Old 11-07-2009, 03:43 PM   #1 (permalink)
Default Dx6i DIY backlight mod.
Hello fellow freaks.
I just made my own DIY LCD backlightpanel for my dark dull dx6i-screen:
I tought I´d share the process with you, so you could try it for yourselves.
The parts I used were:
  • 4 x 3mm 3,2v 20mA blue LEDs.
  • 4 x 120 ohm resistors.
  • A scrap plexiglass piece ca. 68 x 38 mm
  • Some thin wire I had laying around.
Here`s a simple wiring diagram. (Alot more illustrative than pictures)
Okay, to the process.
First I cut the plexi to size, and filed 4 notches for the LEDs with a needle file.
Then I matted one side with some fine grit sandpaper.
I glued some white paper to the un-matted side. Go gentle on the glue (not like me), use a hotglue gun just around the border of the plexi.
Onto the soldering!
I trimmed the anode (long leg) on the LED and the resistor and soldered them together, as showed on the left.
Then I used a tiny dab of hot glue to fasten the LEDs to the plexi.
Notice the resistors on the LED anodes pointing together.
Then I soldered the resistors on the LED anodes together, on each side of the panel.
Then the cathodes got bent to the paper (back) side, and soldered.
Then I wired the 4 anodes and the 4 cathodes together on the backside, and soldered one long wire for + and one for - power.
The resistor (anode) side is + and the long LED leg (cathode) side is -.
I tapped into the points in the dx6i for power, showed by vseries here
The result:
Notice the gluespots.. They doesn´t show through the LCD though.
Then I just showed the backlight-panel behind the LCD-panel, and wired the powerwires to the two points in the dx6i.
In the dx6i:
(The glare in the corners isn´t that bad in real life..) The light is evenly distributed over the whole LCD, I promise!
Now I´m prepared for the long dark winters in Norway!
*EDIT*
OH, and insulate the backside of the panel so it doesn´s short anything. Hot glue works fine.
ID:	123438   Click image for larger version
ID:	123439   Click image for larger version
ID:	123440   Click image for larger version
ID:	123441   Click image for larger version
ID:	123443   Click image for larger version
ID:	123444   Click image for larger version
ID:	123445   Click image for larger version
ID:	123446   Click image for larger version
ID:	123449   Click image for larger version
ID:	123450   Click image for larger version
ID:	123454   Click image for larger version
Name:	wiring diagram.jpg
ID:	123477   Click image for larger version
jonnyhar is offline        Reply With Quote Quick reply to this message
Old 11-07-2009, 04:43 PM   #2 (permalink)
that seems a lot cheeper than the 60 dollar kit they sell on ebay!
sethf8403 is offline        Reply With Quote Quick reply to this message
Old 11-07-2009, 04:55 PM   #3 (permalink)
Yeah the cost should be around $10 I think.
The plexiglass is probably the most expensive, I don´t know, I had it laying around.
Old 11-08-2009, 09:54 AM   #4 (permalink)
Great stuff man! I love it!
Thanks for taking the time to share
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote Quick reply to this message
Old 11-09-2009, 07:52 AM   #5 (permalink)
No problemo! I´ve been getting alot of help on this forum reading the posts of others.
Old 11-11-2009, 01:21 AM   #6 (permalink)
Nicely done
Where could I get hold of that kind of plexiglass?
Noe du hadde liggende,eller vet du om ett sted der hvor man selger slikt
thermalclimber is offline        Reply With Quote Quick reply to this message
Old 11-11-2009, 07:22 AM   #7 (permalink)
<norwegian>
Clasern! Alltid Clas Ohlson! De har dioder, ledning og motstander også.
</norwegian>
Old 11-15-2009, 05:20 PM   #8 (permalink)
You can use a cd-cover.... it is transparent, plastic and easy to cut...
mapas is offline        Reply With Quote Quick reply to this message
Old 12-13-2009, 06:30 PM   #9 (permalink)
Yeah I guess, but I think plexi is better. It´s thicker.
Old 01-25-2010, 10:09 PM   #10 (permalink)
I would love to see a picture showing how you mount it in the radio
Thanks.
piperye is offline        Reply With Quote Quick reply to this message
Old 01-25-2010, 11:38 PM   #11 (permalink)
Wow, that is great. i am going to modify that a tad for the RDS8000. I have always wished that had a light in there. This will be super! Thank you again!
UBHSTRY is offline        Reply With Quote Quick reply to this message
Old 01-27-2010, 01:35 AM   #12 (permalink)
Not sure if DX7 and DX6 would be the same, but this could be an alternative:
https://www.helifreak.com/showthread.php?t=185389
heli-on is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 01:03 PM   #13 (permalink)
Default dx6i mod
ok here i sit and wonder in awe. i love the idea of the blue leds, however , i have a cell phone that is no good . its a lg phone with keyboard. i have taken the liberty to take this thing apart. what a chore!!!!!. anyways i know that cell phones have baclit screens. this is why i took it apart. and now i have the socalled el board . so as it sits. there is 4 connectors on this board and was wondering if i wire to where it shows in the pics if this would work.? i would also be throwing a toggle in there as well so as to shut it off when not in use.... any suggestions would be great.
thanks all.
copterx 450 ae v2(agusta 109a fuselage)
http://rcfriends.createforum.com
Hawk_Sport is offline        Reply With Quote Quick reply to this message
Old 01-29-2010, 02:56 PM   #14 (permalink)
Default dx6i mod
well i wont have a blue screen. however it shall be white i had another el board that i had taken outta another cell phone. much bigger one . now the problem i forsee is hooking this up and not being able to shutt it off.? am i able to install a toggle between the pos and the board where the wires hookup? also where do i install this? i need more pics as to how this is installed .
ID:	136698   Click image for larger version
Old 01-30-2010, 02:55 PM   #15 (permalink)
Oh ya, I hope your successfull with that. I have hordes of phones, NEVER thought of it.........going to get one now....
Old 02-02-2010, 02:19 PM   #16 (permalink)
You're going to need an inverter. The one I got off of ebay works fine. There's a 3-pin connector going to the transmitter board where you can pick off the 12V. I used the Aux 2 switch on the Tx for power on/off for the inverter.
Old 02-08-2010, 09:24 AM   #17 (permalink)
I like the phone idea!
Old 02-26-2010, 02:37 PM   #18 (permalink)
Default The mod continues
I modded my Dx6i a litte further tonight.
I added two more switches. (The two in the middle) Dx10 next!
The right one turns the backlight on/off
The left one turns the buzzer on/off. That buzzer really annoy me sometimes when I´m setting up helis etc.
Damn these pics gets huge in here! Doesn´t the resize-function work?
ID:	141875   Click image for larger version
ID:	141876   Click image for larger version
Old 02-28-2010, 03:47 PM   #19 (permalink)
so what do the new switches do?
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote Quick reply to this message
Old 03-01-2010, 03:30 PM   #20 (permalink)
Hmmm..
Tags
dx6i diy backlight mod
