Go Back   HeliFreak > R/C Helicopter Support > Bergen R/C Helicopters
Bergen R/C Helicopters Bergen Intrepid 90 Intrepid Turbine Observer Industrial Twin Observer Turbine Support Forum
Old 01-05-2007, 05:01 PM   #1 (permalink)
Default Generator Mounts
In between test flights of new heli's over the holidays, I was able to come up with some simple mounts for Raja's (rbort) "Jewel" Generators.
For the Intrepid Gas and 90/Magnums.
For the Observer EB's
And for the Twin Observers.
The mounts for the Gassers and Observers will be available through Raja, or us, very shortly, for $20.00.
The Mounts for the Twin Observers can be gotten directly from us, and will cost more due to the additional parts needed.
Chris D. Bergen
cbergen is offline        Reply With Quote Quick reply to this message
Old 01-05-2007, 05:37 PM   #2 (permalink)
YEAH
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
www.circlecityhelis.com
lperagallo is offline        Reply With Quote Quick reply to this message
Old 01-05-2007, 09:49 PM   #3 (permalink)
Very slick design Chris
C.Ward
Essex Photography
www.lynchburgaerials.com
heliplt is offline        Reply With Quote Quick reply to this message
Old 01-06-2007, 08:23 AM   #4 (permalink)
Chris, what kind of output are you seeing watts, volts. Craig B
heliman53 is offline        Reply With Quote Quick reply to this message
Old 01-06-2007, 01:26 PM   #5 (permalink)
I've just made the mounts, the Generators come from rbort, http://mysite.verizon.net/vze49gsg/
Chris D. Bergen
Old 01-07-2007, 10:12 AM   #6 (permalink)
Yeeha Chris!
Output is 5.4v, up to 3 amps continuous, 5 amps surge.
Watts would be 16w at 3 amp but the generator motor is capable of around 70w.
In flight tested with a watt meter on my Spectra-g showed 2.45a max amp draw during heavy 3D.
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is offline        Reply With Quote Quick reply to this message
Old 01-08-2007, 07:17 AM   #7 (permalink)
How do you start a 90 size motor with this generator in place, or is it just intended for Gassers? - not that you really need it for glow flights last all of 8minutes or so.
Would be good to switch the motor direction in order to flick a switch and start the engine. Don't think 70W is going to do much though
Kevin
Sponsored by Climbout UK, OptiFuel, Rossendale Models
Synergy E7, Scorpion 5020-450, Optipower 12s4300, Mini Vbar5.2, Spin690
Outrage Fusion50e, Scorpion 4035-560, Optipower 12s3500, Vbar5.2, Spin620
Protos 500, BeastX. RJX90, Bergen 90E, Rave450
ktargett is offline        Reply With Quote Quick reply to this message
Old 01-09-2007, 11:15 AM   #8 (permalink)
You got me with that one. I've been flying gassers and turbines for so long, I totally blanked on the starting of a 90........
I suppose we could go back to starting with a belt!!
Chris D. Bergen
Old 01-29-2007, 06:01 PM   #9 (permalink)
sorry for asking a newbie / idiot question:
What does this "generator" do? What's it's purpose???
Brady Longmore is offline        Reply With Quote Quick reply to this message
Old 01-29-2007, 09:31 PM   #10 (permalink)
Check the link to Raja's site, basically it powers the electronics on the heli.
Chris D. Bergen
Old 03-07-2007, 02:21 PM   #11 (permalink)
Just an update, I test flew an Industrial Twin today made for the people that Raja fly for, with a Generator installed.
While running at an idle, I felt around for any vibes or looseness or any hint of an issue and could not find one. I kept a close eye on it while in a hover for any sign of a high freq or any radio interference, Smooth as glass, no problems whatsoever.
Excellent job Raja, I give your idea a big :thumbsup2: .
Chris D. Bergen
Old 03-07-2007, 05:27 PM   #12 (permalink)
Excellent Mr. Bergen! Thanks for getting that heli up and flying for us too! Now that you made this post I think I better get ready for more requests! I'm down to 1 stock generator, 1 duel jewel, and 2 jewels spoken for in stock, but I just ordered some more parts yesterday and today to make some more.
By the way everyone, I will be going on vacation the first couple of weeks in April, so just wanted to post it here in case you are looking for me and I don't answer email or such.
-=>Raja.
Old 09-07-2008, 09:41 PM   #13 (permalink)
Chris, do you have a part number for the Generator mounts?
They're a bit hard to find on the site... If you're still selling them, that is.
-Eric
rccardude04 is offline        Reply With Quote Quick reply to this message
Old 09-07-2008, 10:29 PM   #14 (permalink)
Default Bergen Jewel mounts
If you're looking for the Bergen Intrepid mount or the Observer mount, I have those in stock. The part numbers are 2046 or 2046-O. I'm sure Chris can get you one as well if you're ordering other parts to make it more convenient for you.
-=>Raja.
Old 09-07-2008, 10:59 PM   #15 (permalink)
I need the intrepid mount and I'm already making out an order from Bergen for some blades and a flybar since I decided to tip it over after the tail let go.
I'd order it direct from you but I don't have paypal and my friend needs it pretty quick.
Thanks for the #s!
-Eric
Old 08-26-2009, 07:39 AM   #16 (permalink)
Default Need conformation and a little help
Hi folks,
I have got the mounting plate and Raja's heavily worshiped Jewel and am following the instructions on Bergens website for fitting but I am struggling to get the plate on.
I have poped off the popsicle stick and now have the mount plate against the chasis on the right side with the two screws into the triple bearing block. My issue is now to put the popsicle stick back on as I have very little room to get it on the rectangular seasaw where the jamut goes. If I do put it on the popsicle stick rubs heavily on the mount plate and also the pop' stick is only and I mean only just on the rectangular seasaw. Its almost as if the mounting plate is too thick... or it needs to go on the inside of the chasis...but if I did that it wouldnt line up to the shaft on the triple bearing block.
Any tips... advice... or is that just the way it is?
Cheers folks...
p.s above is in Phils terminology... if more description is required dont hesitate to ask
madmcphil is offline        Reply With Quote Quick reply to this message
Old 08-26-2009, 07:46 AM   #17 (permalink)
The angled plate does go on the INSIDE of the frames. If you have some slight offset with the shaft, try flipping it around and attaching it to the OTHER side frame.
Got pics?
The black flat plate is ONLY to be used as a template for drilling the holes if your frames do not already have them...It is then removed.
Chris D. Bergen
Old 08-26-2009, 08:19 AM   #18 (permalink)
Cheers Chris....
Makes sense now... I just had it in my head it was a supporting plate... not a "tem" plate
Old 10-02-2009, 01:27 AM   #19 (permalink)
Hi There!
Thanks!...
Have a nice Day to all!....
venusse45 is offline        Reply With Quote Quick reply to this message
Old 04-14-2013, 07:48 PM   #20 (permalink)
are the gen mounts available yet?
SRW, EFC,RCRCC
AMA 930196
IRCHA 3540
Skookum support pilot
geomecc is offline        Reply With Quote Quick reply to this message
