Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters > E5
Old 04-07-2012, 01:15 AM   #1 (permalink)
Exclamation Synergy E5 - Official Information Thread
The E5 project just started at the end of January. A prototype is flying at the moment and I will post pictures when I have the canopy sample. There are some new "original" features that could be easily duplicated which is why I have chosen to not release pictures. As you could imagine, this is a very competitive market and I need to take advantage of every original design aspect.
A little more information about the E5 :
- 550 Class Electric Heli
- 10mm main shaft / 8mm head axle
- Machined Delrin Helical Main Gear
- Shaft Driven Tail System
- Monster Mod 1.25 Bevel Gears and Counter Gear
- Lower motor shaft bearing block
- Third main shaft bearing block
- Direct servo to swash CCPM (very similar to the E6/7)
- 52mm inner frame width for multiple motor options
- 25/30mm motor bolt width for multiple motor options
- Washout Arm mounting integrated into the head block
- 6S - 12S battery compartment capability (I am currently running 6S 5000mah packs)
- Easily stretched to 600 class helicopter with E6 parts
I wish I could give you a release date but as until I am closer to pre-production it is very difficult to estimate. Historically models that I have started in January are released in the summer.
Thanks,
Matt
00boto is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 01:55 AM   #2 (permalink)
Thanks for the update Matt!
kdfi is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 03:17 AM   #3 (permalink)
Thanks for update, I am very interested in this model!
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 08:59 AM   #4 (permalink)
Felt is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 08:59 AM   #5 (permalink)
Thanks for the update Matt. I am really looking forward to this one. A couple of questions.
1.) How does it compare in size to a Trex 550 or Logo 500se?
2.) Will it come packaged as just the E5 or as an E5/E6?
3.) Will the head have an integrated swash driver like the KDE upgrade or separate like the E6?
Gscott is online now        Reply With Quote Quick reply to this message
Old 04-07-2012, 09:19 AM   #6 (permalink)
Thanks,
Matt
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 11:15 AM   #7 (permalink)
Gscott,
The E5 is very similar in size to the Trex 550, I recently placed the E5 right next to a Trex 550 and the size comparison was very close.
Right now I am planning on releasing it only as an E5.
The head does have integrated swash driver which is very cool looking.
Matt
Old 04-07-2012, 11:30 AM   #8 (permalink)
What's your AUW at the moment Matt with 6S 5000's?
BennyTRD is offline        Reply With Quote Quick reply to this message
Old 04-07-2012, 10:43 PM   #9 (permalink)
Hope it come's out soon as I've been wanting to pick up another 550 bird.
How many parts will interchange with the E6/7..Main gear,boom mounts,tail box,etc?
What is your current setup? motor/esc,blades
Do you plan on coming out with some 550 Rail blade's.. Maybe some 556's
George
I don't crash. I land with style.
Bowtech and Hoyt
Tradhunt is offline        Reply With Quote Quick reply to this message
Old 04-08-2012, 10:34 AM   #10 (permalink)
I would love a synergy that can compete with my x5. The x5 has become my go to heli because of size, power to weight, and only needing 6s. I can keep it in my car and if the mood strikes I can charge and be in the air I about 25 minutes. I would love to have a synergy to do this with.
Old 04-08-2012, 03:24 PM   #11 (permalink)
This will be my first Synergy. I love 550-sized helis. This can't come soon enough.
kw_rc is offline        Reply With Quote Quick reply to this message
Old 04-15-2012, 05:49 PM   #12 (permalink)
Thumbs up
I think this will be my start into the world of electric heli's. Have resisted (just!) upto this point as I have investment in nitro.
Would like some info on motor, esc combos so I can start getting stuff together pre kit release.
Sponsored by VISA
Mylee is offline        Reply With Quote Quick reply to this message
Old 04-15-2012, 06:42 PM   #13 (permalink)
Mylee, motor and esc combos will depend if you want to run it on 6S, 8S, 10S or 12S.
Team Rail blades,
Team Scorpion motors,
V-Team
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 04-16-2012, 01:38 AM   #14 (permalink)
Yep, I think I read that Matt is testing a 6s set-up at the mo. this is the route I would be looking to take
Sponsored by VISA
Old 04-16-2012, 10:23 AM   #15 (permalink)
6S I would use 80HV ESC and around 1100 kv motor.
Team Rail blades,
V-Team
Old 04-16-2012, 10:35 AM   #16 (permalink)
You don't need a HV controller for 6S and under.
beeflyer2 is offline        Reply With Quote Quick reply to this message
Old 04-16-2012, 06:37 PM   #17 (permalink)
You are right beeflyer, but if you want to put bigger packs then you would already have the ESC no?
Team Rail blades,
V-Team
Old 04-16-2012, 09:55 PM   #18 (permalink)
Yea but you'd need to change the motor and pinion out too. On my Logo 500 6s V-bar running 560 RT blades stick banging it I was able to hit 180 amp peaks using a Ice 100 so on 6s I'd make the ice 100 the smallest esc you should use IMHO!
Tom
litespeed is offline        Reply With Quote Quick reply to this message
Old 04-22-2012, 05:00 PM   #19 (permalink)
ohhh yeah 12s 550 please, if you need me to smack around a prototype shoot me a pm lol
Trex 700e
hamstar78 is offline        Reply With Quote Quick reply to this message
Old 05-03-2012, 02:41 PM   #20 (permalink)
Matt,
When do we get to see the first teaser pic? I've always wanted to try a Synergy and I think the 550 will be it. Anything with unstrippable 90 size tail gears gets my money.
OnTheSnap is offline        Reply With Quote Quick reply to this message
