Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Like Tree2Likes
Old 01-29-2017, 11:31 AM   #1 (permalink)
Default Trex 550X Dominator Full Build Review
Align T-REX 550X Dominator Review
550X Dominator Specs:
FBL System: NEO
Motor: Align BL730MX 960KV
Pinion: 16T
Headspeeds: 1950, 2150, 2350
ESC: Castle Talon 90
Cyclic Servos: MKS HBL950
Tail Servo: MKS HBL980
Battery: Pulse 4100/5000mAh 45C lipo
Mains: Align 550mm
Tails: Align 90mm
AUTHOR'S OPINION:
The last T-REX model I owned was the T-REX 550V2 back in 2012. That model turned a lot of chapters for me with my build and flying ability. Though it had a flybar it was still stable and flew much like a bigger helicopter. I have setup a few Align models since for some guys but have not owned one in over four years so I looked forward to trying out the new 550X. The T-REX 550X is definitely a leap forward in performance than past 550 models with the integration of numerous innovative design changes and overall lightweight improvements.
Align was one of the first originators when it came to electric 3D model helicopters in the early 90s with their 450 size models. They have had a very successful line of helicopter sizes from 250-800 class machines. All sporting flybar and flybarless technology is offered in both nitro and electric models. If you are just starting out in the hobby and want something reliable that won’t break the bank Align has a model for you. I think if you ask most guys what their first model kit build was they would say it was an Align. Besides Blade with their RTF/BNF helicopters, I strongly believe Align is a contributing factor for a lot of newcomers in the hobby both past and present.
OPENING THE BOX
When you open the box you will find numerous marked boxes containing all of the different sub-assemblies. The first box I opened included the skids, fin, and some frame parts as well as the new 550X canopy. The canopy is nicely painted in a red, white and blue Align color scheme with a nice clear coat finish. Depending on the 550X package you purchase you will find all of the electronics in their own separate box. The main rotor box has all of the head parts and remaining components to build the helicopter with the sub-assemblies set preassembled and packaged in their own sealed bags. The frame sides are sitting at the bottom of the box with the manual and the remaining box contains the blades, tail boom, boom
AUTHOR'S OPINION:
OPENING THE BOX
When you open the box you will find numerous marked boxes containing all of the different sub-assemblies. The first box I opened included the skids, fin, and some frame parts as well as the new 550X canopy. The canopy is nicely painted in a red, white and blue Align color scheme with a nice clear coat finish. Depending on the 550X package you purchase you will find all of the electronics in their own separate box. The main rotor box has all of the head parts and remaining components to build the helicopter with the sub-assemblies set preassembled and packaged in their own sealed bags. The frame sides are sitting at the bottom of the box with the manual and the remaining box contains the blades, tail boom, boom supports and torque tube. With all the parts laid out it was time to start the build.
THE BUILD
The build begins by assembling the EFL Flybarless Rotor Head System. It comes completely dry assembled so you will need to completely break it down and reassemble with loctite and grease. The EFL head design was developed to utilize extreme low CG to effectively reduce resistance during 3D maneuvers while increasing flight responsiveness and precision. Thus increases the usable rotor RPM range without having to change the rigidity of the dampening system. This allows for an optimal control of the geometry even when large amounts of torque are introduced into the system. Some of the head parts are accented with a nice red anodizing on the stainless precision machined metal parts. Align has also redeveloped the swashplate. Their new advanced metal swashplate firmly connects to rotor grips preventing rotor head disengagement during intense flight. Two linkage ball mounting holes provide improved control of system movement. Once I had the head and swashplate assembled I installed them onto the main shaft to await installation into the frame.
The T-REX 550X main frame utilizes composite material integration technology on the carbon side frame plates, including the addition of battery mounting side rails and a top motor mount design. In addition, the T-REX 550X's lightweight design is 200g lighter than on previous 550 models. The 3K main frame feature embedded battery mounting rails and a latch design which provide quick battery changes. The two frame halves join together with M3 screws sandwiched between bearing blocks, frame standoff posts and the front plastic electronics tray. Align integrates plastic parts on the frame to give the model a unique look and cover some parts that may have electronic wires cross over or through parts of the frame. The 550X uses Align’s traditional skid and pipe landing skid design that mounts onto the lower frame standoffs. On the new 550X model the rear landing skid is taller giving the model a 5 degree forward tilt to keep the tail higher off the ground.
