Go Back   HeliFreak > Multi Rotor Support > Blade Multirotor Support > nano QX
nano QX Blade nano QX Information and Help
Old 06-26-2016, 12:40 PM   #1 (permalink)
Default Nano QX 3D MOD thread
http://www.thingiverse.com/thing:1165005/#comments
Take a look at this mod.
Where to and how do you solder the motor connectors?
Has anyone cut up a Nano QX 3D board?
Goblin500, Goblin 380KSE and 2 blade, Logo 400SE, Gaui X3, Oxy3 Cube, Standard Oxy 3, Graupner Alpha 300 3d Quad Graupner MZ12 Tx, ,Vbar Control, NEO, Mini and Full Size Vbar, Futaba, Ikon, Spartan Vortex, Castle and HW Escs, Vortex 150FPV, FatShark
Pard is offline        Reply With Quote Quick reply to this message
Old 06-27-2016, 08:22 AM   #2 (permalink)
I figured it out. The copper dots at the corners of the board, in pairs, are the positive and negative terminals that lead to the motor connectors down the arms. I confirmed this with a multi-meter. If I solder connectors to those dots, I will be in business.
Old 06-28-2016, 09:45 AM   #3 (permalink)
Here are some picture of soldering a motor directly to the controller board. I plan on using a dreamcatcher frame with 8.5 mm motors using the Nano QX 3D board as the controller.
https://micro-motor-warehouse.com/co.../8x20mm-insane
https://micro-motor-warehouse.com/co...products/dc-08
After getting the new motors, I will solder them directly to the board and cut off the stock frame arms.
I will unfortunately lose the LEDs unless I can figure out how to transplant them.
I ordered a set of these to wire up for LED light:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 06-28-2016, 01:38 PM   #4 (permalink)
  • I went ahead and reversed the polarity of each motor by switching the pins in the connectors.
  • Next I removed the plastic motor holder/gear legs.
  • I then wrapped the motor can with masking tape to fit the arm mounting hole snugly and glued in place.
  • Propellers remain the same since the motors are running reverse to what they were before, but upright instead of inverted. So front left motor is now a tractor running clockwise, etc.
  • I placed double sided foam servo mounting tape at the bottom of each motor can for padding during landing.
  • I kept the plastic battery tray but removed the plastic fin.
  • Result is a standard looking quad that with the saved weight flies with much better performance. I eagerly await the arrival of the more powerful motors from micro motor warehouse for some really fun flying!
Old 07-01-2016, 07:52 AM   #5 (permalink)
I tested the 8.5 mm motors. No go. The board does not support the amp draw and even with a .500 Mah battery, I get a shut down.
The 7mm upgrade motors with 20mm cans work well, but they draw too much current and reduce flight time to 3 min from 4:30.
Bottom line, I am sticking with the stock blade motors.
I really wish there was a more powerful inverted capable micro quad out there.
Old 07-01-2016, 05:16 PM   #6 (permalink)
I wish Blade would make a brushless 100 sport/3D quad with in-runners from the mCPX BL tail rotor. Even better, some small out-runners.
Ric66 is offline        Reply With Quote Quick reply to this message
Old 07-01-2016, 05:40 PM   #7 (permalink)
+1
Old 12-11-2016, 02:33 PM   #8 (permalink)
I put an FPV camera on this rig from an inductrix FPV. Very cool!
