Old 10-27-2015, 10:04 PM   #1 (permalink)
Talking Air Filter
Hey Guys
I take-off and land on dusty roads and in short grass where dirt,and dust particles, plus clutch and lining particles could get sucked into my engine destroying the bearings and piston. So, I did some moding and installed a foam air filter on my OS 50, from day one. Three gallons later and my engine runs great, plus maybe I get longer run times because there is less fuel lost due to carburetor blow-back.
ID:	616324   Click image for larger version
ID:	616328   Click image for larger version
mugen 1 is offline        Reply With Quote Quick reply to this message
Old 12-01-2015, 09:40 AM   #2 (permalink)
The Tetra work well:
http://www.ronlund.com/rcheli-prod/CN2214C.html
Good enough for a grass field.
Four Stroker is offline        Reply With Quote Quick reply to this message
Old 12-09-2015, 05:32 PM   #3 (permalink)
The area of the screen seems really small especially if it gets dirty. I read some old threads about these screens and they said the metal mesh would break up and fall into the carburetor if the engine back fired? (hopefully that's fixed now) One other thing, it looks like you would have to pull the engine to clean or inspect the screen/mesh. With my mod, you only have to remove the bottom two radio tray screws,loosen the top two screws and swing it up, to clean,replace or inspect the foam filter. I use a light foam filter oil on my filters to catch any fine dust particles.
Old 12-10-2015, 04:21 PM   #4 (permalink)
I use the Bru-Line carb air screens
Unfortunately, Bru-Line (or Bru Line) does not make them anymore.
They worked great on 30 to 60 size motors
When I found out they were hard to get I bought 4 and saved them on the shelf - just in case.
Sheldon's Hobbies still has the replacement elements, but not the boots that hold them to the carb body.
http://www.ebay.com/itm/BRU-LINE-204...gAAOSwlV9WSRJ6
Old 12-23-2015, 09:01 PM   #5 (permalink)
There is a lot of talk about the O.S.50 Hyper's rear bearing failing, I think it's because small dirt particles enter unairfiltered engines causing the bearings balls to pit and grind away the race. These engines spin as high as 20,000 rpm's, so just a small dust particle could toast your engine.