The tail boom and tail assembly follows suit to most torque tube pod and boom models on the market today. The front plastic tail boom mount has your front drive gear along with the front umbrella gear. The tail case assembly is made up of an aluminum tail tube case with torque tube gears and metal side plates. Manufactured with stronger material, the torque tube front drive gear is more durable. The stronger material reduces the probability of gear striping during flight or damaging the gear as a result of a crash. The newly designed dual point supported tail pitch assembly delivers slop free performance while improving rudder control and precision. The carbon tail boom is built from 3K carbon fiber and aluminum imbedded technology which features light weight and high strength. I’ve flown belted helis the last 4 years so it felt weird assembling a torque tube model again with the inner boom bearing and rubber keeper. Once the torque tube assembly was installed I assembled the rest of the tail components onto the boom. With the tail assembly complete (tail boom case, tail case, boom supports, fins and pushrod) I installed the rear tail section and boom supports onto the main frame using the provided M3 screws.
Next I assembled the main 112T CNC slanted main gear which make for a very efficient and strong drive system. With the main gear and autorotation gear complete I slid it inside the frame and lowered the head assembly down inside of it and secured the main jesus bolt. With the airframe complete it was time to setup my electronics and install them onto the airframe. With all my builds I have the electronics all soldered up and servos centered in the FBL system before I begin my builds. This makes the next step of the build go much quicker.
ELECTROINCS INSTALLATION
For my T-REX 550X build I chose to use the MKS HBL950 high voltage servos on cyclic and a MKS HBL950 for tail control. After installing the servos I routed my wires up towards the front of the frame and secured them using small black zip ties. As previously mentioned I always plug in my servos and center the servo arms before I install the servos onto the frame making the setup steps go much quicker. I decided to use the provided Align motor and mounted it onto the aluminum motor mount and slid it into the frame and secured it into place leaving some little pinion backlash. The T-REX 550X uses the new powerful 730MX (960KV) motor which is highly efficient providing superior power while improving the performance of the 6S power system. You can now adjust the motor pinion main gear mesh. You don’t want it so tight to stress the motor but if it’s too loose it could slip and strip the main gear.
I mounted the Castle Talon 90 onto the right side of the front plastic electronics tray. This location is perfect on the 550X as the wires from the motor can plug directly into the ESC. I mounted the NEO flybarless unit with the wires facing back on top of the front electronics tray. Having everything on the front of this model gives the rear of the 550X a nice clean look when the canopy is installed. However you can choose to mount your FBL system and receiver on the rear of the model on the tail boom mount as well as with past models. I mounted a Scorpion Backup on the left side of the front tray opposite the ESC. The 550X is very spacious and gives you a variety of locations for mounting the model’s electronics. Setup with the Mikado Vbar Control radio and NEO flybarless system was extremely fast and EASY. When you are setting up a new “Other 600” model in the NEO wizard it automatically puts basic presets in the NEO leaving the builder just a few quick setup steps to get your model into the air!
IN THE AIR
After a quick circuit around the field to run the NEO flybarless system through its initial setup test flight it was time to run the T-REX 550X through its 3D paces. The 550X tracked perfectly through the corners, with noticeably higher control precision then the 550L DFC model before this. It’s collective and cyclic response were quick yet agile. Stationary flips and rolls are fast and stable, with no noticeable wobbles and tic-tocs were crisp and precise. The bright red, white and blue canopy was extremely easy to see in all orientations. I can remember back a few years ago my maiden flights used to be hovering around, a few pitch pumps and some forward flight to check tail gains. With today’s quality helicopters and the Mikado NEO setup wizard getting you so close to a perfect flying setup you can run the model through its 3D paces on its maiden flight.
Flight mode Throttle RPM
Bank 1 Governed 1950
Bank 2 Governed 2150
Bank 3 Governed 2350
I purchased Pulse Ultra 4100 mAh 45C packs for this model to keep the weight down for harder 3D flight. If I want to just have fun and sport fly I sacrifice some weight performance but gain minutes of flight time using Pulse 5000 and 5500 mAh packs. My recommendation is lean towards 4500-5000mAh packs if you plan on flying aggressively. You could even get more flight time if you optimize your power system to run at a lower headspeed.
For soft sport flying the 550X really flies well at 1800-2000rpm with zero bobble and really extends your flight time. I tend to fly in Bank 2 at 2250rpm to practice my collective management and not sacrifice my flight times. I found that 2250rpm gives me a long flight time and still gives me plenty of performance to fly lower headspeed 3D. If I want to really show off the 550X’s abilities I can crank her up to 2450 in Bank 3 for extreme fast forward flying and hard 3D.
