Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 12-31-2009, 06:28 PM   #41 (permalink)
Its "Dirt-Grinder's" brother
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote Quick reply to this message
Old 01-01-2010, 09:30 AM   #42 (permalink)
I just read all five pages of this thread. Please in simple terms what product and what parts should I lubicate on my V2.
pwb1 is offline        Reply With Quote Quick reply to this message
Old 01-01-2010, 09:40 AM   #43 (permalink)
Great question. I would like to know the same. Help us Luke pls I guess, all moving parts except servo's of course. Is there 1 lub that does all. Just a synthetic greace?
Cheers, OD.
If you make a mistake and learn from it, that's progress
2 x Nano heli's - now passed on to Megan, HoneyBee V1.....Awaiting test flight, T-Rex 250 V1, Hitec 5084MG tail servo, DX6i, Walkera 4#3A (it's in fairly good hands Bugster).
oliverdots is offline        Reply With Quote Quick reply to this message
Old 01-01-2010, 10:42 AM   #44 (permalink)
Certainly, if it moves, lubricant will help it! (Servos nearly always come pre-lubricated, so don't lubricate them. I guess the servo manufacturers think it is a good idea....as far as I am aware, they have been doing it for over 40 years...)
The main areas that will benefit are the areas that take the most loading; main gear, shaft bearings (main and tail). I like to try and work some into the swash as well. These are the parts that move continuously and can cause the highest loading for the motor. On a belt driven tail, I would also use a silicone on that, to keep the belt supple. There is an argument that it can help reduce static build up as well, which can cause glitching..
As for which lubricant....yep, pretty much any semi or fully synthetic will do it in terms of plastic and metal compatibility. There is not normally any silicone rubber on a heli (you don't want to put silicone lube on silicone rubber; it will swell up), so silicone is normally OK. I use Molykote PG65; one tub will last you a lifetime!
450 Bell 222, 450 Jet Ranger, HBFP Redbee Extreme, 500 size Blackhawk MH-60, 600 EP Spitfire, Sebart 342 30e, Davy Systems Flybaby, ST Models FW190, Micro SU26 & GWS P38. DX7s
Luke Warmwater is offline        Reply With Quote Quick reply to this message
Old 01-01-2010, 10:51 AM   #45 (permalink)
I run a fully synthetic oil in my dirt bike a ester 4 would that been fine also I have a synthetic chain oil. Thanks
Old 01-01-2010, 11:06 AM   #46 (permalink)
The chain oil will have "more cling, less fling"!
Old 01-01-2010, 11:37 AM   #47 (permalink)
Where did you get the Molykote PG65 from pls Luke
Cheers, OD.
Old 01-01-2010, 04:24 PM   #48 (permalink)
Try here:
http://www.rwgreeff.co.uk/molykote-p...eige-1kg-PG651
That 1kg pot will last a lifetime, literally!
Old 01-01-2010, 04:31 PM   #49 (permalink)
Thanks for that Luke
Cheers, OD.
Old 01-05-2010, 01:40 PM   #50 (permalink)
Wow, there is a LOT of information in this thread. At the risk of being a complete newbie, maybe the next time someone lubricates their HB they could take a few pictures and put them in here with a few words like lubricate here, don't lubricate here, etc. Pictures are worth a thousand words especially for clueless folks like me.
Luke, great job. I learned more about grease in 10 minutes than I ever thought possible!
USNA_91 is offline        Reply With Quote Quick reply to this message
Old 05-14-2011, 02:18 PM   #51 (permalink)
Luke, just to let you know that your information is still being appreciated. Thank you.
PassinThru is offline        Reply With Quote Quick reply to this message
Old 05-16-2011, 04:04 PM   #52 (permalink)
I think that thread should be a sticky in all Helicopter support forums on Helifreak. Many of us (including me) are using WD40 causing plastic parts to fail....
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 05-18-2011, 03:50 AM   #53 (permalink)
Nice to know it's of some help!
Old 05-18-2011, 04:30 AM   #54 (permalink)
Yep, great thread.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 05-18-2011, 12:55 PM   #55 (permalink)
Just checked and Luke's thread is stickied in the super sticky here.
https://www.helifreak.com/showthread.php?t=162565
Nearly had a senior moment and stickied it again
And hey Luke - great to see you here - must be almost 3 years now you've been helping us HBFP pilots
Cheers, Bugster
Bugster is offline        Reply With Quote Quick reply to this message
Old 05-18-2011, 02:11 PM   #56 (permalink)
I'm just hanging on for my pension!
Old 05-18-2011, 06:16 PM   #57 (permalink)
Mine should appear in around 2 weeks - retiring early because I had a decent offer for my business.
Just can't wait to have spare cash and time available for helis again. Want to fly 3D with HBFPs.
Better warn the UK suppliers to build up stocks of spares.
Cheers, Bugster
Old 07-12-2011, 12:53 PM   #58 (permalink)
Would something like the following be ok to use?
http://www.amazon.com/Jig-Loo-JIGUSA.../dp/B002AR379W
thanks,
cheve is offline        Reply With Quote Quick reply to this message
Old 07-12-2011, 01:08 PM   #59 (permalink)
I personally wouldn't use graphite as a lube..but a straight liquid....i think if the graphite got into any bearings it may be an issue..hoping someone can confirm?
HBV2, HBCP3, HBKING 2 FP, 4 Trex 450 Clones, Trex 500 GF, 500 Trex Clone, MCPX, MCX2 - 32 "Planks" and 5 Cars - 29 years of R/C and counting, and it's just getting WORSE!
check me out on youtube! www.youtube.com/jettamandan09
JettaManDan is offline        Reply With Quote Quick reply to this message
Old 07-19-2011, 03:04 AM   #60 (permalink)
@Luke Warmwater: thank you very much, this is really appreciated and your posting has been of great help!
spektrex is offline        Reply With Quote Quick reply to this message
