Go Back   HeliFreak > R/C Electronics Support > JR and Spektrum Radios and Electronics > 2.4G JR Radios
2.4G JR Radios JR 2.4 Gigahertz Radios and Technology
Old 02-24-2014, 07:49 AM   #1 (permalink)
Default XG11 LiPo upgrade
If I want to change the battery to LiPo where in the TX do I change the settings for this?
gh
goodhunting is online now        Reply With Quote Quick reply to this message
Old 02-24-2014, 02:22 PM   #2 (permalink)
you don't, the 11xg is designed for a li-fe battery (which charges to a max of 7v)
the only thing you can change is the low battery alarm check the manual to find how
JR 11XG DMSS the only way to go , xcell 60 xcell 60 SE
jet ranger xcell 60 mechanics now electric
T rex 700e, beastx V1, Trex 700 F3c V2,
Trex 500 stock ,trex 500 fbl (beastx ) , 500 scale ,Trex 550e , MFA 500,.Micromold Lark
sircol is offline        Reply With Quote Quick reply to this message
Old 02-24-2014, 02:24 PM   #3 (permalink)
Done that. I set mine on 7,5... is that too low?
Old 02-25-2014, 09:25 AM   #4 (permalink)
Why would you want to change to a LiPo, LiFe is the better choice for a TX. Just do not charge with the included JR charger.
7.5V for a 2S should be fine.
VControl
Old hand at Planks
Peter
Old 02-25-2014, 09:32 AM   #5 (permalink)
The LiFe battery lasted about an hour.... LiPo is in there and not showing any sign of wear yet.... it is a 3s LiPo...
Sent from my GT-I9505 using Tapatalk
Old 02-25-2014, 10:35 AM   #6 (permalink)
3S, yikes, the TX has been designed for a nominal voltage of only 6.4V, a 3S LiPo will give a nominal voltage of 11.1V far too much for the voltage regulators inside the TX. The low battery warning for a 3S should be at 9.9V. I have no idea if the warning can be adjusted that high.
VControl
Old hand at Planks
Peter
Old 02-25-2014, 10:41 AM   #7 (permalink)
Ok I guess I will downgtade then. I used 3s in the 11x...without problems. I guess I have to change out again....
Old 02-25-2014, 10:46 AM   #8 (permalink)
The stock battery should last a great deal longer than that.
I can charge the one in the XG14, then fly it for 5-6 days (averaging 4-6 flights each day), and the battery is still not run down.
Old 02-25-2014, 10:56 AM   #9 (permalink)
BTW I fly on weekends and my battery lasts for longer than a month, the default low bat warning for the stock LiFe battery is very conservative, I once left mine on after the warning and it still lasted for 40 minutes before the TX shut down.
VControl
Old hand at Planks
Peter
Old 02-25-2014, 11:32 AM   #10 (permalink)
Hmmm maybe I shoild give LiFe another try then.... what is your low level alarm for LiFe?
Old 02-25-2014, 12:05 PM   #11 (permalink)
The factory default setting, which I think is 6.0 volts.
I have only ever had the Low Voltage Alarm go off once.
Old 02-25-2014, 12:09 PM   #12 (permalink)
OK then... I guess I have some re-soldering to do tonight... Will give LiFe another try...
I guess it can't hurt...
gh
Old 02-25-2014, 01:51 PM   #13 (permalink)
Back on LiFe....
Old 04-10-2014, 08:43 PM   #14 (permalink)
Sort of on the same subject......
I have second TX battery pack (LiFe after market) for my XG8, I have to change the plug to suit the TX, does anyone know what type of plug this is?, I think it is a jst brand, but for the life of me cannot find one or a part type anywhere.
mondo is offline        Reply With Quote Quick reply to this message
Old 04-10-2014, 11:41 PM   #15 (permalink)
I cut off the one on the original battery. .. it sucks since the LiFe holds for half a day of use only...
Poslano z mojega GT-I9505 z uporabo Tapatalk
Old 04-11-2014, 03:26 AM   #16 (permalink)
it's a JST brand (J.S.T.Mfg.Co.Ltd )
you will need a crimping tool
battery lead
housing = XARP-02V
contacts = SXA-001T-P0.6
to make a charge lead (to charge out side of tx )
this housing will work = XARR-02V
contacts = SXAM001T-P0.6
Old 04-11-2014, 04:05 AM   #17 (permalink)
Thanks very much for the info, no place I can buy only a few sets of each though, so I will add in a jst plug set I have to the battery cable so then just a matter of using same plug on my spare battery.I hope someone starts selling the correct male/female sets on ebay.
Old 04-11-2014, 06:23 AM   #18 (permalink)
Cannot see that you get only half a day of use. Do you charge it with the included charger till the LED goes out on the TX or do you charge it outside on a normal charger? If using the recommended charger that came with your TX then there might be something wrong with the charging circuit inside the TX.
VControl
Old hand at Planks
Peter
Old 04-11-2014, 07:03 AM   #19 (permalink)
yes I charge it with the regular charger that came with the radio. The fact that I cut off and then resoldered the connector should have no impact...
I charge it until the light stops...
BUT I do have to charge it almost daily...
Will try to measure the capacity next time I charge it.
gh
Old 04-11-2014, 04:48 PM   #20 (permalink)
goodhunting,
I would contact JR service.
You may have something going on in the transmitter that is draining the voltage at a more rapid rate than normal. I had this with a different brand or receiver once, many years ago.
