Go Back   HeliFreak > R/C Electronics Support > bavarianDEMON/HeliCommand
bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support
Like Tree1Likes
Old 12-25-2012, 09:46 PM   #41 (permalink)
Seasick78, i just wanted to say THANKS for all the videos you did, i have the same Transmitter, and i was so happy watching all of your videos, my HC3-SX is in the way, and will be used on my Goblin 770, i will maybe first use it on a smaller heli, the 500 first to get used to it !
Again thank you !
mmarmouz is offline        Reply With Quote Quick reply to this message
Old 12-27-2012, 12:06 AM   #42 (permalink)
You are both quite welcome. I'm glad they helped you get started!
Team - "Self Interests" -
Old 12-29-2012, 01:25 PM   #43 (permalink)
BKF
Josh,
I noticed you have a video on the tail, but do any of the videos show the swash being controlled by the HC3SX as you tilt it around? I'd just like to see how yours reacts compared to mine, on the bench.
BKF is offline        Reply With Quote Quick reply to this message
Old 12-29-2012, 02:56 PM   #44 (permalink)
I don't have a vid of that. I'll make one for you later tonight if I can.
Old 12-29-2012, 03:37 PM   #45 (permalink)
BKF
Thanks, Josh!
I've got everything all set up now... Just adjusted the collective travel so I'm getting around 12 degrees or so +/- using an old E-Flite pitch gauge (really need to get a digital unit!).
Still a little worried about the movement I'm seeing on mine, but if yours does the same on your Goblin, I'll feel a lot better about it before I try to maiden her.
Old 01-08-2013, 05:02 PM   #46 (permalink)
Thanks Josh.. great job! I almost have mine setup, I got the heli flying really nice but I running into trouble getting my bailout switch right. I am using a dx7s and have all the sliders going in the right direction when moving the switches,however I don't get the blinking green light. Mine moves to -100 on the diagnose page like yours but no flashing light. I am missing something....lol
Kurt
Blade 450X HC3SX, Nano CPX
Trex 250 G31 Black Widow
Tarot 450 HC3SX, Trex 500 DFC Pro HC3SX, DX7S
varmit is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 05:11 PM   #47 (permalink)
Are you getting two solid green lights on the diagnose page? You may try increasing the value for rescue to greater than -100, like -105.
Then, remember you will only see the blinking light on the unit if the USB cable is disconnected and rescue is activated.
Old 01-09-2013, 08:40 AM   #48 (permalink)
Just an update Josh. I got it figured out, as I (stupid me) didn't have the "acro" tab selected.Had "pos & inv" instead. Heli fly flawless!!!
Thanks to all in this forum for the helpful tips.
Kurt
Old 01-09-2013, 08:47 AM   #49 (permalink)
Great news. Thanks for the update.
Old 01-11-2013, 06:53 AM   #50 (permalink)
Hi Seasick78, hope you are doing fine,
i am happy to let you know that i just finished yesterday the initial setup, as i have the same TX as you, it was so easy watching your videos !! thanks !
Everything is working the way is supposed, the HOR and bailout, just one question, as the bailout switch is a release switch, do you have to keep holding it until the heli is rescued ? or you just have to push it once and release quick ?
Old 01-11-2013, 07:23 AM   #51 (permalink)
Default HERE are the set-up video's!!!!!!!!!
For rescue you and how I have it setup, it needs to be held. As soon as you let go it goes back to normal. If you prefer to have it stay on then you would want to use a regular switch like I use for horizon mode, instead of the momentary switch.
I prefer momentary for rescue and standard for horizon.
Old 01-11-2013, 07:44 AM   #52 (permalink)
Me too, just wanted to make sure i know how to use it for the first time, so if i get it right, as long as i hold it, i will continue to climb...
Old 01-11-2013, 08:32 AM   #53 (permalink)
Correct
Old 01-11-2013, 11:09 AM   #54 (permalink)
Correct
thanks
Old 01-11-2013, 07:11 PM   #55 (permalink)
Well now i am fine tuning my mixer settings, and i have a small issue,
well i am getting my 0 degree in middle stick no problem on both blades, i have increased my collective travel to 80 to be able to get ~12.2 degree at max pitch, but my min pitch is 11.5 and not ~12, i mess with the collective offsert, i will loose my 0 degree in mid stick, what to do ? i know that i have a perfect 90 degree in my servo horns, and all linkages have the right length, i also level the swashplate. is .5 .6 not an issue at all ?
is it ok to have a not equal negative and positive pitch ? my pitch curves are linear on all modes -100/-50/+0/+50/+100
Also the Aileron travel value i set to have my 8 degree, this is with the pitch gauge in the front of the heli, so i guess to determine my elevator servo travel, i need to put the gauche in the side of the heli and push the cycl to front and back to determine my 8 degree ? am i right ? just want to make sure.
thanks
Old 01-29-2013, 02:40 PM   #56 (permalink)
Thank you
I was about to sell my hc3sx I am going to give it one last shot
with these videos I see where I went wrong
Very much appreciated
do you know if anyone has gone into as much detail on the jr radio
tx
Nic
KDS NIC is offline        Reply With Quote Quick reply to this message
Old 01-29-2013, 02:45 PM   #57 (permalink)
There are information posts but not videos to my knowledge. The software is the same no matter which radio. You just need to know the radio to make it all mesh together.
Old 02-03-2013, 11:04 AM   #58 (permalink)
Josh:
Your videos were extremely helpful in setting up the horizon and bail-out modes on my HC3Sx (on a Synergy E7). These videos are outstanding. As I sat at my bench and watched the mixes do their work to activate bail-out and horizon I thought, I have to thank this guy. So thanks very much. Using separate model profiles in the radio is a totally great way to go.
Your work is much appreciated .
Tom DiBella
Oakland, New Jersey
Tom D AMA # 920386, IRCHA # 3396
The ox is slow but the earth is patient.
TJ Present is offline        Reply With Quote Quick reply to this message
Old 02-28-2013, 12:16 AM   #59 (permalink)
Tom,
Thank for letting me know the videos and suggestions were helpful for you as you got started. I'm glad you were able to get things setup and hopefully you are enjoying your HC3sX equipped heli.
Old 03-09-2013, 08:16 AM   #60 (permalink)
noob question on the hc3x base using dx8. i have the head gain bound to the gov switch. what is a good starting point for the gain i have mine set to +50. or should i set it to 0?
Goblin 700 Ikon 560ult cc160hv
Scale Bell 222 T700, Agusta A109 Grand 700
Blue Thunder 700 RCHN #365
G500,E5 12s,600np dfc, t500 dfc beater
Jackass1277 is offline        Reply With Quote Quick reply to this message
