Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 10-19-2011, 01:45 AM   #101 (permalink)
HI,
thanks a lot for your message
The second stage is very solid, because it's already reducted, and the torque is better handled by a small ratio usage.
Most failures are due to heating / friction, using dry PTFE compounds helps in reducing heat generation.
Also, the Delrin has several variants, there is the DElrin 100 St used commonly ( but it's a mistake, it's a shock resistant delrin, not made for gears), natural delrin is very good but it is very sensible to friction and temperature due to the elevated speed especially on first transmissions stages.
Another possibility is to use fiberglass reinforced compounds ( PA6 GF xx) which is very resistant but it's agressive compound and the pinion used with the gear must receive a surface hardening treatment.
A full belt system is possible, but needs dampened belt pulleys and also a wider tail boom to allow the usage of large pulleys. the GOblin has, at the present time , one of the best transmission of the market. Only the main shaft gear needs slight modification but i'm sure they already modified this at SAB
BEst regards,
Fabien
Fabien is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 12:30 PM   #102 (permalink)
HSC
Well.....this reductor was designed for mee by mee, in may ways is soo komplex because I want 14mm wide belt, joker,woodoo have 10 to 12, so no compromise hear.
Usuly I do not look for kompromises, I always use the higest qality of matirial and do not look after machining time.
Also this preduct was not made for serial machining, but for botiqe ( TDR is botiq isn't it).
You can make whatever you wish with tolerances and matirial,
but 7075 is 5lightyears in front al others Alu materials.
A je to ?
HSC is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 12:45 PM   #103 (permalink)
For me, the TDR is everyday flyer and it was designed with this in mind.
The whole design is working extremelly well.
As Klaus wrote, for using really high powered motors, you can try to improve some weak points, but a problem might appear somewhere else.
More robust heli of different brand would be better solution then.
That does not mean i consider the belt solution as useless, it would be a great improvement, i just think it does not justify the effort.
Like performance tuning a weak car, when you can buy better one for the same money.
But if you love the car and do not want anything else, why not.
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 10-19-2011, 04:28 PM   #104 (permalink)
Hi,
i fully agree with you regarding the stock performances of the TDR.
The reason why i like the Belt upgrade is very simple : it reduces a little the vibrations, the noise also a bit, but more than all, it looks nice (bling factor).
Sometimes, the pleasure is simply to have something a bit rare like a heli or an upgrade,obviously i woudl not have the need of such an upgrade because my flying skills would not allow me to approach the " rupture " point of these parts, but well this is like a TDR or a Goblin or a Sitar heli for those who have known these beautiful mechanics: we do not really need them, but we want them )))))
Anyway, if i can manufacture or help to manufacture a few sets for the people who wants these upgrades, i will simply be happy to do it, and to owe one set
BEst regards,
Fabien
Old 10-20-2011, 11:25 AM   #105 (permalink)
HSC
Hello ! Right now I em producing set of reductors.
Two are sold allready one is still free serching for owner.
So if you can not wait for Taiwan pm mee.
Items will bee ready for shiping in week or so...
Regards
A je to ?
Old 10-20-2011, 11:34 AM   #106 (permalink)
Default Reducer
How much do you want for it? Thanks
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote Quick reply to this message
Old 10-20-2011, 06:16 PM   #107 (permalink)
Will you be making any more?
I dont NEED one, I WANT one!!
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote Quick reply to this message
Old 10-21-2011, 01:32 AM   #108 (permalink)
Pm sent.
Cheers Craig.
Banshee 700 Limited "No 17" -- Logo Xxtreme
Henseleit TDR 4525 Ultimate -- Henesleit MPXLE FBL
DJI S800
craigcec is offline        Reply With Quote Quick reply to this message
Old 10-21-2011, 10:28 AM   #109 (permalink)
HSC
The last one goo to Australia.....this round sold out....
Regards
A je to ?
Old 11-22-2011, 04:05 AM   #110 (permalink)
My reductor arrived today and it is absolutely beautifully designed and made and is a credit to HSC.
Thankyou for a wonderful upgrade for my TDR.
Regards,
Lance
Old School Heli Pilot and MAAA Heli Instructor
MA Spectra T Wren44 | MA Spectra G Toxic 231 | MA Stratus YS91SR | MA ProII YS91FS |
MA ProII YS61STII |
Kasama Srimok N90 YS91SR | Ergo 3D OS46FX | Ergo30 OS30SX | HK600e | HK500e |
Vortexx is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 05:00 AM   #111 (permalink)
Some news about production?
swalko is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 09:07 AM   #112 (permalink)
Tolerances on the original design are too tight to get to a price point that is affordable, even by TDR owner's standards...
Don't think the tolerances need to be that tight, but have no intention of changing the design (as it is not mine)
Edvard R is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 10:18 AM   #113 (permalink)
HSC
Hello !
Need one more intetesent for 3rd round.
Now I em ordering matirial, in week or soo will bee hear, than production cca 1 week.
Shiping normal no tracking (including in the price), posible DHL for exsrta payment.
Regards
A je to ?
Old 11-22-2011, 07:57 PM   #114 (permalink)
Default belt drive tdr
Hello,i'm interested in purchasing your set up.
HotRodHeli is offline        Reply With Quote Quick reply to this message
Old 11-23-2011, 04:14 AM   #115 (permalink)
HSC
Hello boys !
Hear is some nice pictures of reductor fro Australia equiped with HK4535 monster, this is gona be hotttt, fasttttt.
http://www.archeli.com.au/forums/sho...=149010&page=2
A je to ?
Old 11-23-2011, 01:02 PM   #116 (permalink)
I would also like to have 1 set. How do I order?
Belgoheli
belgoheli is offline        Reply With Quote Quick reply to this message
Old 11-25-2011, 10:04 AM   #117 (permalink)
HSC
Curently all 3 gears have a owner, next bounch in 45 to 60 days, for reservations PM me....
A je to ?
Old 11-26-2011, 01:28 AM   #118 (permalink)
Saw craigs heli in the flesh, the belt drive setup is beautiful, he said its a little smoother.
Just wondering if the belt requires retension or replacement??
helicraze is offline        Reply With Quote Quick reply to this message
Old 11-26-2011, 12:02 PM   #119 (permalink)
HSC
Hello !
Why you are asking, does Craig have loosen belt ?
I have reetensioned mine after 5 starst and after that was all OK for a longer periode.
The data sheet from belt say 150 to 200 N for 14mm wide HTD 3M, but this is only papers......
Regards
A je to ?
Old 11-26-2011, 08:36 PM   #120 (permalink)
I only ask because i know from experience with robotic machines that have critical tension they stretch after new
