped them super fast.
I'm waiting patiently by the mailbox to hopefully bring my unruly tail to be rock solid,
also bought a set of KBD tail blades since I have read they work best with the chinese weight mod.
Fl00k is offline        Reply With Quote Quick reply to this message
Old 11-05-2011, 09:49 AM   #235 (permalink)
Weights arrived today! super fast
I'm thread locking and giving it some cure time.
Thanks again HJ
Kevin
*update*
Works like a charm one of the best upgrades I have done
Old 12-13-2011, 06:28 PM   #236 (permalink)
Default How is Chinese weight mod Installed on Threaded Metal Tail Blade Holder
Hello Heim Joint,
I have a Trex 500 with the Align metal tail rotor where the bolt hole is threaded on one side of the tail grip for the tail blade bolt to screw into (i.e. there's no nut). How does your mod install for this configuration? Do I have to drill out the threaded hole or do any drilling to install your bolt? Or does it just pass through the threaded hole and the weighted nut screws on the bolt with no drilling?
Thanks,
Phil
Helidestructor is offline        Reply With Quote Quick reply to this message
Old 12-14-2011, 07:19 AM   #237 (permalink)
Originally Posted by Helidestructor View Post
Hello Heim Joint,
Thanks,
Phil
Yes the bolt threads through the threaded hole and the weighted nut screws on the bolt with no drilling.
HJ
Old 12-14-2011, 11:56 AM   #238 (permalink)
HJ
Thanks Heim for the reply,
I would like to buy a set for the Trex 500 Align metal tail.
Phil
Old 12-14-2011, 06:46 PM   #239 (permalink)
Phil
PM sent at 1:51 PM
Old 12-29-2011, 07:59 AM   #240 (permalink)
After watching your video's and reading through this thread I think I'll order some for all of my birds.
What material are you using to make them Heim? Have you considered using stainless steel?
TIA
ProtoDewd is offline        Reply With Quote Quick reply to this message