All size batteries easily fit on the included slide out locking battery tray. If you only have one battery tray, swapping out flight packs is as easy as un-strapping the Velcro strap and attaching another pack. I keep 5 packs on trays ready to swap out between a busy day of flying or testing. I highly recommend buying a few extra battery trays and straps though. It makes swapping batteries between flights a breeze. Two battery trays cost $25 and the straps are another $4. I found the best places to purchase extra battery trays and Align parts are HeliDirect and LowerHeli. They ship the same day you order with 2-3 day priority mail and I have always received my parts promptly.
THE LAST WORD
I still am a firm believer that a mid size heli with 550mm main blades is the best choice for a beginner to step up and advance into up to a “bigger size” helicopter. For $590 this helicopter kit comes as upgraded as it gets with a full metal head, metal tail and fiber carbon parts along with Align’s new MX motor. Overall the T-REX 550X is an extremely capable 3D helicopter for fun or training purposes with lower costs to repair if you were to put it in. It has very good power to weight ratio and also a light disc loading for a mid class model. This makes it very agile but also capable of handling a variety of different pack sizes. The increase in size from the T-REX 500L makes it much more stable and easy to see in flight.
For a midsized 3D machine, the T-REX 550X provides the stability of larger helicopters, while maintaining portability and economical operation of a smaller helicopter. The kit was well packaged, the manual was well thought out and easy to follow. For a smaller model it remains maneuverable even at lower headspeeds, yet is able to handle the hardest smack 3D you can throw at it. The kit is a great value considering all that is included. The T-REX 550X is everything I expected it would be. This helicopter can satisfy all the needs for a model in the midsize class. From the ability to fly smooth for 6 minutes or to fly hard and fast in the same model is a bonus. Minimal maintenance, amazing performance and a stunning appearance is certain to keep it at the top of its class for a long time!
For more pictures and video you can see them on my helicopter Facebook page "3D and Scale R/C Helicopters".
Fly Safe
-Chris
Build Video
Align T-REX 550X Build Video (7 min 13 sec)
Maiden Flight
Align Trex 550X Maiden Flight (4 min 0 sec)
Chris Reibert is offline        Reply With Quote Quick reply to this message
Old 01-29-2017, 06:53 PM   #2 (permalink)
Nice job! I hope to be able to do the same soon.
Trying to enjoy everything the RC hobby has to offer
Ramflames is offline        Reply With Quote Quick reply to this message
Old 01-29-2017, 11:07 PM   #3 (permalink)
HF Scale Support
Nice build and videos, Chris. My first "large" helicopter was the 550EFL that I quickly converted to Skookum. Now, I'm finally building 700s for scale chassis and training. I agree that the 550 (ex .30 size) is a great beginning for larger size helicopter training and the cost of maintenance is not as hard on the pocket book as the larger sizes are. Take care.
Don
Old 01-30-2017, 02:34 AM   #4 (permalink)
Nice review, and very nice flying !
I also have the 550X but i cant agree with you that is has light disk load. It is very heavy for 550 size.
I have a protos max wich is 6,1 kg, with 710 blades it has 3,23kg/ square meter, 550X is 3,6kg, with 550 blades it is 2,98 kg/sq meter. But the max has a 5100/11000W motor on 12S, the 550X has 2500/4000W on 6S.
It feels heavier than the max in the air to me.
Whick i can say is feels light, is a 450L with 360 blades. It is 2,4kg/sqmeter.
This is why i dont like it that much, i prefer the heavier feeling like the max, or the 550X.
kc4sox likes this.
XL Power 520 - XL4020-motor, DS512HV + DS825 servos, Spirit Pro FBL
XL Power and Spirit FBL field rep.
Gtamas90 is offline        Reply With Quote Quick reply to this message
Old 01-30-2017, 10:14 AM   #5 (permalink)
Nice review - I also have the 550X, its definitely an improvement over the 550L which I also had previously. Not sure about the Talon 90 though - I had one on my 550L and it got so hot that it worried me so I swapped it for a HW100 and was pleased when I saw that the HW V4 100 is standard on the 550X (doesn't get more than warm).
jchbarnes is offline        Reply With Quote Quick reply to this message
Old 01-30-2017, 10:25 AM   #6 (permalink)
As a "full build review" curious why you changed out the stock electronics. The average person buying this kit is going to get the beastX FBL and Aligns (Hobbywing) ESC. I scanned the text quickly but didn't see mentions of how you choose the electronics. Do they now sell a version without FBL and ESC?
This is your brain on helicopters!
