Old 01-30-2015, 01:10 PM   #21 (permalink)
Yeah that sucks for sure. You dont want to fly it till you get sorted first. Otherwise you might replace much more than a shaft or 2. Ask my $50 SpinBlades that were smashed due to tip over takeoff caused by a bent main shaft.
-Heli Yea! Master of: the living room, mechanical setup and, the obvious!
Belt'ish CP FBL, HDX 500 DFC, New V120D02S FBL, Mini CP FBL, Hirobo Shuttle ZX, 450L w/VX1e, QR-X350PRO FPV, 450L w/APM FPV(in progress) DEVO 10 white w/2km range!
Heli Yea! is offline        Reply With Quote Quick reply to this message
Old 01-30-2015, 01:17 PM   #22 (permalink)
What kind of transmitter do you run if you don't mind my asking
k4rn1v00l is offline        Reply With Quote Quick reply to this message
Old 01-30-2015, 01:23 PM   #23 (permalink)
A Walkera Devo 10 white edition. I had a DX6i before.
Old 01-31-2015, 03:55 AM   #24 (permalink)
+1
Wait for the shafts and make sure everything runs smooth, its not worth taking a chance and freaking out the FBL..
Tight meshes in the tail gears will vibrate like mad, so make sure all is running smooth...
Oxy 285 (6s) (AR7200BX, HKII 2216-16, Koby40) T-REX 450L (6s) (VX1e, HK 2520-1880, HW50v3), Goblin 570 (12s) (VX1n, HKIII 4025-550, Jive80+HV)
Lynx Team Pilot / Oxy Field Rep
Livan75 is offline        Reply With Quote Quick reply to this message
Old 01-31-2015, 07:11 AM   #25 (permalink)
My 450 is like that too, same exact thing.
It still flies great, though.
If it gets worse i'll probably look into swapping the main shaft but for the moment i'm happy with it, the BeastX responds great and doesn't do anything funky even with that wobble in the swash.
(1) Blade McpX stock
(2) Blade Nano CPX, one with HH Brushless kit
(1) Blade msR stock
(1) Align Trex 450 Pro ( )
daver18qc is offline        Reply With Quote Quick reply to this message
Old 01-31-2015, 07:41 AM   #26 (permalink)
I'm kind of surprised align would have that issue with their kits. A bad swash plate? There's no excuse for that. Yes I'll order a new swashplate and main shaft and if it doesn't fix it I'm just going to do what you did and just fly it anyway
Old 01-31-2015, 09:42 PM   #27 (permalink)
(Forgot to say that i bought it used though, don't know if it's a factory defect or not in my particular case!)
(1) Blade msR stock
Old 05-23-2015, 07:32 AM   #28 (permalink)
Ive had a few different align swashes and they all seem to have a bit of slop. At first they might be tight but after a flight or two the slop starts. So instead of buying align swashes ive started buying tarots dfc swashes and they dont seem to have any slop so far and they are half the price as aligns.
(I.Y.A.O.Y.A.S.)
Old 05-23-2015, 07:15 PM   #29 (permalink)
My swash does the same. The plastic part that holds the ball is not "perfectly" centered. I tried disassembling the swash, because I believed the plastic bit was two pieces sandwiched that could be adjusted. I couldn't get it apart to see...
The heli fly's fine. I do suspect that it could be bad on the servos though...
Sefrez is offline        Reply With Quote Quick reply to this message
Old 05-25-2015, 05:34 PM   #30 (permalink)
Mine does the same as well. Mine was a new kit and I even contacted aligntrexstore about it before flying it. They said that the slop was normal and all the swashes have it so I have just been flying mine. I did buy a new align swash and it has the same slop in it. Ill take a vid of mine maybe tomorrow. Mine is flying great so far just trying to figure out the tuning on the gpro.
Martinshelis is offline        Reply With Quote Quick reply to this message
Old 05-26-2015, 03:25 PM   #31 (permalink)
I don't think the OP's problem is with slop. I think it is centering of the ball that the shaft goes through in the upper swash. That is my problem which is causing what I see in the video.
I do consider a little slop normal, but this is a fixed predictable oscillation of the swash as the shaft rotates, not caused by random movement due to slop.
Old 05-26-2015, 03:27 PM   #32 (permalink)
I been flying mine even after I posted the video havnt noticed and bad effects
Old 05-26-2015, 05:27 PM   #33 (permalink)
Mine is the same as the one in the video. Flys with no noticeable side effects. On spool down it has a slight vibration though.
Old 06-14-2015, 07:27 PM   #34 (permalink)
Ive just noticed that my align swash that I got recently does this but a little worse. I think it was causing my blades to go in and out of tracking and cause erratic collective changes without any real input. I switched it to a tarot dfc swash and really tgink I might be done w aligns swash for now. 30 bucks a pop and they all have slop in them. Tarots are half the price and seem to have alot less play. Just my two cents though.
(I.Y.A.O.Y.A.S.)
Old 06-14-2015, 07:39 PM   #35 (permalink)
+! My align swash was doing the same thing minus the tracking. Collective stick position was not the same all the time. I just got a tarot swash in the mail and installed yesterday. It definitely has a lot less play/slop in it. The tarot swash should solve that problem.
Old 06-15-2015, 07:53 AM   #36 (permalink)
Could you notice a difference in flight?
(I.Y.A.O.Y.A.S.)
Old 06-15-2015, 08:00 AM   #37 (permalink)
I haven't flown it yet. But I am sure it is going to make a difference. If its not raining when I get home I might test it today.
Old 06-15-2015, 08:23 AM   #38 (permalink)
W my align swash installed my heli would drop w little to no collective input and then it would take quite a bit of collective to get it back to where it was before. It felt like it had expo on the collective around center. Very weird feeling.
Now w new dampers, thrust bearings, slop free wash it is very sensitive on the collective. Doesnt take much of an input and it jumps right to it. Much better than the align swash at half the price!
(I.Y.A.O.Y.A.S.)
Old 06-15-2015, 11:53 AM   #39 (permalink)
Thats exactly how mine was behaving.
