Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 11-16-2015, 06:55 AM   #1 (permalink)
Default Sparks!
So I'm testing out a used 6HVU I got. I was running down a strange issue during setup where it keeps locking up. Just ran it again and noticed sparks jumping from boom to the main frame. I don't know if that is normal. I'm guessing you don't want sparks around the RX and FBL. So now I'm guessing I get to learn what it means to ground it all. Any tips would be helpful, this will be my first time to do this.
Oxy 2, X3, Protos 380, G420, Logo 480, Trex 500X, Logo 550 SX
Krea is offline        Reply With Quote Quick reply to this message
Old 11-16-2015, 07:23 AM   #2 (permalink)
Just need to ground the boom, found a few posts now I just need to see if I have the wire.
Old 11-16-2015, 07:24 AM   #3 (permalink)
My electronics should be okay right? Not enough to actually cause damage?
Old 11-16-2015, 07:43 AM   #4 (permalink)
I wouldn't fly it without grounding the boom after you do that electronics should be fine but test everything by removing the blades.
Your is my Bread and Butter.
Compass Field Rep/KBDD Team pilot/Experiencrc.com
sewerfly is offline        Reply With Quote Quick reply to this message
Old 11-16-2015, 02:40 PM   #5 (permalink)
"I wouldn't fly it without grounding the boom after you do that electronics should be fine but test everything by removing the blades."
AMEN!
I would also shoot some silicone spray on the belt (inside and out). Helps with static and also lubricates the belt.
Old 11-16-2015, 02:41 PM   #6 (permalink)
I had no idea it generated that much static. I wasn't even spooling up all that fast, just on 6S to like 20% for testing. Crazy stuff.
Old 11-16-2015, 02:52 PM   #7 (permalink)
It is worse in dry weather.
If you start searching the forums, you will see that various machines have had issues with this (including Compass, Align, and Mikado). Grounding the boom and coating the belt with silicon about once a year, eliminates the issue.
Old 11-16-2015, 04:12 PM   #8 (permalink)
Yep, I've also seen the arcing. Pretty impressive.
Q700
RCHN #232
quinn is offline        Reply With Quote Quick reply to this message
Old 11-16-2015, 06:40 PM   #9 (permalink)
Yep. Like Ah Clem said, the lack of moisture in the air really increases static electricity.
Also, you should check continuity with an ohmmeter from the tail case to the motor mount to verify it is grounded properly.
Eric T is offline        Reply With Quote Quick reply to this message
Old 11-17-2015, 11:04 AM   #10 (permalink)
Got it setup today, need to purchase the ohmmeter or whatever that is some time to verify before putting it in the air. I soldered a wire to a washer for the tail, and soldered the wire to the washer on the motor mount. I gave it a good tug and everything felt good. Starting to question solder to washer in a high vibration environment though. Thoughts? Thinking I should just do it right and get the little eyelit thing I saw in the compass video. Last thing I want is that wire coming out in flight, I saw how the components reacted and fail-safe didn't always activate.
Old 11-17-2015, 02:52 PM   #11 (permalink)
A soldered washer should be fine (I have done this in the past).
I usually use crimp type lugs (but solder them anyway).
Make sure that you spray the belt with silicon, inside and out.
Normally you don't need a ground wire on the tail gearbox, as the bolts that retain the gearbox to the boom pierce the tail boom.
The important one is from the boom to the motor mount.
