Old 06-15-2008, 07:36 PM   #1 (permalink)
Arrow Head Vibration and TX Setting
Hello,
Had a Blade 400 and decided to move up to a T Rex 600 E CF.
Here is the back ground; I have a 600 E CF with stock electronics a 6S 5000MAH battery, and the 600XL Motor. I put Futaba servos in the collective S9452, and on the rudder I have S9254 with a GY401. The receiver is a spectrum 6200, and a DX6i TX. It has the torque tube up grade, and CF blades. I built it from the ground up using Bob’s videos. (Thanks BTW) I have the swash plate perfectly level, and the pitch in dead on at 0 degrees middle stick, and + 11/ - 11 respectively.
As it runs up to speed the head shakes, and does so until it reaches almost middle stick @ 75% throttle. Then the shaking stops till you power her down, and as it slows the head shaking returns. All the parts are brand new and strait as I checked them as they were installed. Any thoughts, or is this normal for the bird? For the record I did try a different set of blades, and got the same result. They are tight, but not too tight. I also tried running her up to speed and leaving the stick at middle and then turning on idle hold so as she powered down, it was at 0 pitch and still the head shook.
Now for the TX settings, I just want to get and idea if these look correct.
GYRO Set at
67.5%
THRO CUR
NORM 0-60-80-90-100
STUNT 100-92.5-85-92.5-100
HOLD 0.00
PITC CUR
NORM 0-45-50-75-100
STUNT 0-25-50-75-100
HOLD “Same as above”
Swash MIX
AILE -60
ELEV +60
PITCH -70
REVERSE
THRO –N AILE –R
ELVE –R RUDD –N
GYRO –N PITC –N
SWASH TYPE
CCPM 120
She flies great, although you can feel the weight of this thing in the TX. Just hovering her for now as I am trying to get a feel for her (3 Batteries so far)
Anyway I would really appreciate the pros taking a close look over my settings and letting me know if I’m on the right track. I would hate to have something miss figured, and she fall out of the sky.
Thanks again
dxl007 is offline        Reply With Quote Quick reply to this message
Old 06-16-2008, 02:52 AM   #2 (permalink)
YOur settings look OK although there does seem a lot of PITCH AFR - have you checked the pitch with a gauge - some degree of shake is common in the T600 as you describe - check you blades for balance and also blade tightness - they shouldn't move if you hold the heli on its side and give it a gentle shake - I would suspect they are a tad too loose
John
Old 06-16-2008, 12:56 PM   #3 (permalink)
Yes I have checked the pitch with a gauge, and it is spot on.
Old 06-16-2008, 02:48 PM   #4 (permalink)
Are you using the black or the grey dampeners? It sounds like you are using the black, stiff ones. Try the softer grey ones.
And very simple: Don't take off from concrete! Get softer ground to avoid ground resonances.
Cheers!
T-Rex 600 CF | VBar |TT|Plettenberg 30-12HE|JAZZ55-10-32|3X9252|9254|FF-6, FASST|Radix600|SLS3700ZX 10s packs
Azzurra is offline        Reply With Quote Quick reply to this message
Old 06-16-2008, 04:11 PM   #5 (permalink)
Sounds like your just a jack-a$$ to me
caldwellj629 is offline        Reply With Quote Quick reply to this message
Old 06-16-2008, 04:18 PM   #6 (permalink)
Real nice..... Thanks for your insite
Old 06-16-2008, 04:21 PM   #7 (permalink)
Anytime- just let me know if you need anymore advice, LOL
Old 06-16-2008, 04:31 PM   #8 (permalink)
Yeah you'll be the first one I call..... Clearly you're the MAN...lol
Old 06-16-2008, 04:45 PM   #9 (permalink)
Yeah- i hear that all the time but it never gets old !!!
Old 06-16-2008, 05:19 PM   #10 (permalink)
Did I miss something?
Megahertz is offline        Reply With Quote Quick reply to this message
Old 06-16-2008, 08:38 PM   #11 (permalink)
we are just kidding !!!!
