Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Raptor G4/E720
Raptor G4/E720 Thunder Tiger Raptor G4/E720 Helicopters
Old 02-10-2014, 07:12 AM   #21 (permalink)
I get 105 on the slider for cyclic set up and the 8 degrees.
Team Thunder Tiger, Team Byrons, DemoAero, Team Optipower
jkraft is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 12:04 PM   #22 (permalink)
Originally Posted by fulcrum2 View Post
Guys,
just to double-checck my set-up:
What is your number on the slider where you set cyclic 8deg. in set-up? (tab after total pitch range).
Thanks and have a great day, Stefan
Mines bang on 100 with Align DS610 servos.
It will be different depending on the servo as some will move more or less for a given pulse width.
Current fleet: Goblin Thunder Sport, Trex 700L, Logo 600, Specter 700, TDR, OMP M1 - Vbar Control - 5" and 3" FPV racing quads and a Taranis
Next heli(s): No idea. I have everything I wanted.
Bigpops is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 01:06 PM   #23 (permalink)
Mine is 94 with BLS451 and Spektrum Sats. I measured it with the "expert option" without pitch gauge. Looks like it is in the ballpark.
I don't think it differs from one radio brand to the other, instead it is more the swash link geometry that matters.
Has anyone played with that setting? You could use bankswitch, put 95/100/105 in each bank and see how the ship behaves. Might do this once the winter gives up here...
Thanks friends
fulcrum2 is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 03:27 PM   #24 (permalink)
It's 270 135 45
Team Synergy and Rail
helienv is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 04:41 PM   #25 (permalink)
I have recently tried a new setup on my E700 w/vbar. I set my cyclic 8° to 11° instead. Then I turned paddle sim completely off. Flies great!
Wess Collette
VTeam
Optipower USA
WessCo is offline        Reply With Quote Quick reply to this message
Old 02-10-2014, 06:48 PM   #26 (permalink)
Hey Wess,
How did you get 11? When I max the cyclic slider I only get about 9.5 degrees. I must be going about it wrong in the vbar.
Old 02-10-2014, 07:19 PM   #27 (permalink)
I'm using the stock head...no upgraded parts.
Wess Collette
VTeam
Optipower USA
Old 02-10-2014, 07:27 PM   #28 (permalink)
I am too. What is your slider at in the set up tab? is that where you made the adjustment? I have my agility at 110 and I'm not close. I'm just wondering if all you did is slide the slider and hit measure to get the 11 degrees. Like I said I'm at 105 for 8 degrees and can't even get to 11.
Old 02-10-2014, 07:29 PM   #29 (permalink)
Yes, that's how I did it. Where you measure the cyclic to 8°.
Wess Collette
VTeam
Optipower USA
Old 02-10-2014, 07:37 PM   #30 (permalink)
using an RC Logger digital pitch gauge, I zero it out. Click measure and then move the slider until I get 11 degrees. My cyclic number is on 109.
Wess Collette
VTeam
Optipower USA
Old 03-04-2014, 02:15 PM   #31 (permalink)
This is cool. I will test with 11 degrees on ciclic.
What about de head gain?
TT Raptor E700
Logo 600 SX
Victor-sp is offline        Reply With Quote Quick reply to this message
Old 06-22-2014, 04:12 PM   #32 (permalink)
I'm having some issues with the tail during climb outs. It kicks some degrees.
Equipment being used:
- Stock Nick Maxwell motor
- YGE 160HV Mikado OEM version
- MKS HBL980 tail servo
- Rail 116 mm tail blades
- VBar V5.3
Help would be greatly appreciated.
Thanks,
Mathias
Lynx Oxy 3 | JR XG14
Mathias is offline        Reply With Quote Quick reply to this message
Old 06-22-2014, 05:49 PM   #33 (permalink)
What headspeed? What's your gain setting? Take a screen shot of the tail main menu. Are you running Pro Software?
Wess Collette
VTeam
Optipower USA
Old 06-22-2014, 08:33 PM   #34 (permalink)
Default Vbar on E700
Try I gain at 55 or 50 and p gain at 80
VControl, Vbar Neo, Scorpion power systems, Optiguard, BK servos, Mikado Logo 700
Phil777 is offline        Reply With Quote Quick reply to this message
Old 06-22-2014, 10:56 PM   #35 (permalink)
- VBar V5.3
Thanks,
Try lower vbar gov gain and collective add, add more pre-comp, and dont run too harsh I gain, that all I can say to help you
-Logo 600SX, Full size Blueline 5.3 + BLS 256 HV, Cyclic Fu BLS 252 powered by Life 2s 6.6 V, HK III 4035 - 500 kv + Vbar Gov, YGE 120 HV
brain is offline        Reply With Quote Quick reply to this message
Old 06-23-2014, 12:46 AM   #36 (permalink)
Turn the P and I both up to 80. You guys are going the wrong way. The Raptor has a very low tail ratio. Run the P and I at 80 and the tail will hold like a death grip. I have the MKS 980 on there and run the head at 2100 and the tail gain at like 78. Stock horns. No wags ever...
The vgar gov gain I have at 30. Collective add I had at 20 and collective dynamic at 15.
I know Nick uses the same setting on the tail of his too.
V6 of Vbar the gov settings are quite a bit different. V6 is amazing how much improvement Mikado made to the control loop...
Norman Ross Jr.
Mikado USA -- Insane Canopy -- Scorpion Motors
futurase is offline        Reply With Quote Quick reply to this message
Old 06-23-2014, 10:34 AM   #37 (permalink)
I already have the P and I gain at 80. 30 for gov gain, 20 for collective add and 15 for collective dynamic. So, exactly the numbers you're referring to.
What's your collective pre-comp values at?
Mathias
Old 06-23-2014, 03:25 PM   #38 (permalink)
Norman Ross Jr.
Old 06-23-2014, 03:26 PM   #39 (permalink)
If you still have issue investigate the one way. It very well could be slipping...
Norman Ross Jr.
Old 06-23-2014, 05:20 PM   #40 (permalink)
Same esc motor and tail blades as u and lowered my I gain to. 55 p gain 80 precomp 30