Trex 700L, Trex 700N DFC HB gasser,Trex 700N V2 HB gasser, Trex 550X. Spirit or BD3SX
rhodesengr is offline        Reply With Quote Quick reply to this message
Old 01-30-2017, 10:42 PM   #7 (permalink)
I purchased it airframe only and bought everything else separate. (Though the Super Combo is a killer pride). I fly Mikado Vbar Control Radio and other electronics. I did not want to buy the Super Combo instead use all my own electronics of my choice. I was reviewing the airframe not what I put into it though I cover it all in my review. I was quite impressed how far Align has come since my original Trex 550E flybar model.
UH34D likes this.
Old 02-09-2017, 04:19 PM   #8 (permalink)
It is a nice heli and build, only trhing I found was the jesus bolt on the main gear is perhaps a couple of mm's out, I did try a complete new main shaft and it still did not line up sorrectly
mr magoo is offline        Reply With Quote Quick reply to this message
Old 02-09-2017, 04:44 PM   #9 (permalink)
I don't know that it is anything close for a couple of mm's off but it is a bit difficult to get the holes all lined up. Seems like it is always a struggle even with other Align models to get the Jesus bolt through.
Old 03-07-2017, 02:03 AM   #10 (permalink)
My 550x will be here tomorrow! Thats why I'm up so late, I can't sleep!
Align450L Dominator Align 550X SAB570(R.I.P.) Kraken 700
BT T Line
DX6i/DX8G2/NX10
Leadzeplin is online now        Reply With Quote Quick reply to this message
Old 03-07-2017, 02:07 AM   #11 (permalink)
Sorry, being selfish. Nice review! Just got me even more pumped up.
BT T Line
DX6i/DX8G2/NX10
Old 03-26-2017, 12:21 AM   #12 (permalink)
Great write-up!
I just ordered a 550X today
Seems like the perfect sized heli!
aldrichg9 is offline        Reply With Quote Quick reply to this message
Old 03-26-2017, 03:01 AM   #13 (permalink)
Originally Posted by aldrichg9 View Post
Great write-up!
I'm a couple solid weekends into my first build on the 550X and the kit has been awesome. I had one hole, on the top bearing block, that was offset and didn't line up perfectly with the pre drilled hole in the frame. To make sure I didn't cross-thread it, I opened up the hole in the frame a little in the direction of the offset.
Others have said the manual stinks and in some ways I would agree. But overall I am pleased with Aligns quality.
Good luck with you're Build
BT T Line
DX6i/DX8G2/NX10
Old 03-26-2017, 09:30 AM   #14 (permalink)
Ya the manuals aren't the greatest, and we are trying to improve them wherever we can.
But I'm pumped about this heli.
Old 03-26-2017, 12:03 PM   #15 (permalink)
Just my own opinion but compared to the hobby industry as a whole, Align manuals are pretty good at least as far as building the model. Maybe some of the verbiage about setup towards the end is not so great but honestly, I don't read all that. The diagrams are clear and detailed and the flow from page to page is a reasonable sequence for the build.
Truly disappointing manuals: anything from Spektrum. My DX18 is packed with features that I could never figure out from the manual. Things like Mixing and Sequencer. The manual pretty much just says you can do Mixing and do Sequencing but very little about how. Spektrum RX manuals often don't even have a diagram of or close up photos of the product showing the ports.
Try building a Euro molded sailplane. They often don't even have a manual at all.
Old 05-14-2017, 11:48 AM   #16 (permalink)
has anyone noticed that the wires are thin on the DS825m servos. easy to break and they still draw a lot of amps so why are they thin.
Because they are wrapped up in a black wire casing?
kenstick is offline        Reply With Quote Quick reply to this message
Old 11-15-2017, 04:38 AM   #17 (permalink)
I'd like to fit helioption canopy mounts to my 550x. Are the fronts the same size as the rears ?
karl1081 is offline        Reply With Quote Quick reply to this message
Old 11-18-2017, 08:16 AM   #18 (permalink)
Yes it looks like I bought the same sizes for both.
ID:	729165   Click image for larger version
ID:	729166   Click image for larger version
Old 11-18-2017, 02:49 PM   #19 (permalink)
Thanks for verifying that Chris, just wanted to make sure as I'm ordering from the US and didn't want to have to mess about returning them if incorrect. Ps would it be ok to ask your advice if I get unstuck on anything when I start my build on the 550x
Old 11-18-2017, 03:20 PM   #20 (permalink)
Thats a nice flight Chris!
T-Rex 450 Pro DFC
xrayray is offline        Reply With Quote Quick reply to this message
