Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 12-18-2014, 11:47 PM   #1 (permalink)
Default Tail belt walking off idler
I replaced both belts after the main belt failure and now my tail drive belt is walking off the non-tentioning idler pulley. It has happened on every flight and most of the time it is just partially off of the idler. The last time it had rolled all the way off the idler. I have tried tightening the belt more and it did not fix the issue. It came down pretty hard during the belt failure, but I don't see anything bent. I suspect it may be an issue with the new belt. Has anyone had a belt do this before?
vburge is offline        Reply With Quote Quick reply to this message
Old 12-19-2014, 12:16 AM   #2 (permalink)
How much tension is on the tail belt? Usually that happens if it is too loose or too tight. The tensioner should be able to swing in and out. It shouldn't be resting on the monoblock or pinned to the frame.
kumar2494 is offline        Reply With Quote Quick reply to this message
Old 12-19-2014, 01:22 AM   #3 (permalink)
I have always followed the manual and have not had this issue till now. The tensioner arm would just be hitting the stopper screw and I would tighten it down. Not sure what you mean by "pinned to frame?"
From manual:
Pull the boom away from the frames very tightly. Make sure the tensioner arm is all the way open against the stopper screw.
Old 12-22-2014, 01:35 PM   #4 (permalink)
I put the original tail drive belt on and it walked off the bottom of the idler also. It isn't the belt or tension, so I have ordered a new idler and the fixed post it mounts on.
Old 12-28-2014, 04:08 AM   #5 (permalink)
Did that fix it?
Andersonsmog is offline        Reply With Quote Quick reply to this message
Old 12-29-2014, 10:18 AM   #6 (permalink)
I put the new idler, post, and old belt on and the first flight it still walked off. However, the next three flights it did not. During my 5th flight I had a boom strike and it demolished the boom and belt.
Old 12-30-2014, 03:31 AM   #7 (permalink)
belt tension should be tight but not over tight. between 1 and 2mm from the frame and being fully tightened.
):>Team Gaui USA, MKS-Servos USA, Dryfluid, ScorpionPowerSystems, Cyclone Blades"J1S Designs" #Highonhelis
highonhelis is offline        Reply With Quote Quick reply to this message
Old 12-30-2014, 07:35 AM   #8 (permalink)
Sooo, why does the manual say the belt needs to be tight enough to put the idler pulley against the stop screw?
Is the manual wrong and just not updated?
180cfx, Align 450L, Goblin 500, Rush 750, Avant Mostro
Lynx Team Pilot
Pitch-Itch is offline        Reply With Quote Quick reply to this message
Old 12-30-2014, 08:40 AM   #9 (permalink)
Both of my Mostro have the belt tight to the point where is touching that stop screw. The important thing is not to over tight it.
Victor M.
MikadoUsa/Scorpion Power Systems/Xpert Servos
vmalpi is offline        Reply With Quote Quick reply to this message
Old 01-28-2015, 08:37 PM   #10 (permalink)
Of course I had a major crash and replaced numerous parts, but I suspect the cause for the belt walking off was one of the intermediate shaft bearings was completely frozen. It is just a theory, but it is no longer walking off and I don't know what else could have caused the problem. The belt on there now is one that I had already tried and it was walking off before the crash. Here is my Mostro back in the air after being down for a month. The new Xnova motor has tons of power and runs much cooler than the scorpion.
Mostro 1-27-2015 (5 min 12 sec)
Old 01-28-2015, 09:22 PM   #11 (permalink)
the heli sounds very quiet and smooth in that video.
μολὼν λαβέ
#RCHelisAreCoolAF
FBLessOne is offline        Reply With Quote Quick reply to this message
Old 01-28-2015, 09:47 PM   #12 (permalink)
Mostro 1-27-2015 - YouTube
Which Xnova Motor are you using? And What Blades?
Avant Mostro E --- Synergy N5c
Goblin 570 --- KDS Agile 7.2
MD 600 --- Goblin Speed
Goblin 380
Razorback Flyer is offline        Reply With Quote Quick reply to this message
Old 01-28-2015, 10:26 PM   #13 (permalink)
Xnova XTS 4530-525kv motor with 695 mm cyclone blades. I am using the vbar governor at 2100 rpm.
Old 01-29-2015, 07:46 AM   #14 (permalink)
Thank You, My Mostro is on the UPS truck today out for delivery! Thought Id like to give these motors a try.
Goblin 380
Old 01-29-2015, 07:57 AM   #15 (permalink)
Very cool to see you back in the air!
Lynx Team Pilot
Old 01-29-2015, 07:58 AM   #16 (permalink)
Welcome to the Avant group Razorback flyer! Once you build and fly the Mostro, it is hard to even consider buying a different brand. The Xnova motor is awesome.. I didn't like how hot my scorpion motor got and believe it created additional wear on the drive belt. The Xnova with Cyclone blades is a very efficient combination and I am flying 4:50 min with 28% left in the batteries after most flights. Hope you have a "smooth" build and let us know if you need any help.
Old 01-29-2015, 08:01 AM   #17 (permalink)
What kind of wear were you seeing? I ask because the KDE motor I am running gets VERY hot even in cold weather. In the summer I can't imagine how hot it will get.
Lynx Team Pilot
Old 01-29-2015, 08:42 AM   #18 (permalink)
Which KDE motor are you running? I have the 700xf 505g3 in mine and it stays much cooler than the scorpion. What do you have set for timing?
Old 01-29-2015, 08:48 AM   #19 (permalink)
I'm running the same motor as you. Not sure about the timing at all. I just programmed mode 4 on the kosmik.
What's your timing setting? I will have a prog unit soon so I can play around with the parameters.
Lynx Team Pilot
Old 01-29-2015, 09:07 AM   #20 (permalink)
Timing is set to 18. Any idea exactly what temp yours is after a flight? Mine peaks at around 155-160 which is pretty normal. My scorpion used to peak over 200 sometimes.
