Old 09-09-2014, 02:50 PM   #1 (permalink)
Default ZYX-S2 anyone done this?
have a zyx-s2 brand new..
1. I would like to know if we can use a full JR/ spektrum receiver ( not satellite only)...on th s2 ? or am I stuck on the satellite only system..?
2. wont connect on windows 8... win7 perfect..no problems
tarot is so vague.....any gurus...out there?
8sman is offline        Reply With Quote Quick reply to this message
Old 09-09-2014, 07:29 PM   #2 (permalink)
1) Yes you can hook it up to a conventional receiver. See the diagram in the receiver tab in the setup page with conventional receiver type selected.
2) assuming you are using a satellite, you should bind the satellite with the conventional receiver, then plug it in as shown on the non conventional receiver type page.
If you still have conventional receiver type selected in the dropdown, it may be the reason for the blinking yellow.
But first,
For the unconnected problem, make sure the connector is seated well in the ZYX-S2. The shrink wrap may be holding it out some.
Once I had to file down some of the heli frame to make it fit in well.
One more thing. I dont see any green button on the zyx assistant software. Perhaps you are using the older ZYX-S software? That wont work with the zyx-s2
jbilliter is offline        Reply With Quote Quick reply to this message
Old 09-09-2014, 08:06 PM   #3 (permalink)
thnx jbitliter...but you did not answer my question...
my question is>
can I use the Tarot zyx-s2 using a full spektrum/JR RECIEVER..(NOT Satellite only) ?
IM USING 1.1 tarot zyx s2... it recognizes the Com port. but wont connect to tarot..no matter what... yes there a green button next to com port.
Old 09-09-2014, 08:15 PM   #4 (permalink)
I thought my item 1) answered it. Yes you can use a conventional receiver. The picture shows the hook-up
The green arrow next to the comm port is always green even if there is no dongle or you select the wrong comm port. Success communicating is indicated in the lower right of the page.
Name:	convventional receiver.jpg
Old 09-09-2014, 09:11 PM   #5 (permalink)
I tried that....it wont connect with software...1.1 no matter what I do..i did get the light t turn solid red.
Old 09-09-2014, 09:39 PM   #6 (permalink)
That green arrow is a selector for the correct comm port. Without the dongle plugged in
You may see 1 or 2 coms COM1 and COM3 for example. When the dongle is plugged in you should see a new COMx show up (mine shows as COM4). The new one is the one you should select.
What operating system are you using. Did you install the usb driver for the op system. Its in the zyx install folders
Old 09-09-2014, 11:11 PM   #7 (permalink)
its wndows 8....then im screwed..,, had my brother use his laptop win7.. connected perfect...I don't have myown win7 computer anymore.. Damn,u win8 !!
Old 09-10-2014, 05:56 AM   #8 (permalink)
If you're getting a code 10 error when you plug in the USB dongle you have the wrong USB driver. Are you seeing a "com 4" in the drop down arrow box in the software when you try to connect? Select com4.
Nihilistic is offline        Reply With Quote Quick reply to this message
Old 09-10-2014, 06:03 AM   #9 (permalink)
Check out this thread and see if it helps. Not sure if it pertains to the S2 as well as the ZYX-S.
http://www.rcgroups.com/forums/showp...postcount=6444
Old 09-10-2014, 11:14 AM   #10 (permalink)
com pertains to which port u connected the usb...it should automatically be detected by the software...IT CONNECTS FINE ..ON WINDOWS 7..
Old 09-10-2014, 12:35 PM   #11 (permalink)
Former Microsoft Desktop Operating Systems Support Tech and active MS Beta Tester here..
Win8 sucks.
This is a classic hardware incompatibility issue. MS had them with I was supporting Win3.x, Win9x, NT, Win2K and WinXP.
Tarot uses a standard run of the mill USB to Serial adapter based on the Prolific PL2303 chipset. There are versions of this chipset that are supported by Windows 8.
Check this link: http://www.prolific.com.tw/US/ShowPr...id=225&pcid=41
The ZYX will flash the yellow LED if it does not have signals from a receiver. If you are going with a conventional receiver configuration YOU MUST HAVE the slots marked Pit/Ele/Aux, Ail, and Rud populated and connected to the appropriate slots on the receiver. The receiver must be bound to a TX and both TX and RX must be powered up. Make sure the connectors are fully seated.
If you go through Setup and you cannot get either roll or pitch (nose up/down) to work properly, try swapping the servos plugged into channels 1 and 2 at the gyro.
After you have completed Setup, be sure to click "WriteFlash" to insure the current settings have been save to the gyro. Before you close the software, click 'SaveConfig' and save the current configuration data.
Oldgazer is offline        Reply With Quote Quick reply to this message
