Old 08-11-2015, 10:56 PM   #1 (permalink)
Default Can't figure out tail wag
Can't figure out tail wag on my first 450. Bought it already built but not properly setup mechanically or electronically. I finished the work(to the best of my knowledge) and this is what I cannot figure out. The helli will start doing this tail wag which you see in the video. I originally figured it to be a problem with to much gyro gain on tail but after i figured that out and set it in to 50-60-70% it does the same thing on all 3. Any ideas what could be causing this?
tail wag (0 min 49 sec)
[Super CP, Master CP x 2, V120d02s, V911 x 2, Tarot-Align-ALZRC-Fusano Franken 450]
Tseeley0203 is offline        Reply With Quote Quick reply to this message
Old 08-12-2015, 12:03 AM   #2 (permalink)
Tell us a little more about your setup - which fbl unit are you using?
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8
Skidpad is offline        Reply With Quote Quick reply to this message
Old 08-12-2015, 01:59 AM   #3 (permalink)
tail wag - YouTube
Are you sure the tail is setup correctly direction wise on the controller? I've never seen a heli wag so much on the ground! Make sure the gyro is correcting the right way. Also try lowering the mechanical gain by moving in the rudder servo arm one hole in.
jgiannakas is offline        Reply With Quote Quick reply to this message
Old 08-12-2015, 02:51 AM   #4 (permalink)
Try the Chinese weight mod on the tail grips. Even if you have the factory weighted grips, the extra Chinese weights counteract the tennis racket effect. It will greatly improve the tail authority. It worked for me.
Trex 550e•Blade Fusion 480•Blade 330s•Blade 230s Smart•MSH Protos 380 Evo •OMP M2 Explore•OMP M2 V1•(2)OMP M1• Goblin Fireball•Blade Fusion 180• Spektrum NX8
Victory Motorcycles:2013 Victory Cross Country•2007 Victory Jackpot
kla912000 is offline        Reply With Quote Quick reply to this message
Old 08-12-2015, 03:23 AM   #5 (permalink)
As said, it will improve tail authority and will give you good benefits when flying but in this instance it feels like something is just not setup correctly - you dont need this mod to have a solid tail, only a higher performing one
Old 08-12-2015, 03:43 AM   #6 (permalink)
Tail gain settings can be highly variable based on many factors (ball link distance, helicopter, servo, tail blades, etc).
Try lowering the gain until it will spool properly.
Also try spooling up with the main blades OFF until you can bump the tail around without wagging or other unexpected behavior. If it is on a smooth, flat surface, you'll be able to do this easily and safely. As you'v noticed, you're at risk of a crash/tipover with a unpredictable tail like that.
Russell Harding is offline        Reply With Quote Quick reply to this message
Old 08-12-2015, 07:42 PM   #7 (permalink)
I am using a Turnigy 3d-h v1 and tail servo would be a wk-2601h.
Old 08-12-2015, 07:47 PM   #8 (permalink)
Yes it works perfectly when i disconnect the motor and pivot the heli by hand on the ground. I will try moving it in a notch on the horn like you say. Any information will help.
Old 08-12-2015, 07:51 PM   #9 (permalink)
Good idea. That sounds a lot safer to dial the gain in. But Does it not matter that it's not fighting the torque from the main blades?
Old 08-12-2015, 07:54 PM   #10 (permalink)
There is minimal torque when the heli is at zero pitch on the ground, even with the main blades on.
I've found that if you have massive tail problems, or massive over-gain on the tail, it will wag without the main blades on on the ground.
By testing without main blades, you will be able to see if the tail behaves as expected and turns and stops as commanded. You'll know if you're in the ballpark with a bigger safety margin.
Old 08-16-2015, 03:59 PM   #11 (permalink)
go through the set-up again you did something wrong .
possible wrong type servo selected
I'm not familiar with your fbl unit but I can tell it's set up error
Spending time, Paying attention
Bladefx is offline        Reply With Quote Quick reply to this message
