Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree2Likes
Old 09-18-2015, 03:01 AM   #321 (permalink)
Suggestions....
What about a Urukay theme Urukay? The kids love him apparently
Goblin 380, 420, 500, 570, 700. Soon RAW 420 & RAW 6s Piuma
HeliAxe is offline        Reply With Quote Quick reply to this message
Old 09-20-2015, 05:07 PM   #322 (permalink)
So i finally got to maiden the Urukay this weekend (2 bladed head) and WOW . I love it. Running on 4000mah 30C packs, i was worried about it, but they held up fine for 4min flights.
The manual calls for allowing the gears to cut in during the first few flights and also says to maiden it at 1550 -1600 HS. They also say that the heli will exhibit some odd behavior during the first few flights. Well, i get this cyclic wobble at maybe 1200 - 1300 HS that dissapears with more HS. Even when auto'ing the heli at the end of the flight under only the blades' inertia when passing through that range of HS, it develops the wobble before coming down. Is this normal?
Angelo
SAB Urukay HPS-3 Brain || Kraken700 || Goblin 650BT Ikon || X380 Ikon || Trex500 Pro Ikon
Angelo A is offline        Reply With Quote Quick reply to this message
Old 09-20-2015, 10:15 PM   #323 (permalink)
Yes its normal, you will probably find it gets better after a few flights as the dampers bed in a little. The wobble will move down lower in the RPM range so it will be out of the range you would normally fly, but you might still see it at the end of an auto.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 09-24-2015, 04:30 PM   #324 (permalink)
So has anyone been able to mod (or just buy) a precision bell crank for the tail, Lynx or similar? Lynx has no three blade options so I would have to reverse engineer the brass slider portion to attach the three bladed "spider" pitch link.
My tail is fine, but you know.... idle hands
Goblin 380|HD500
Destroyed: Urukay
|Goblin Speed
DX9|#652
earhythmic is offline        Reply With Quote Quick reply to this message
Old 10-11-2015, 07:48 PM   #325 (permalink)
OC Helifreak
my Uru has close to 100 flights already and still flies like new. had 3 blade strikes and one tail strike with the ground resulting in a couple replacement parts but that's it.
Edge540V3 DA120
Urukay HPS3
KSE700 HPS3
Mamba DA70
Airboss is offline        Reply With Quote Quick reply to this message
Old 10-18-2015, 09:26 PM   #326 (permalink)
Well I think that's it for me and the Urukay.
Goblin 380|HD500
Destroyed: Urukay
|Goblin Speed
DX9|#652
Old 10-18-2015, 09:32 PM   #327 (permalink)
Sorry to see that man.... what happened
jsbach#1 is offline        Reply With Quote Quick reply to this message
Old 10-18-2015, 09:38 PM   #328 (permalink)
ouch cant like that
Goblin 770,700,630,630C,570 700 C Goblin Speed
Scorpion Power Life too short so Fly
tdf1946 is offline        Reply With Quote Quick reply to this message
Old 10-18-2015, 09:50 PM   #329 (permalink)
Looks painful!!
Angelo
Old 10-18-2015, 10:24 PM   #330 (permalink)
Looks like a battery lead came unsoldered, I was using the BEC on the HobbyWing 160. I was coming out of a pretty fast Cuban 8 and right when I leveled off about 10 feet off the deck the heli became unresponsive, and a split second later it pitched itself forward hard and lawn darted itself. It happened pretty far out in the field, but imagine if it was coming towards me!
Let this be a lesson...I have an Ultraguard on board, but at the end of the previous flight I noticed my electronics didn't stay on when I unplugged the main flight pack. I figured my setup has been trouble free thus far so I'd troubleshoot the UG when I got back home. Famous last words.
Goblin 380|HD500
Destroyed: Urukay
|Goblin Speed
DX9|#652
Old 10-19-2015, 01:11 PM   #331 (permalink)
OC Helifreak
BEC on a 700 ? bad news dude but sorry for your loss
Edge540V3 DA120
Urukay HPS3
KSE700 HPS3
Mamba DA70
Old 10-20-2015, 12:32 AM   #332 (permalink)
are you going to rebuild or sell whats left
Old 10-20-2015, 01:06 AM   #333 (permalink)
Best BEC in the hobby with plenty of guys running it, didn't think I was that far off base. Was previously running a Scott Gray Reactor but that's still a single point of failure. Pick your poison I guess.
Not much to rebuild, all of the salvageable parts fit in a 2x3 inch bin. I've been eyeballing the Goblin Speed for a while so I'm leaning towards that set up for 3D.
Goblin 380|HD500
Destroyed: Urukay
|Goblin Speed
DX9|#652
Old 10-20-2015, 07:00 AM   #334 (permalink)
Oh dude that sucks
Hope you have better luck with the Goblin Speed / 3D.
I love flying the Goblin speed 3D style on my sim. Looks awesome
Old 10-20-2015, 11:35 AM   #335 (permalink)
Actually the HPS3 head is in pretty good shape... Three bladed Goblin Speed anyone?
Goblin 380|HD500
Destroyed: Urukay
|Goblin Speed
DX9|#652
Old 10-20-2015, 07:05 PM   #336 (permalink)
OC Helifreak
I always run a 2S lipo Rx batt with a plug no switch or regulator to power the Rx and use of HV servos on all my big $$$ toys. theres plenty of room and the extra weight is your insurance policy against failure.
Edge540V3 DA120
Urukay HPS3
KSE700 HPS3
Mamba DA70
Old 10-20-2015, 07:48 PM   #337 (permalink)
I have a Speed I was thinking bout converting
Old 10-29-2015, 08:12 AM   #338 (permalink)
Has anybody looked up the parts to convert an Urukay to an Urukay Competition? Canopy+boom and landing skids are the obvious ones. How about main frames and tail side plates? Are those mandotary? I was considering a custom canopy for my Urukay so I might as well do a Competition one...
| SAB GREEN GOBLIN 700 | SAB URUKAY | Synergy E5 | Synergy E7SE | 700 Dominator | Futaba 18MZ | T-Rex 500 ESP DFC | Mcpx BLS | Red Bull BO-105 | 180CFX | Kyosho Hyperfly | TBS Disco | Disco Pro | Disco Pro AMOB | Caipi | www.youtube.com/hizlimax |
Hizlimax is offline        Reply With Quote Quick reply to this message
Old 10-29-2015, 01:11 PM   #339 (permalink)
OC Helifreak
Cool
safety first when it comes to these big helis, the bullet proof connection from battery to Rx helps me fly with less stress
Edge540V3 DA120
Urukay HPS3
KSE700 HPS3
Mamba DA70
Old 10-31-2015, 08:54 AM   #340 (permalink)
Looks like Urukay Competition uses new 725mm main blades and 104mm tail blades. It makes more sense to buy the kit.
