Old 08-15-2015, 09:36 AM   #21 (permalink)
Originally Posted by PTFlyer View Post
I stretched it and am running 350mm main and 72mm tail blades...
It's a 6s setup with a
cc lite 50
NTM 2938 1700kv
tgy 306HV all around
Vortex VX1n
2900 head speed
That motor heat up a lot for you?
Minicopter Diabolo 550 w/ MSH Brain
Gaui X3 w/ Mini KBar
250 Pro DFC w/AR7200 (needs some costly fixing)
thepiper92 is offline        Reply With Quote Quick reply to this message
Old 08-15-2015, 09:47 AM   #22 (permalink)
the first picture shows where I have the sat mounted...
the second picture shows the vortex mounted inside the frame above where the sat is mounted
the little servo plug on the back is a very short extension where I can plug the vortex pod into without having to get at the unit to plug in,...
ID:	602836   Click image for larger version
PTFlyer is offline        Reply With Quote Quick reply to this message
Old 08-15-2015, 09:48 AM   #23 (permalink)
Nope....surprisingly that motor runs very cool.....and I hammer this heli
I run really high end stuff on my goblins but this heli is my "fly it like a stole it" heli, and I'll tell you what ....the guys at the field are amazed as how well it flys and the power it has...
and how well it crashes, and it crashes.....alot
Old 08-15-2015, 09:57 AM   #24 (permalink)
Hmm, I have the same motor and it will fry an egg. Must be gearing or airflow on my X3
Old 08-15-2015, 09:59 AM   #25 (permalink)
really.?.....check your gear mesh and make sure it's not too tight...cause I gave a guy at my field my spare motor, and his runs just as cool as mine
also check your timing and pwm
I'm running out....but I'll check my castle settings and let you know what timing and pwm I am running and post them later for you
Old 08-15-2015, 10:11 AM   #26 (permalink)
Mesh is definitely good, running at 2900 and 3200 HS. Could be the longer blades.
Old 08-15-2015, 02:28 PM   #27 (permalink)
Awesome heli's everyone. I'm going to maiden mine this afternoon.
Dstaks is offline        Reply With Quote Quick reply to this message
Old 08-15-2015, 05:56 PM   #28 (permalink)
Hope the maiden went well for you....
The motor I am running I have set at
Timing Normal 5
PMW Rate 8Khz
Old 08-15-2015, 06:00 PM   #29 (permalink)
Timing Normal 5
PMW Rate 8Khz
Hmm, I'll have to check mine. Sounds like what mine is. Perhaps it's blade length, weight, gearing and/or airflow. The motor works well, just gets hot if it's already a warm day.
Old 08-15-2015, 08:27 PM   #30 (permalink)
Familyguy, just maidened the x3 today. Thanks for such a good looking heli! Nice low hover, felt very smooth!
(I.Y.A.O.Y.A.S.)
Old 08-16-2015, 12:00 PM   #31 (permalink)
Tell ya what.
I have both X3 and 450pro, belted both, I enjoy more the pro than the X3.
More flying time that's why.
Some people comes and tell that they get 4 or 4 1/2 mins of flying time.
Please tell me your set up an I will get the same gear as you.
You are flying the X3 and getting excited when you have to stop at 3 or 3/12 mins at the most.
Yes, I like the X3, but flying time is less.
Same servos and FBL controller on both
salrica is offline        Reply With Quote Quick reply to this message
Old 08-16-2015, 12:28 PM   #32 (permalink)
Originally Posted by salrica View Post
Tell ya what.
2500 HS with 360 blades, and 1400mah Gensace, 6-8 minutes is not a problem. Basic flight though. 4-6 with sport/mild 3D
Old 08-16-2015, 12:48 PM   #33 (permalink)
Motor?
Pinion?
Governed?
Old 08-16-2015, 04:51 PM   #34 (permalink)
Tell ya what.
For what it counts I get about 7 minutes on the 450L, stock motor, stock esc, no governor, head speed at about 3200rpm, 3S, 2200mah 40c gens ace, 11t pinion, landing at 80% used, sport flying.
jgiannakas is offline        Reply With Quote Quick reply to this message
Old 08-17-2015, 06:18 AM   #35 (permalink)
Glad your happy with it. Enjoy!
Two Oxy 4 Max's, Two Raw 420's, Raw 580 w/Xnova, Raw 580 Nitro w/OS55, Futaba 16IZ, iKon 2's, Hobbywing, .
Robbe Futura Sport, Schluter Mini Boy-shelf queen's.
Marc
Family Guy is offline        Reply With Quote Quick reply to this message
Old 08-17-2015, 08:22 AM   #36 (permalink)
What fligt tines were you getting w those batteries and the 13t pinion again?
(I.Y.A.O.Y.A.S.)
Old 08-17-2015, 09:52 AM   #37 (permalink)
Governed at 2950 RPM head speed I would get 4 mins. I didn't like the 2950 head speed or the 4 mins flight time ether. The 450 Pro would allow me to have both the higher head speed that I liked and the 5 mins of flying too. So I'm with salrica on this one. The 450 Pro in the pix's I got used and rebuild it and the electronics that was in your X3 is now in that 450 Pro. By the way that's a good looking 450 Pro you got there too!
Marc
Old 08-17-2015, 04:21 PM   #38 (permalink)
Here's my fleet... Haven't flown the Hughes in anger yet. Still a relative noob, and prefer gentle circuits... cos I can't do owt else lol. Having fun though, and learning loads with my HK450GT!
Regards
Ian
... full Man Cave
lainchy is offline        Reply With Quote Quick reply to this message
Old 08-17-2015, 07:09 PM   #39 (permalink)
Here's my primary heli - Tarot 450 PRO V2 with a DFC head and a bunch of aluminum upgrades - metal base, battery, and nose plates, integrated tail unit, dual slider metal tail, etc. Runs an SK3 motor, YEP40A esc, KST 215 cyclic and 515MG tail servos, FrSky D4R-II RX (for taranis) mated with yellow FBL unit....
Final pic is of the current heli fleet - second 450 is a near identical clone to this one (same upgrades) but has a belted tail and runs the TGY clones of the KST servos. Otherwise all same gear.
The 250 is a CopterX clone with a bunch of Align replacement parts and a Robird G31 FBL
mCPx BL is out of commission with a bad main board....
ID:	603375   Click image for larger version
ID:	603376   Click image for larger version
ID:	603377   Click image for larger version
boykster is offline        Reply With Quote Quick reply to this message
Old 08-18-2015, 03:26 PM   #40 (permalink)
Just got into helis this is my TREX 450 ( I bought a raw friction clone off ebay and it was junk but I stole the canpoy off of it lol) just finished painting the skids, and stabilizers red to match
scgeek12 is offline        Reply With Quote Quick reply to this message
