Go Back   HeliFreak > R/C Electronics Support > Spartan RC
Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support
Old 03-25-2016, 09:28 AM   #1 (permalink)
Default Spartan vx1e question
I've got a Compass 550 Ultimate, running a 6s setup, with Scorpion HKIII 4025-1100KV motor and castle creations 120hv edge speed controller.
MKS HV1220 on cyclic
MKS HV HBL 669 on tail
Also, running a separate on board 2s to power the electronic.
I will be installing a spartan vx1e, which is running version 3.01 firmware and
Should the spartan be updated to the latest M6 v4.52?
Anyone got the configuration setting they would like to share on the spartan setup to get me off the ground?
Last edited by ssrobzoom; 03-28-2016 at 07:55 PM.. Reason: Not a stock motor but a Scorpion
ssrobzoom is offline        Reply With Quote Quick reply to this message
Old 03-25-2016, 09:36 AM   #2 (permalink)
When I get home tonight I'll send you my settings.
dominator is offline        Reply With Quote Quick reply to this message
Old 03-25-2016, 10:08 AM   #3 (permalink)
If it's a brand new setup I would always start by updating the Vortex to the latest firmware. In this case it would let you use the electronic governor if you wanted.
Also, somebody sharing settings doesn't avoid you going through the setup, there isn't really a lot to be gained there. You still need to work through all the setup steps to ensure its all configured correctly.
The good news is that the Spartan Studio software guides you through everything, so it's pretty easy.
I also have a guide that walks you through everything you need from start to finish:
https://www.helifreak.com/showthread.php?t=715148
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 03-25-2016, 10:35 AM   #4 (permalink)
Definitly update. And there are good default settings in the Spartan. Even presets such as 3D and Bert Kammerer settings.
Goblin 770 Comp, Raptor E700, T Rex 450-600-700 DFC, 600N, Blade NCPx-130-180. Citizen 778
HEXAHYDRATE is offline        Reply With Quote Quick reply to this message
Old 03-25-2016, 11:59 AM   #5 (permalink)
+1 on doing the update. Also I've found that the spartan flys a little better on the 550u using 20-21 mm servo horns. So if you have a set, use those. I'd also recommend using the spartan gov if you have an rpm sensor.
Old 03-25-2016, 03:05 PM   #6 (permalink)
Should I enable the gov. setting?
Old 03-25-2016, 03:36 PM   #7 (permalink)
Start off without the governor, on any flybarless system it's best to get the tail gains right before you touch any governor.
