Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 07-28-2016, 02:24 AM   #21 (permalink)
The only thing which gives additional clearance for 550 blades is the new rotorhead. It's 15mm higher, which gives more space, but also additional stability. Means the V2 will be less responsive on cyclic.
Regards
Patrick
Pdolivo is offline        Reply With Quote Quick reply to this message
Old 07-29-2016, 03:39 PM   #22 (permalink)
Regards
Patrick
If this is true then that means I would only need the new frame sides and the new head to convert my X5 Formula to the X5 V2. From the manual all the other pieces look to be the same. I will definitely be taking a closer look at this while at IRCHA.
Gaui X4 II-Spirit RS | Gaui X7-Spirit RS | Gaui R5 V2-DEMON AXON | Soxos Strike 7.1-Spirit GTR
JETI DS-14 | JETI DS-16 Gen2
iscripter is offline        Reply With Quote Quick reply to this message
Old 07-30-2016, 08:06 AM   #23 (permalink)
It looks like that. I've checked the new manual and these were the only parts they changed. But I think the Formula will be more responsive than the V2.
Unfortunatly they didn't change the front torque tube drive. In my opinion this the only weak point of the X5 and tends to strip gears. The X3 and X7 solutions are more durable.
Regards
Patrick
Old 08-02-2016, 08:31 PM   #24 (permalink)
I think it's a bit funny. One of the selling points of the Formula head was that it was 10mm lower than the FES head, if I recall correctly. Looks like they keep bouncing around on how high above the heli the rotor should be.
LyleT is offline        Reply With Quote Quick reply to this message
Old 08-03-2016, 12:36 PM   #25 (permalink)
formerly koi-fish
Just hoping that it's mostly backward compatible with the V1. At first look, it appears to be. THat way I can continue flying what I have for a long time
/ 180cfx, 300x, X3,X4-II, Protos 380, Chase 360, x5, Logo 480, Gob 380, Gob 500, Gob 570, Warp 360, 450x, forza 450/450ex, T-Rex 600 Dom, Logo 600, DX9, 1973 Ford f100, Traxxas Summit/Bronco/Bandit/X-Maxx
"Everyone wanted his soul, all he gave them was a smile" - Steve Marriott
Diogenes is offline        Reply With Quote Quick reply to this message
Old 08-04-2016, 03:49 PM   #26 (permalink)
For those curious, here is a 6S 5000 in the new frame.
If you are at IRCHA, come take a peek!
Team Gaui USA/Empire Hobby
Gaui NX7 - Gaui X7 - Gaui R5 - Gaui X5 - Gaui X4II - Gaui NX4 - Gaui X3L - Gaui X3 - Gaui X2 - Velos 880
AMA 267329
joelr is offline        Reply With Quote Quick reply to this message
Old 08-04-2016, 03:57 PM   #27 (permalink)
V2 canopy mounted on the V1 frame.
AMA 267329
Old 08-04-2016, 03:58 PM   #28 (permalink)
Looks like I got the pictures inverted on this phone, can a mod fix them?
AMA 267329
Old 08-04-2016, 08:03 PM   #29 (permalink)
are the v2's out yet?
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 08-05-2016, 06:25 AM   #30 (permalink)
They are out, but there was a delay in getting them to IRCHA. There is one here that is going to be given away.
AMA 267329
Old 08-05-2016, 12:42 PM   #31 (permalink)
formerly koi-fish
I may just get the frame, seeing this. Even though it makes it heavy, I use 5000s from time to time in my X4-II. Would be nice to have some cross use for them
Old 08-06-2016, 01:41 AM   #32 (permalink)
It's a pity that you don't have the space behind the battery any more - I have my FBL there...
phailipp is offline        Reply With Quote Quick reply to this message
Old 08-08-2016, 01:43 PM   #33 (permalink)
I don't know the solutions of the X3 and X7, but today I've stripped the gear of the tail as well. It was brand new (4 flights). So I think as well that this should have been improved with a steel or PEEK-version.
Old 08-08-2016, 04:26 PM   #34 (permalink)
Will pulse 6s 5000s 65c fit in there you think?
Jan
JANtoolMAN is offline        Reply With Quote Quick reply to this message
Old 08-08-2016, 04:36 PM   #35 (permalink)
It should, it's about the same size as the Optipower 6S 50C shown in the picture. There was a bit of room around that battery too.
AMA 267329
Old 08-08-2016, 05:42 PM   #36 (permalink)
Tail strike?
Proper mesh?
Have lots on my X5 with no issue's, other's also
thebirdman is offline        Reply With Quote Quick reply to this message
Old 08-08-2016, 05:46 PM   #37 (permalink)
Originally Posted by thebirdman View Post
Tail strike?
Proper mesh?
No tail strike and it was the gear in the back. There the mesh is not adjustable...
Old 08-10-2016, 04:11 PM   #38 (permalink)
Me also, proper mesh. But outside temp. was about 30°C and I was doing fast funnels. Then the front gears stripped and the visual inspection after the crash showed something like molten gears
And the result of the TT gears failure was that., the bend tail boom (banana) was the result of going tail first into the ground ..
Regards
Patrick
ID:	665891   Click image for larger version
Old 08-10-2016, 09:00 PM   #39 (permalink)
Guys, I'm a huge Gaui fan, but... why not make the frame where the CG of the battery can be adjusted? New V2 frame limits how far forward the pack can be moved. Also, what happened to running 556mm main blades? Why not make that an option? As well as 570mm blades?
Let's not forget that X5 shares parts with X4, and that means gears. No wonder guys are stripping them. I'm replacing tail gears every few months - they wear.
The V2 needed an X4-like frame and beefier gears and options to run 520 - 570 blades.
Also, I find the gearing too be odd - 15T pinion is too much. Synergy E5 uses 12T pinion.
I'm building an E5 this winter and moving the electronics from X5. X5 is a nice larger 500 with full size servos, but I think I'll pass on the V2.
X5 rocks as a light 500 with full size servos - leave single tail bearing, use ~4100mAh pack and no changes needed. This V2 is just... not here not there. Dunno what they were thinking.
Synergy E7se | Mikado 690SX V2 | Goblin Black Thunder T | Gaui X3 | brushless mCPx
VControl | MKS & KST Servos | Pulse
Heli-X8 | Lynx Team Pilot
prokyon is offline        Reply With Quote Quick reply to this message
Old 08-26-2016, 08:32 AM   #40 (permalink)
Oh, another thing is servo position - they should extend the servo posts and move the servos away from the frame for fulcrum effect. This will also enable one to remove servos without taking the motor off.
So yes, back to just using the X4 II frame as a starting point.
