Old 06-29-2016, 05:01 PM   #1 (permalink)
Default Use smaller pinion to raise T-curve?
I have a 700 w 750MX 530kv 12/112 gearing on a helijive 120 and its governor.
I use a spektrum radio. And at 45% throttle on the radio I'm at 1950 headspeed.
Should I drop to a 11T pinion to be able to raise the throttle curve to 60-70% or fly it like it is as long as the motor and esc don't get too hot.
I ask because I'm under the impression that you should run any speed controller close to wide open giving enough gov headroom.
45% throttle is quite low
blue92ehsi is offline        Reply With Quote Quick reply to this message
Old 06-29-2016, 06:18 PM   #2 (permalink)
actually yes -> for your standard operation you should get a smaller pinion in order to bring your throttle curve up.
It would be more efficient even its running OK also with 45% throttle.
However the smaller the motor pinion the more likely you can run risk stripping gear. So be aware of it since you cannot bring it endless down. Sometimes a motor with less kV would be the better answer.
Kontronik, Switch Blades, Bavarian Demon, TDR, TDF, Diabolo, HeliBaby, Takumi and Banshee
im4711 is offline        Reply With Quote Quick reply to this message
Old 06-29-2016, 06:27 PM   #3 (permalink)
Noted, but being that a 750MX is a standard option for a Trex 700 i am going to try a smaller pinion first before I buy a expensive motor.
