2.4G Spektrum Radios Spektrum 2.4 Gigahertz Radios and Technology |
10-08-2013, 07:50 PM | #1 (permalink) |
Need help programming a channel dx9(should be same for 8)
Hello I just got my DX9 radio and I want to program AUX 2 (switch e which is a 3 pos switch)
I only need 2 positions on the switch, say 0 and 1 to display -100% and +100% so I can switch tail banks on my sk720be how do I program the radio to do this. I am already using switch A (2 pos switch) using the gear channel to do -100 +100% in the gyro menu. |
10-09-2013, 06:54 AM | #2 (permalink) |
Can't you program the switch so that pos 0 is -100, pos 1 is +100 and pos 2 is +100?
Only a problem if you have LESS position on the switch rather than MORE. You should be able to verify the AUX2 output in the monitor screen. On the DX8, AUX2 is also known as Gov in heli mode.
TRex 700E Pro DFC HV (BD3SX) - Gaui X5 (6S/BD3SX), Blade 130X, RealFlight, Heli-X, Taranis+DSMX |
10-09-2013, 02:18 PM | #3 (permalink) |
Re: Need help programming a channel dx9(should be same for 8)
I am already using the gyro channel for that so aux 2 isn't being used. I managed to make 2 mixes to give -100 and +100 seems ineffective or not the best way to do it using 2 mixes but that's the only way I know
Sent from my HTC One using Tapatalk 2 |
10-09-2013, 02:21 PM | #4 (permalink) |
So I have a switch using gyro channel to switch between 2 different self level modes, and using 2 different mixs I have a different switch on aux 2 channel to use 2 different tail modes.
10-09-2013, 08:09 PM | #5 (permalink) |
Darrell262, From your messages I am having trouble working out what you are trying to do.
Do you want a setup similar to what I have for my X5? which is:
Is this what you want to configure?
