Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 02-18-2014, 11:41 AM   #101 (permalink)
Price's Goblin 570
Europe = 649.00 €
US = 699.00 $
https://www.facebook.com/epfun.be/ph...type=1&theater
ep-fun is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 11:51 AM   #102 (permalink)
Originally Posted by ivak4eto View Post
If that's the case, I predict that next Goblin could be 430. Here's why:
- There isn't shrunk version of G500.
- There's a demand for 450 size heli
- 450 size helis use 425mm and SAB goes by blade size - not typical (500,600,700,800)
- There're 70mm difference between all models (except 570 and 630, which is 60mm, but these two models are in different category, and still almost 70mm like the rest)
Here's the graph:
Tradional 450 sized helis use 325mm blades, not 425mm. 425's go on your traditional 500 sized (ie Align TREX500)
I don't think there will be any shrinking of the 500 going on, it's too heavy for 430 blades and the 630 is doing OK in the lineup but nowhere near the 700.
Next size 450 class will be targeting the 6s stretched 450 class of helis like stretch protos started, then Warp360 and then 450L Dominator.
Not happening anytime immediate though.
SAB Heli Division Rotorquest
snemi00 is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 11:52 AM   #103 (permalink)
Default Goblin 570 in make
Except 450's typically run 325's, not 425's
500's usually run 425's
Edit: i see Snemi00 beat me to the punch
Fusion 180 - M2 Evo - RAW 420 - Fusion 550 - Tron 5.5 - Kraken 580 - Kraken 580n - Kraken 700 - Kraken 700n - Vcontrol Evo
vertico is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 11:55 AM   #104 (permalink)
You guys are right my bad!
ivak4eto is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 11:59 AM   #105 (permalink)
Just found this??? What's the deal? Reg n comp?
Ponyguy is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 12:01 PM   #106 (permalink)
Just different color codes would be my guess.
Citizen 242
NC_2_VA is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 12:01 PM   #107 (permalink)
You may or may not be aware, but Align's sizing was primarily based on the numbers they used on their Electric motors. This was moved over from brushed motor days, where '600' for example used to mean something about the motor. Then it goes even deeper when you start talking nitro. For instance the G630 would be considered a '60 class' bird, where a 600 is a '50 class' bird. Not many new folks remember 60-sized helis. There are still only a handful today. Naming a heli by its blade size makes far more sense these days as people choose their power center for any given model differently. What we are really interested in is the true blade size... At least I am.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 12:16 PM   #108 (permalink)
Yes, I heard of that and it is very confusing for new guys like me
I was just thinking that G430 could be a heli with 430mm blades (500 typical align), since Goblin already has kinda 550 (or G500), 600 (or G570), '60 class (or G630), 700 (G700) and 800 (G770).
Am I in the ballpark?
... I just didn't get the weight/power ratio for shrunk G500 being too heavy for 430mm blades...
Old 02-18-2014, 12:56 PM   #109 (permalink)
Looking back at the first photo it does appear to share the same main block as the Goblin 500.
So i'm going to take a stab at what is required to convert from Goblin500 to Goblin 570:
Frame sides
Full Size servo mounts
Tail Boom
Tail Belt
Tail Pushrod
Aluminum Tail Case Spacer
Blades of course
Old 02-18-2014, 01:06 PM   #110 (permalink)
[QUOTE=snemi00;5654494]
/QUOTE]
I dont fly anything under gob 500 in size, so foook smaller.
you going 6s or 12s? I have tons of packs laying around in all formats really, so not limiting, esc/bec is 12s regardless as well (jeti)
4025 size max... humz? thats weird, thats what my 500 runs... gotto be able to fit that 4035 or 4025 or 4026.. or whatever.. hmm hmm
honey bee king II
andersn is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 01:06 PM   #111 (permalink)
TheVortex3d is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 01:07 PM   #112 (permalink)
Looks like 12s
Old 02-18-2014, 01:23 PM   #113 (permalink)
[quote=andersn;5654664]
/QUOTE]
I'm going to setup for 12s of course.
I'll start with the YGE90HV esc and a WR BEC and then when the new Jive Pro 80HV comes out, for sure that will go in the heli.
Pyro 850 for me, not sure which kV just yet, there is a wide selection there.
I'm also going to try out an XNOVA motor at some point soon, I've got Rotorquest setting up for them now. Just getting the details sorted out on which sizes to get on the initial order
Old 02-18-2014, 01:26 PM   #114 (permalink)
Looks very nice, but I find myself wondering.. if I'm going to run 12s on the 570, why not just go for the 630? I'm not sure what advantage the 570 size has, other than being a bit cheaper to operate than the 630.
dwelzel is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 01:36 PM   #115 (permalink)
Pyro 850 in the G570? Is that a typo?
Goblin 700c - Pyro 800 - Kosmik Cool 160 - BD 3SX - Torq Servos - Flown at 1250rpm
Goblin 800xls - Pyro 850c - Kosmik Cool 200 - BD 3SX - Torq Servos - Flown at 775rpm
Scooter. is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 01:54 PM   #116 (permalink)
[quote=snemi00;5654706]
pyro 850 holyshitbatman?
I remember we talked about the xnovas, I usually have tons of motors laying around, I just discoverd I just sold my motor for the 570.. and the fbl and esc !! (DOH) but still got servos, I bought the servos for the 570 in april 2013 :p
honey bee king II
Old 02-18-2014, 02:00 PM   #117 (permalink)
LOL!!
Yup, big typo.... I meant Pyro 650!
Old 02-18-2014, 02:01 PM   #118 (permalink)
LOL!!
meeeh tiny motor :p
honey bee king II
Old 02-18-2014, 02:03 PM   #119 (permalink)
Anybody else notice the blades on the 570 and the 700 in the pictures? I wonder if we are going to see a new style blade from SAB soon. I hope so those are cool looking blades.
Goblin 700, Goblin 630, Goblin 500, Gaui X4 II, Trex Dominator, Trex 550e, Blade 300x
Team Helidirect Field Rep
bullittsam159 is offline        Reply With Quote Quick reply to this message
Old 02-18-2014, 02:04 PM   #120 (permalink)
The 630 is a real heavy machine, but also much bigger. It's not really my thing. Mostly just a smack machine that can take ungodly abuse.
This 570 is a real lightweight in comparison. It will be much more nimble and I think fly with razor sharp precision.
Have a look at the 700 market and compare a Thunder Tiger E700 which is a real lightweight to the Logo 700XXtreme.
Both beautiful machines but on completely different ends of the spectrum to eachother in design and execution.
