Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters
Compass Helicopters Rage RC Hellicopter Discussion
Old 09-24-2014, 02:26 PM   #21 (permalink)
Originally Posted by GimpyGolden View Post
They'll work on Atom and Warp for Swash-Grip but both models Servo-Swash use 2mm link rods so no go down low.
550/600/700 all use 2.5mm above and below swash, tail rod is still 2mm though.
Are you sure?
The warp is 2.5 all around except for the tail, or at least mine is...
Mcpx Dbl Brushless | 1̶3̶0̶X̶ | 180CFX | Warp 360 | Atom 500 | BD-3SX | DX8
AMA 1040965
fjoe is offline        Reply With Quote Quick reply to this message
Old 09-24-2014, 02:53 PM   #22 (permalink)
Originally Posted by KiloXray View Post
I wasn't aware that the links we have been using were deemed "faulty". I only took this that they have designed an improved part. It is purely optional and not unsafe to fly the original ones.
Do you have different information about this?
Several users including myself have reported link failures, including a couple crashes resulting from the links failing to grip the rod threads. My guess is they attempted to fix the link failure problem along with creating a ball end that matches what you would see from other heli manufactures, where you have some real meat on the ball end.
RedJoE is offline        Reply With Quote Quick reply to this message
Old 09-24-2014, 07:14 PM   #23 (permalink)
Originally Posted by fjoe View Post
Are you sure?
Your right, Warp is 2.5mm servo-swash. Maybe there just isn't room for the extra bulk of the new links on the Warp.
Just to add I really don't think the Warp or Atom need a heavier link anyways, current is plenty big.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 09-25-2014, 07:58 PM   #24 (permalink)
They appear more robust. Never failed one in flight here, but simply feel the tightness when making up links. The improved links is yet another example of Compass commitment to us. Many thanks!
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 09-26-2014, 06:50 AM   #25 (permalink)
I was curious about the details of how they failed...?
I've occasionally had one that it too tight going on, and can imagine it could split under load. I've also drilled a pilot for them to thread in properly. I typically feel the resistance to the link cutting it's threads when I make them up, and get a sense that they are plenty tight.
Also, I have a couple of the link assembly tools which really helps.
Did yours pull out or split? Were they ones you personally assembled?
= Rb43 =
Old 09-26-2014, 08:31 AM   #26 (permalink)
Rob, some of the newer batch ones have had to large a bore for the rod to thread tightly.
I personally had one pull threads during flight, not right out but close. On the bench I was able to push it back on as well as compress the other two swash-servo links.
Obviously did not fly it again until I replaced these links. I got another set from Jeff but they were no better so put on some Rocket City ones a bud gave me.
In the end knowing how loosely they assembled I shouldn't have trusted them or tried to make them fail on the bench but I thought 'they should be oK" and flew with them.
I did suffer a crash on another occasion due to loosing a link. It was either same scenario or was a worn one that needed replacing. That was a spooky crash, better described in this thread you've already visited..
Old 09-26-2014, 11:06 AM   #27 (permalink)
Yes, the links are so loose on the rods that you don't have too thread them on, simply push the ball end onto the rod and it will go on without threading. Either the ball end boar is too large or the rods are too small. Funny, the 700x links I got are so dang tight I had to put them in my vise to get them to thread on, it's hard to find something that works properly in this hobby lol.
Old 10-10-2014, 11:20 AM   #28 (permalink)
This is nice but you can't buy them anywhere ??
mrultralite is offline        Reply With Quote Quick reply to this message
Old 10-10-2014, 07:02 PM   #29 (permalink)
Default links
the 700 links were a pain to assemble,prob never come off and the fit on the ball links was perfect.
I also got a new swash link set from prostar and they have the new style links on them
7HV,Trex 700N,Suzi Janis 800,500 DFC ,NX4 Warp,all on HC3SX, 230s
mmracecars is offline        Reply With Quote Quick reply to this message
Old 10-10-2014, 08:04 PM   #30 (permalink)
I just got some parts from prostar and they are the new links, but will they work on my Warp and Atom?
AMA 1040965
Old 10-11-2014, 08:58 AM   #31 (permalink)
WOW! New links already? Cool! What part number?
= Rb43 =
Old 10-11-2014, 10:13 AM   #32 (permalink)
Default LINKS
the warp swash link set came with the new links
Old 10-11-2014, 03:15 PM   #33 (permalink)
Part num for new link?
No helis!
Jad.
JadAl_87 is offline        Reply With Quote Quick reply to this message
Old 10-11-2014, 09:40 PM   #34 (permalink)
02-0709ST
from the news link:
https://www.helifreak.com/showpost.p...64&postcount=2
AMA 1040965
Old 10-11-2014, 11:58 PM   #35 (permalink)
Ah Clem showed them to me today at the HF FF. They're nice and beefy.
HeliFreak Support
Graupner MZ-32
Old 10-12-2014, 01:27 AM   #36 (permalink)
I will be testing a set on my Warp this week. The plastic is different, the shape of the link is different-these look very good to me!
Old 10-12-2014, 09:49 AM   #37 (permalink)
From where we can buy those? Prostar doesn't have them.
No helis!
Jad.
Old 10-12-2014, 04:28 PM   #38 (permalink)
I don't think they are for sale just yet-I believe we are very close.
Old 10-14-2014, 04:02 AM   #39 (permalink)
How did I end up with these then?
AMA 1040965
Old 10-14-2014, 10:03 AM   #40 (permalink)
The ball links are available since 3 weeks. Prostar should have them.
Team Compass Model - Kontronik - Rapicon - MTTEC - KBDD - MKS
Sebastian Zajonz is offline        Reply With Quote Quick reply to this message
