Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 11-25-2012, 02:18 PM   #1 (permalink)
Default Introduction - Hatori SB-12R Muffler - Flex mount
Here's the new Hatori gas muffler, its based on their original "flex mount" system. Targeted for zenoah based 26-29cc motors
Hatori SB-12R flex mount gas muffler
If you're familiar with the Hatori flex mount system, its the same setup. The muffler itself rides on high temp o-rings and clamps to the header using silicon dampers. This is the most obvious difference from the current Hatori gas mufflers that direct mount to the cylinder using a steel plate.
if there is a drawback to the original muffler, its that the bolts that hold the steel plate to the cylinder are inside the muffler. So if they get loose you have to disassemble the muffler. With this system, all the bolts are external so they can be tightened easily.
Flex Mount Assembled
here's what comes in the package. No additional mounts are needed as the flex mount system fully supports the muffler
Muffler Package Contents
and here's the dimensions for the muffler. Its basically identical to the existing hatori gas mufflers except that the steel spacer plate is no longer needed so its 5mm closer to motor. All up weight of all of the muffler components is 8.8 oz. Thats about the same weight as some of the lightest mufflers being offered today.
Muffler dimensions
Here you can see the pipe mount with the Viton O-Rings installed and the mount dampers inserted in the header mount
Ready for installation
If' you're familiar with the Hatori flex-mount system, the header is a large cavity where the o-rings on the pipe-mount seat. This is something totally new for gas helicopters!
Header cavity is similar to the glow versions
The pipe mount bolts on using std M5 bolts. This mounts easily on the Whiplash Gas however some models like the Radikal V2 would require a custom spacer due to the way the landing gear/motor frame fits around the engine
Pipe mount installed on TRMVX290TT - Special Edition
Once the header is seated on the pipe mount o-rings, its secured to the mount/engine using M2.5 bolts and special lock nuts
Muffler attached to pipe mount
And here's the muffler mounted on the Whiplash Gas. As noted earlier at 8.8oz, the Hatori went from being the second heaviest pipe available to the second lightest!
Muffler installed on Whiplash Gas
The Bottom Line
The Hatori SAB12-2R is of the highest quality and finish. It offers high performance as well as a pleasant sound. Now its one of the lightest as well!
carey shurley is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 03:49 PM   #2 (permalink)
Very nice.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 04:45 PM   #3 (permalink)
Very nice.
Team HeliProz
Zaaaguy72 is offline        Reply With Quote Quick reply to this message
Old 11-26-2012, 11:04 AM   #4 (permalink)
Very nice.
Be sure to test how long the o-rings last. I can remember using their nitro versions, years ago, and seem to remember that the O-rings did not last very long. As the gasser engines run a lot hotter, I will be curious to see how these o-rings hold out.
Phil
MotorRotor is offline        Reply With Quote Quick reply to this message
Old 11-26-2012, 03:50 PM   #5 (permalink)
One would hope they are high temp versions, or they are likely to melt before you finish the first flight...
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 11-26-2012, 04:27 PM   #6 (permalink)
Of that I am curious too.,
Team HeliProz
Old 11-26-2012, 09:00 PM   #7 (permalink)
Please lt us know if this new muffler can be mounted on Radikal 30??
The old version is imposible to mount on Radikal 30 without using some special spacer. What about this new muffler??
Happy autos!!
Felino is offline        Reply With Quote Quick reply to this message
Old 11-27-2012, 11:44 AM   #8 (permalink)
it will be a couple of weeks before I have one, I can see if it will fit after that
Carey Shurley
Proprietor - Gas Powered Helicopters
Old 11-27-2012, 05:16 PM   #9 (permalink)
Originally Posted by carey shurley View Post
Expect availability in mid December 2012 - pricing not yet announced.
With a street price of about $270 for the current version, I'll bet that the new design will be even higher
We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it.
Rudy is offline        Reply With Quote Quick reply to this message
Old 11-30-2012, 07:59 AM   #10 (permalink)
I didn't like the Nitro version at all. I also found those rubbers would eventually crumble. Also had trouble with nuts stripping and just the entire design was cumbersome. I just never liked it.
HeliXHeli 700 | VBar Silverline | TRM275TT
TREX 550 V2 DFC | VBar Silverline | CC Ice 100 | CC BEC Pro
Rototerrier is offline        Reply With Quote Quick reply to this message
Old 01-07-2013, 01:11 PM   #11 (permalink)
any updates??
tony
vatechguy3 is offline        Reply With Quote Quick reply to this message
Old 01-08-2013, 06:06 AM   #12 (permalink)
nothing yet at least in the USA
Carey Shurley
Old 01-28-2013, 08:02 AM   #13 (permalink)
Default gyro
Hi, Any news on this in the USA yet? I have one on order that has been shipped and on route to me in the uk.
Hope it works out ok, as running the Can muffler on my new Helix 700.
Bald-ie is offline        Reply With Quote Quick reply to this message
Old 02-13-2013, 12:28 AM   #14 (permalink)
Well it turned up today, and it certainly looks sweet ! It's fitted now, and hope to get out later this week to try it out.
Old 02-13-2013, 12:28 AM   #15 (permalink)
Double post
Old 02-13-2013, 07:16 AM   #16 (permalink)
HatoriUSA is now selling it as the SB-12R-2
Carey Shurley
Old 02-18-2013, 12:41 AM   #17 (permalink)
Well it's arrived, fitted and briefly tested.
As expected from Hatori, the quality is spot on, nicely finished and well made.
The note is very pleasant, and performance is great.
Need a few more flights to get a good feel for the effect on tuning / power but very happy so far.
Old 02-22-2013, 03:54 AM   #18 (permalink)
Price is $269.99 at heliproz.
Suat
Trex 700 Gasser
Old 02-22-2013, 06:31 AM   #19 (permalink)
Damm I knew it would be high but crap
Old 02-22-2013, 06:39 AM   #20 (permalink)
Yeah. But Century is leading the expensive mufflers market with this one:
$324.95 http://www.centuryheli.com/products/...073&pageid=210
The prices are really annoying.
Suat
Trex 700 Gasser
